appleliciouzs Posted April 6, 2013 Share Posted April 6, 2013 Greetings! I am new in installing Mac OS X. Actually, I downloaded already the OS itself but I'm having kernel panic and it says that cannon load UEFI settings??.. I really want to install this. Please help me, I am really new installing this since I never owned a Mac products. Btw, this my system: Asrock H61m-u3s3 Intel Core i5 2320 8GB RAM Power Color 7770 ( AMD Radeon 7770) Since i found that my gpu are supported in this version of ML(10.8.3) Please help me. TIA. Quote Link to comment Share on other sites More sharing options...
Xelerater Posted April 6, 2013 Share Posted April 6, 2013 When ever i try to boot from Hard disk through chameleon boot loader i get this kernel panic (attached image) please help.. if I set the system definition to iMac 12.2 then still i get the same error how to fix?? I need to know if i need to flash the bios of my motherboard (i mean is it necessary)?? Please guide, Thank you  Quote Link to comment Share on other sites More sharing options...
pernacabeluda Posted April 6, 2013 Author Share Posted April 6, 2013 You need to patch AICPM and use SSDT for your CPU. Read http://Olarila.com/forum/viewtopic.php?f=28&t=1703 Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Xelerater Posted April 7, 2013 Share Posted April 7, 2013 Thanks alot for helping, i have managed to fix that Kernel Panic above, but unfortunately now i'm getting these two kernel panics randomly (see attached pictures). I'm using system definition MacPro 4,1 to Fix the 560 ti values (as mentioned in below link).. is there any way to attempt 560 ti fix, if I use system definition iMac 12,1 or iMac 12,2. http://dbm.devbin.org/gtx560ti/ Thanks alot guyz for all the support, i must appreciate your efforts   Quote Link to comment Share on other sites More sharing options...
Xelerater Posted April 8, 2013 Share Posted April 8, 2013 Thanks alot for helping, i have managed to fix that Kernel Panic above, but unfortunately now i'm getting these two kernel panics randomly (see attached pictures). I'm using system definition MacPro 4,1 to Fix the 560 ti values (as mentioned in below link).. is there any way to attempt 560 ti fix, if I use system definition iMac 12,1 or iMac 12,2. http://dbm.devbin.org/gtx560ti/ Thanks alot guyz for all the support, i must appreciate your efforts  Thanks alot guyz i have managed to fix it, i selected iMac 12,1 as mentioned in this forum, all is fine now. I want to build another Hackintosh and i want to know that if this PC is OK for Mountain Lion, or should I install Lion or Snow Leopard. System Specs: Intel Dual Core E6500 (2.93Ghz) Asus P5QPL-AM (Intel G41 Chipset) (LGA775), Video Chipset: Intel GMA 4500(M)(HD) Audio: Realtek ALC887 Network Card: Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller (NDIS6.20) 1 gb DDR2 Ram (Bus Speed 667 Mhz) Let me if there is some DSDT available for this Motherboard. If I need to upgrade RAM then let me know (DDR2 2gb 800 Bus would be fine?). I need to know about SMBIOS shall i select iMac 9,1 it will be fine? or shall i use Mac Pro 3,1? Quote Link to comment Share on other sites More sharing options...
bravo503 Posted April 15, 2013 Share Posted April 15, 2013 Hello, new to the forum and hackintosh looking for some guidance I have managed to boot the flash drive and install osx onto my hard drive. when I boot it up after installing it I select the hard drive it flashes some text on the screen very quickly and then reboots. I have tried using verbose mode -v, safe mode -x, -f, and -F. What can it be if it will boot from the usb but not from the hard drive. additional info: for some reason it always boots straight to chameleon i have never seen clover. I am using a 128gb kingston ssd motherboard: asrock Z77 extreme 4 cpu: corei7 3770k thanks in advance Quote Link to comment Share on other sites More sharing options...
artur-pt Posted April 15, 2013 Share Posted April 15, 2013 hello take a good read here... what is u graphics ? http://Olarila.com/forum/viewforum.php?f=28 good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
bravo503 Posted April 16, 2013 Share Posted April 16, 2013 my graphics is intel hd 4000 I checked the link you posted and I found this link http://Olarila.com/forum/viewtopic.php?f=28&t=3111. I couldn't even begin to understand what those instructions were explaining but I noticed that the files gave the vid card 32mb of ram. I set my bios to give only 32mb to video and it booted up! I'm sure there's a long road ahead because nothing works currently, but at least I have something to work with! Quote Link to comment Share on other sites More sharing options...
