Administrators MaLd0n Posted January 12, 2023 Author Administrators Share Posted January 12, 2023 6 hours ago, desmocrash said: Asus strix Z690-G Gaming Wi-Fi https://www.transfernow.net/dl/20230112yepDhCZJ Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @danielnmaldonado@gmail.com Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Sutrisno Sofingi Posted January 14, 2023 Share Posted January 14, 2023 (edited) i try to install Mojave No MAC, My installation always stuck/stop in this status, please help me Edited January 14, 2023 by Sutrisno Sofingi Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted January 14, 2023 Author Administrators Share Posted January 14, 2023 7 hours ago, Sutrisno Sofingi said: i try to install Mojave No MAC, My installation always stuck/stop in this status, please help me https://www.olarila.com/topic/25111-hackintosh-efi-folders-for-all-chipsets-with-opencore-mod/ Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @danielnmaldonado@gmail.com Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
desmocrash Posted January 14, 2023 Share Posted January 14, 2023 On 1/13/2023 at 12:38 AM, MaLd0n said: https://www.transfernow.net/dl/20230112yepDhCZJ Hello Mald0n you are the best I mapped the usb it's good there. There are still some issues when leaving standby loss of network but otherwise everything is ok Big thanks Quote Link to comment Share on other sites More sharing options...
fergazz Posted January 14, 2023 Share Posted January 14, 2023 Saudações! Pequeno problema aqui, o OC não retira a entrada da EFI no boot, tentei diversas formas, não consegui fazer ele tirar a EFI, ficando em looping, até que eu selecione a unidade MacOS para carregar o sistema… Alguma alternativa para resolver isso? Procurei e não encontrei algo específico para isso… Quote Link to comment Share on other sites More sharing options...
FabianDeAsis Posted January 14, 2023 Share Posted January 14, 2023 Hello everyone! I am having (since yesterday) a problem installing Mojave. In fact, it doesn't even boot the USB drive. I watched a few tutorials on YouTube, followed the guides here, copied the EFI folder for my motherboard (I have a DH67CL), used other flash drives, disabled and enabled UEFI booting, disabled Virtualization, and nothing. The error in question says "Reboot and Select proper Boot device or insert boot media in selected boot device and press a key". I know that means that the boot usb drive has not been recognized, or at least the RAW image I downloaded to install Mojave. So, I downloaded High Sierra and did exactly the same thing again. I flashed the image with Balena Etcher (without any errors), rebooted and selected the bootable USB drive and.... Nothing. But this time, I get an infinite loop of the following image: Things I tried: - Format USB drives with MiniTool Partition Wizard (because creating the bootable drive creates partitions with formats that Windows does not read, so I return the flash drive to its original state every time my attempts fail). - Using three flash drives (8gb, 16gb and 64gb respectively) including an external and an internal hard drive. - Toggle between GPT and MBR partitions with each attempt. - Download the same Mojave and High Sierra Olarila Image's at least 3 times each (only just in case...) - Install with Rufus (yes, it is possible, and it has worked for me before). Same result as with Balena Etcher - Disconnect each drive until only the usb drive is left. - Enable and Disable UEFI Boot, disable integrated IGP, boot without GPU (using the integrated graphics). - Connect each flash drive to each USB port on the motherboard (including a couple of USB 3.0 ports). - Connect all the pendrives in two other PC's and a laptop (and follow exactly all the above mentioned, to rule out any probability). I should mention that a year ago I installed High Sierra on this same computer without any problem, and the only thing I didn't try to do was to download the version I used then because it is removed from the site and I can't get it anywhere else. Ofc, currently, I just want to install Mojave. My Specs: - Mother Intel DH67CL - i5 3570 - 8Gb (2x4Gb) DDR3 1600 - Radeon R7 250 2Gb GDDR3 - Corsair CX450 - An SSD for primary OS and a lot of HDD's I appreciate in advance any help u can offer me, I'm already desperate hahaha. Regards! Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted January 15, 2023 Author Administrators Share Posted January 15, 2023 1 hour ago, FabianDeAsis said: I have a DH67CL u need check if this mobo have uefi mode Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @danielnmaldonado@gmail.com Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
FabianDeAsis Posted January 15, 2023 Share Posted January 15, 2023 4 minutes ago, MaLd0n said: u need check if this mobo have uefi mode In "Things I tried" I mention that I have disabled and enabled UEFI mode (I did it a lot of times), so the BIOS of that motherboard does have that option. Enabled or disabled, I can't boot the flash drive. Quote Link to comment Share on other sites More sharing options...
FabianDeAsis Posted January 18, 2023 Share Posted January 18, 2023 Well, thank you all very much for your great help, I solved it. Have a nice day. Quote Link to comment Share on other sites More sharing options...
Souza Thiago Posted January 21, 2023 Share Posted January 21, 2023 (edited) My notebook freezes when it reaches 16%. Intel i5 8 generatio, 16gb ram, ssd m2 nvme, 2 usb-c, 1 usb-a. Edited January 21, 2023 by Souza Thiago Quote Link to comment Share on other sites More sharing options...
