Hackintosh Guide - Catalina / Big Sur / Monterey on Mobos Series 100, 200, 300, 400 and 500 with OpenCore Bootloader
2 hours ago, diamonddust said:
hi @MaLd0n, I got this strange Audio problem affecting either with OpenCore or Clover. Right after wake up I get distorted audio do you know what could cause it.
use codeccommander
is common in some audio codecs
-Donations-
Link to comment
Share on other sites
4 hours ago, nemois said:
i7 3770k
-Donations-
Link to comment
41 minutes ago, diamonddust said:
OC Efi
-Donations-
Link to comment
12 hours ago, thief_fighter said:
@MaLd0n I got this error when booting using your EFI folder. Do you know how can I fix this?
unfortunately in hackintosh there is no solution for everyone in one simple folder, u need check it
-Donations-
Link to comment
4 minutes ago, quang1102 said:
Hi guy
use folder from first post
-Donations-
Link to comment
6 minutes ago, quang1102 said:
EFI folder from first post not working
try it
https://filebin.net/4fz59rppyoohc89e/EFI_OpenCore_Series_100.200.300.zip?t=u66db9hu
-Donations-
Link to comment
42 minutes ago, diamonddust said:
I'm struggling to get Wake up after sleep working, right no I get wake up but screen freeze, no mouse or keyboard. I did clean up the Efi folder but still
use correct smbios, iMac19,2
-Donations-
Link to comment
Ok it seems to work now, I did a Bios Clear CMOS and Load Default values than used your suggested Bios option; enable Internal Graphics and disable CSM. On the Ga Z370N wifi I did the Fixing CFG Lock and System Time and Alarm Source too.
Based on the Vanilla Guide https://khronokernel-2.gitbook.io/opencore-vanilla-desktop-guide/ the suggest this bios setting:
Recommended BIOS settings
Disable:
  • Fast Boot
  • VT-d(can be enabled if you set DisableIoMapper to YES)
  • CSM
  • Thunderbolt
  • Intel SGX
  • Intel Platform Trust
  • CFG Lock(MSR 0xE2 write protection)
  • If this can't be turned off in the BIOS(or even found) please consider patching it out. See Fixing CFG Lock for more info.
  • AMD CPU users don't need to worry about.
Enable:
  • VT-x
  • Above 4G decoding
  • Hyper-Threading
  • Execute Disable Bit
  • EHCI/XHCI Hand-off
  • OS type: Windows 8.1/10 UEFI Mode
  • Legacy RTC Device(Relevant for Z370+)
What do you think?
i5 8500 | Gigabyte Z370P D3 (F15a) | Sapphire RX 570 itx | SMBIOS iMac19,1
Link to comment
40 minutes ago, diamonddust said:
Ok
with my dsdt just enable internal graphics if u need intel quick sync and disable csm, nothing more
about MSR, u can unlock or not
-Donations-
Link to comment
Yes I tried and in fact it does boot even without fix.
Another thing I notice is that If in BIOS I set the ram speed at 2666 mhz the system wake up even with the keyboard, while if I set it with XMP Profile 1 (in may case at 3000 mhz) wake up work best with Power Button, keyboard works too but It's kind of glitchy.
Link to comment
glitchy.
check options erp
-Donations-
Link to comment
@MaLd0neu instalei o macOS Catalina no pendrive (pelo meu macbook pro, usando o DIskmaker X 9), usei o Clover_v2.5k_r5104.pkg para criar a partição EFI e o boot, copiei a pasta EFI do primeiro post (openCore 100,200,300), coloquei o arquivo gerado pela minha máquina (DSDT.aml) em ACPI/origin/, gerei os arquivos patched e tentei instalar no meu computador. Em 2 minutos para acabar a máquina trava. Atualizei o OpenCore para a ultima versão e mesmo assim dá o mesmo erro.
To te enviando o EFI final, atualizado pro 0.5.5 e com os arquivos na pasta ACPI.
Configuração do computador:
Placa-mãe: Asus TUF B360B Gaming BR
Processador: i5 9600F
Placa de vídeo: RX 580
16GB RAM
SSD 240GB exclusivo para o Hackintosh.
Agradeço desde já a ajuda.
EFI.zip
Link to comment
tem de patchear o dsdt
-Donations-
Link to comment
I'm having the following configuration,
ASRock Z170 itx/ac
i7-6600k
AMD RX 570
Intel NVMe SSD 660p
Default clover boot loader was working fine, when I try to use OpenCore on my system, it didn't manage to boot up.
When I unzip the EFI folder and startup, I get the attached screen and the system hangs. Therefore unable to run the RunMe app.
Thanks in advance!
IMG_0023.HEIC.zip
Edited by SriRuleZ
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