artur-pt Posted April 16, 2013 Share Posted April 16, 2013 hello i see but u must read... is all here in forum to do a hack... but must read about it mac os x is developed for mac .. hack mac os x is 99% of reading, googling, persistency and 1 % of luck u hardware be compatible good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
kendovietnam Posted April 21, 2013 Share Posted April 21, 2013 I installed with -v -x -f GraphicsEnabler=NO. Everything was fine until this morning, i could not boot to MAC OS. Does anyone can help me please? I used Dell Inspiron 5250 with Intel i7 3612QM. Mac OS did not recognize any graphic cards, ATI 7670 or even HD 4000 with full kexts installation. Quote Link to comment Share on other sites More sharing options...
artur-pt Posted April 21, 2013 Share Posted April 21, 2013 hello amd card don't work give a good read in Guides and Tutorials here in forum and u see how to install intel hd 4000. http://Olarila.com/forum/viewforum.php?f=28 good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
wallenfx Posted April 25, 2013 Share Posted April 25, 2013 Guys I have problem when trying to install OS X 10.8.3 I get White screen with spinning gear/wheel(cursor) i tryd GraphicsEnabler=No -f , PCIRootUID=1,0,1-x and no luck still stuck with white screen and spinning wheel. Please HELP ! I'm using USB BOOT AMD RADEON 6670 Intel core i5 3550 3.3 GHz Gigabyte GA-H77-DS3H Quote Link to comment Share on other sites More sharing options...
pernacabeluda Posted April 25, 2013 Author Share Posted April 25, 2013 Did you try both Clover and Chameleon? Try moving video kexts, see instructions on first post. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
wallenfx Posted April 25, 2013 Share Posted April 25, 2013 I did try both and i get same problem I'll try moving video right now. Quote Link to comment Share on other sites More sharing options...
wallenfx Posted April 25, 2013 Share Posted April 25, 2013 Moved kext but still same problem... Quote Link to comment Share on other sites More sharing options...
wallenfx Posted April 25, 2013 Share Posted April 25, 2013 with GraphicsEnabler=No thats where it stops Quote Link to comment Share on other sites More sharing options...
mendietinha Posted April 25, 2013 Share Posted April 25, 2013 you have to move the proper kexts and boot with GE=No and -f. or -x too. Quote Se quando viaja faz o que quer, quando viajar, não leve a mulher ----  No PM support. Use the forum..Dell Latitude i7 8565U 16Gb 256Gb M.2 Intel UHD620 (macOS 14.3) OC Lenovo Core I5 6200U 8Gb 256Gb HD520 (macOS 14.4b) OC Ryzen 7 5700X 32Gb 2Tb nvme RTX 3060TI 8Gb (W11) Link to comment Share on other sites More sharing options...
wallenfx Posted April 25, 2013 Share Posted April 25, 2013 I Used GraphicsEnabler=No -x and got to instalation and instaling right now ! Lets see how it will go And thank you very much! Quote Link to comment Share on other sites More sharing options...
wallenfx Posted April 26, 2013 Share Posted April 26, 2013 Hey me again I instaled OS X 10.8.3 with CLOVER and when when I want to Boot the USB drive, then choose to boot the HD you just installed OS X (not the installer USB again) I'm stuck at this screen BUT IF I USE -X AND GRAPHICSENABLER=No I GET TO SAFE MODE... WHAT SHOULD I DO ? Quote Link to comment Share on other sites More sharing options...
pernacabeluda Posted April 26, 2013 Author Share Posted April 26, 2013 You have to configure graphics injection and maybe patch kexts http://Olarila.com/forum/viewtopic.php?f=28&t=736 Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
wallenfx Posted April 26, 2013 Share Posted April 26, 2013 i fixed everything but now i get boot0 error and i used Clover to install OS X 10.8.3 how to fix it help Quote Link to comment Share on other sites More sharing options...
pernacabeluda Posted April 26, 2013 Author Share Posted April 26, 2013 Like this, but get boot1h from /usr/standalone/i386 http://Olarila.com/forum/viewtopic.php?f=28&t=1676 Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
wallenfx Posted April 26, 2013 Share Posted April 26, 2013 I'm geting dd: boot1h: no such file or directory Quote Link to comment Share on other sites More sharing options...
pernacabeluda Posted April 27, 2013 Author Share Posted April 27, 2013 You have to copy it from /usr/standalone/i386 to the root of the installer USB  cp /usr/standalone/i386/boot1h /Volumes/OS\ X\ Install\ USB Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
wallenfx Posted April 27, 2013 Share Posted April 27, 2013 But there is no boot1h file on USB WITH MAC OS X 10.8.3... There is only boot.efi Quote Link to comment Share on other sites More sharing options...
