jjk2014 Posted January 4, 2014 Share Posted January 4, 2014 I've tried chamelion as you told. But its getting stuck at "Missing bluetooth..". Also I'm able to boot well using default installer clover. PS: I installed using clover. I can't install with chamelion coz it gets stuck like above. I don't know what's in Clover which makes it possible to boot/install well on my system. Sorry to ask you again; is there any way I can install the exact bootloader from usb to hdd. thank you Quote Link to comment Share on other sites More sharing options...
PimentelX86 Posted January 4, 2014 Share Posted January 4, 2014 Hello You can use Chameleon, did you create these files? *org.chameleon...*SMbios And installed these kexts? Also you need install FakeSMC and NullCPUPM(generic power management)... post your or.chameloen and SMbios files... i'll check it Quote Link to comment Share on other sites More sharing options...
greko2009 Posted January 5, 2014 Share Posted January 5, 2014 Hello, I installed OS X, Clover bootloader and Realtek Network drivers. When booting from USB everything works fine, I also have 2 monitors and they both work perfectly and desktop is extended. When I try to boot from hard disk then boot gets stuck at : missing bluetooth controller transport Also, what should I do to enable sound? My config is: Gigabyte EP45-DQ6 Nvidia Geforce 9500 GT 1GB 8GB RAM Thank you Quote Link to comment Share on other sites More sharing options...
artur-pt Posted January 5, 2014 Share Posted January 5, 2014 hello u should read this http://Olarila.com/forum/viewtopic.php?f=28&t=1716 http://Olarila.com/forum/viewtopic.php?f=28&t=3901 good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
greko2009 Posted January 6, 2014 Share Posted January 6, 2014 hello u should read this http://Olarila.com/forum/viewtopic.php?f=28&t=1716 http://Olarila.com/forum/viewtopic.php?f=28&t=3901 good hack Thanks a lot but since it was working perfectly when booting from USB I checked the bootloader differences and noticed that USB bootloader "injects" NVidia. So, I changed my clover options to "inject NVidia" , copied NV* kexts from USB and it works perfectly (tested with a steam game too to make sure 3D acceleration works). Also installed ALC889A kexts and sound works fine too. Thank you for your help Quote Link to comment Share on other sites More sharing options...
jjk2014 Posted January 11, 2014 Share Posted January 11, 2014 Let me explain my progress.. I started fresh install by partition hdd into two(250GB each) as GUID. I booted ML install usb using clover installed ML on the first partition. Following this guide http://Olarila.com/forum/viewtopic.php?f=27&t=3101&start=490. I managed to boot from hdd without using usb. After this success, I went on to install windows vista. Again I started over by partition hdd using ML usb disk utility restarted and installed vista on the second partition. I could boot vista from hdd. Then again I installed ML to the first partition followed guide above but after restart still vista is loading. So now I need help dual booting vista. Quote Link to comment Share on other sites More sharing options...
artur-pt Posted January 11, 2014 Share Posted January 11, 2014 hello u need to install the boot loader in first partition use boot0hfs for chameleon use boo0ss for clover good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
jjk2014 Posted January 11, 2014 Share Posted January 11, 2014 I made 2 guid partitions using ml usb installer(one for OSX and 2nd msdos)restarted. First installed Vista.(in vista setup custom,I saw about 4 partitions I selected the msdos partition). Vista booted normally from hdd). Then I installed ML on OSX partition installed clover bootloader as imentioned above. Still only vista loads.. Quote Link to comment Share on other sites More sharing options...
artur-pt Posted January 12, 2014 Share Posted January 12, 2014 hello u do something wrong.. is so easy guid 2 3 partitions first mac os x .. hfs+ second to windows (fat should be only formated in windows install ntfs) install the 2 system install the boot loader in first.. boot0hfs or boot0ss and there u go if not work no ideias ( it works for anybody using legacy boot ) good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
jjk2014 Posted January 12, 2014 Share Posted January 12, 2014 Thank you artur... I forgot to add boot0ss while installing clover. So basically this is what I've done correct me if I'm wrong: Partitioned HDD installed windows on second partition. Then installed OSX on first partition. Booted using USB to OSX then I installed clover package(rev 2061 same with usb i guess). Immediately after installing clover I followed pernacabeluda's instructions http://Olarila.com/forum/viewtopic.php?f=27&t=3101&start=490 and booted into HDD. Am I correct upto this level? Quote Link to comment Share on other sites More sharing options...