Apple_Lover_1984 Posted January 23, 2023 Share Posted January 23, 2023 Hi I'm new here I can't seem to even get to the installer screen as the screen goes black after many fast scrolling walls of text! I waited a long time and the screen stayed black (about 20 minutes I waited) My system is an HP EliteDesk 800 G4 SFF with the iGPU and Core i5-8500 with a 256GB SATA SSD I don't have access to a Mac that is up and running as it seems most of the Hackintosh tools seem to be Mac only? I did use the Windows way of putting in the correct (Coffee Lake in my case) EFI folders in place however I can't get to the installer so I can't even install the OS what am I doing wrong? Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted January 24, 2023 Author Administrators Share Posted January 24, 2023 On 1/23/2023 at 1:27 AM, Apple_Lover_1984 said: My system is an HP EliteDesk 800 G4 SFF with the iGPU and Core i5-8500 with a 256GB SATA SSD -Bios/UEFI in full default settings(Just change settings if need) -Use USB2 port for easy installation with no remap USB -Users with IGPU can use -igfxvesa bootarg for easy installation -Delete old EFI folder and paste new. Don't use merge files -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead -Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @danielnmaldonado@gmail.com Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Karbitonit Posted January 26, 2023 Share Posted January 26, 2023 hello, please help, I can't understand why the installation does not start on the asus prime h370m plus board I downloaded the efi folder from here, although everything went fine on the z370 board no video card on board Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted January 26, 2023 Author Administrators Share Posted January 26, 2023 -Bios/UEFI in full default settings(Just change settings if need) -Use USB2 port for easy installation with no remap USB -Users with IGPU can use -igfxvesa bootarg for easy installation -Delete old EFI folder and paste new. Don't use merge files -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead -Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @danielnmaldonado@gmail.com Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
di sempakin Posted January 28, 2023 Share Posted January 28, 2023 Error Install macOS Monterey. install mac os monterey application is damaged "This copy of the install mac os monterey application is damaged, and can't be used to install mac os" IMG_20230128_150041.zip Quote Link to comment Share on other sites More sharing options...
Pzre9 Posted February 5, 2023 Share Posted February 5, 2023 (edited) Removed due to installing another OS for tampering the EFI files. Edited February 5, 2023 by Pzre9 1 Quote Link to comment Share on other sites More sharing options...
SHUBHKARMAN SINGH Posted February 5, 2023 Share Posted February 5, 2023 (edited) Edited February 6, 2023 by SHUBHKARMAN SINGH 1 Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted February 5, 2023 Author Administrators Share Posted February 5, 2023 1 hour ago, SHUBHKARMAN SINGH said: How to fic MacOS Ventura is not Compatible with this Mac error while installing MacOS Ventura on my PC stay on compatible version 1 1 Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @danielnmaldonado@gmail.com Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
di sempakin Posted February 8, 2023 Share Posted February 8, 2023 Thank you somatch All Quote Link to comment Share on other sites More sharing options...
zmassy Posted February 10, 2023 Share Posted February 10, 2023 Hi guys I'm trying to install monterey on my desktop through your raw image seen and considering that I start from windows I prepare the stick with balenaEtcher I insert the uefi in the stick but when I restart it only gives me problems, I attach photos and a report of cpu-z the inserted uefi is that of Haswell desktop ,I hope someone can help me.Thank you very much ps sorry for my english MASSIMO.zip Immagine 2023-02-09 152310.zip Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted February 10, 2023 Author Administrators Share Posted February 10, 2023 -Bios/UEFI in full default settings(Just change settings if need) -Use USB2 port for easy installation with no remap USB -Users with IGPU can use -igfxvesa bootarg for easy installation -Delete old EFI folder and paste new. Don't use merge files -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead -Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @danielnmaldonado@gmail.com Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Guest Posted February 11, 2023 Share Posted February 11, 2023 Hello, I have an Acer Aspire A315-58 laptop, processor 11th Gen Intel(R) Core(TM) i3-1115G4 Tiger Lake-U Is it possible to install Hackintosh on it? I have two SSDs in it. Primary SSD is running windows. How can I install Hackintosh in the secondary SSD? But my main question is, is it possible to install Hackintosh on this laptop? Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted February 11, 2023 Author Administrators Share Posted February 11, 2023 2 hours ago, sam99eer said: Hello, I have an Acer Aspire A315-58 laptop, processor 11th Gen Intel(R) Core(TM) i3-1115G4 Tiger Lake-U this IGPU don't have support on macos Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @danielnmaldonado@gmail.com Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
zmassy Posted February 12, 2023 Share Posted February 12, 2023 good morning, does anyone know how to have graphics acceleration with the gt 710 2gb video card, with monterey installed? thanks a lot Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted February 12, 2023 Author Administrators Share Posted February 12, 2023 this card lose support and u need use OCLP Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @danielnmaldonado@gmail.com Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