jjk2014 Posted January 12, 2014 Share Posted January 12, 2014 So now I can boot both OSX and windows successfully. I managed to install graphics, sound, network etc. and use my system without any major problem. Only System standby don't work. So Now I have these questions. Should I install any other kexts to safely use my system.( From what I know the ML EFI already contains all the necessary kexts) I don't mind standby etc. I just want to use softwares like CAD etc. So shall I continue using system or anything important to check??? Quote Link to comment Share on other sites More sharing options...
artur-pt Posted January 12, 2014 Share Posted January 12, 2014 hello only need to install third party kext if need it.. read carefully post intall guide.. is all there http://Olarila.com/forum/viewtopic.php?f=28&t=1716 good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
jjk2014 Posted January 12, 2014 Share Posted January 12, 2014 thanks artur, So are you saying that I can use my system without damaging it? Please note that I have not added ant dsdt/Power management etc. Only the EFI folder copied from USB Installer to HDD. Quote Link to comment Share on other sites More sharing options...
artur-pt Posted January 12, 2014 Share Posted January 12, 2014 hello u don't have native power management.. because u use nullcpupowermanagement.. like the name say .. it null appleintelcpupowermanagement and protect u cpu overeating but u can work that way.. like so many others users.. only have minimum state and maximum.. about that u must read.. good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
jjk2014 Posted January 13, 2014 Share Posted January 13, 2014 will it overheat my CPU and thus damage motherboard. I will be using some photoshop like softwares on my hack. One more thing can I update everything from Appstore Update section? If I update using Appstore I should immediately do it afterML install? OR after setting bootloader kexts etc? which way you prefer? Quote Link to comment Share on other sites More sharing options...
artur-pt Posted January 13, 2014 Share Posted January 13, 2014 hello what u gonna update ? if the system is not working well ? first u set the system.. when is stable.. and u know what u do to make that.. then update good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
jjk2014 Posted January 13, 2014 Share Posted January 13, 2014 Thanks for your advice and keeping my spirit up... Now I fell into another trouble.. This time I partitioned my hdd into 3. first osx, then rest two msdos ( because I needed a partition for exchange data between OSes.) As usual I first installed Windows vista on 2nd partition msdos. It was booting fine. After finishing vista setup, I installed ML via USB into the OSX partition. I installed clover using boot0ss Now I can boot ML fine but not to vista. Clover is showing the two os in menu ML and Boot windows from Legacy 3. If I select Vista I see a cube-like icon for sometime then blank screen. Can u tell where I went wrong? Quote Link to comment Share on other sites More sharing options...
artur-pt Posted January 13, 2014 Share Posted January 13, 2014 hello no idea.. if it work once.. u must do something wrong.. revise u procedure.. good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
duey101 Posted February 18, 2014 Share Posted February 18, 2014 Hi, I've been working on this for a while now (3 days) and I can get it to install but when I try to run it I get this screen... I can boot up to the USB after install and go to the option to boot from the HDD I installed on (primary, active) but when I click on that option the cursor blinks once and then freezes on a plain screen, nothing happens. If I boot using Chameleon I get the similar options from the Chameleon menu and I click boot from HDD, get the above progress and then it stops. I have no clue how to fix it. Any ideas what is wrong? This is the USB RAW install from this link... http://bayproxy.me/torrent/8915051/ Quote Link to comment Share on other sites More sharing options...
artur-pt Posted February 20, 2014 Share Posted February 20, 2014 hello read the install guide ... have u moved ur video kext ? the nvidia don't work.. only hd 3000 is all in install guide http://Olarila.com/forum/viewtopic.php?f=28&t=2193 good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
ericsia Posted March 2, 2014 Share Posted March 2, 2014 Trying to install this version over HP DV6 1390 but getting this before starting installation:this version of Mac OS x is not supported on this platform reason: Mac-F22788A9 any idea? are you booting from USB? Clover or Chameleon? Try forcing another SMBIOS, a more recent model which is supported by Mountain Lion. I can't find the folder where you install clover, can you tell me where is it? Quote GMA 4500 kext https://mega.co.nz/#!DlIQ2CpA!OovTWWRQIUQ-osUbj7bcTjrbByBCmVf5AfW-A5GUNtA Link to comment Share on other sites More sharing options...
henrietta1234 Posted December 28, 2020 Share Posted December 28, 2020 hello. what does that mean : "Access chat to get download link (channel topic)." if i click on the chat im in some chat group where nobodys answering and i dont get a download link? thanks in regard Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted December 30, 2020 Administrators Share Posted December 30, 2020 On 12/28/2020 at 8:05 PM, henrietta1234 said: hello. what does that mean https://www.olarila.com/forum/83-olarila-pre-made-iso-recommended/ Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
