Hackintosh Guide - Sierra / HighSierra / Mojave / Catalina / BigSur / Monterey on Serie 5, 6, 7, 8, 9 with Clover Bootloader / DSDT
-Donations-
Link to comment
Share on other sites
-Donations-
Link to comment
@MaLd0n I did the Catalina update and my USB ports started to act up, I added the new 15 port patch to my config, still has the same issue.
used Hackintool to map the ports, on the back of my hack I have 4 usb3 and 2 usb2, front from the first usb header I have 2 usb2.
they all tell me device needs power, when mapped the back usb2 stop working, but the fronts work fine, I checked they are marked usb2.
in Hackintool I see eh01, eh02, xhc, ehc1 (it is renamed in my config to eh01 so a bit confused here).
not sure what the deal is, using the config directly from this thread with no issues until Catalina.
let me know how you would like me to proceed with runme or a ioreg, I can revert back to before the Catalina port fix and I've already removed the ssdt's and kext Hackintool created.
Link to comment
-Donations-
Link to comment
[ref]fallen00sniper[/ref], serie 8+ don't use ehci devices, need kill it and put all usb inside xhc device ;)
-Donations-
Link to comment
[ref]fallen00sniper[/ref], post files
--Run_Me
RunMe.app
-Donations-
Link to comment
Bom dia MaLd0n,
Desde que actualizei para o Catalina que o sistema acorda do sleep inesperadamente. Às vezes aguenta-se algumas horas em sleep, outras acorda de 5 em 5m. Outras acorda e desliga passado 1m, outras acende mesmo os monitores. :(
Como poderei descobrir o que se estará a passar?
Inicialmente vi que tinha o proximitywake activo, já meti em 0 e continua a acontecer o mesmo.
Na consola em Mac Analytics Data, aparece:
powerd
Subsystem com.apple.powerd.proximityWake
Activity ID: -- Thread ID: 0x0 PID: 87
com.apple.message.domain: com.apple.powerd.proximityWake
com.apple.message.__source__: SPI
com.apple.message.darkwake2hidactivityonac: 0
com.apple.message.darkwakeonaccnt: 0
com.apple.message.darkwake2hidactivityonbatt: 0
com.apple.message.darkwakedurationonac: 0
com.apple.message.darkwakedurationonbatt: 0
com.apple.message.darkwakeonbattcnt: 0
com.apple.message.darkwakesnouseractivityonac: 0
com.apple.message.darkwakesnouseractivityonbatt: 0
com.apple.message.darkwakeswithuseractivityonac: 0
com.apple.message.darkwakeswithuseractivityonbatt: 0
SenderMachUUID: A7079937-F09A-3FC6-AADE-C3F2524432E1
Os settings para power management estão assim:
uran0s-macpro:~ uran0s$ pmset -g
System-wide power settings:
Currently in use:
autorestart 0
Sleep On Power Button 1
halfdim 0
hibernatefile /var/vm/sleepimage
proximitywake 0
powernap 0
networkoversleep 0
disksleep 10
sleep 45 (sleep prevented by mds_stores, mds)
hibernatemode 0
ttyskeepawake 0
displaysleep 45
womp 0
Envio em anexo o resultado do ficheiro runme.app
Obrigado, desde já.
uran0s.zip
Link to comment
[ref]uran0s[/ref], DSDT.aml.zip
desativa o hibernate com o .command e desativa wake from lan em preferencias do sistema e no bios tb
-Donations-
Link to comment
Já estava desactivo na bios e no sistema. Reforcei ao desactivar no terminal "sudo pmset -a hibernatemode 0" e troquei o ficheiros para o DSDT.aml que enviaste novo. Alteraste alguma coisa?
Obrigado desde já.
Dou novidades assim que verificar o resultado.
Link to comment
[ref]uran0s[/ref], "Despertar para Acesso da Rede" está desativado em opções de economia?
-Donations-
Link to comment
uran0s, "Despertar para Acesso da Rede" está desativado em opções de economia?
Continua a acordar. :(
Em preferencias do sistema>sobre>network>wifi encontrei o seguinte:
Wake On Wireless: Supported
AirDrop: Supported
AirDrop Channel: 44
Auto Unlock: Supported
Status: Connected
Têm como desactivar o WOL para o wireless? Será daqui?
Link to comment
[ref]uran0s[/ref], deve ser, tem de ver se a injector tem essa opção
-Donations-
Link to comment
fallen00sniper, post files
--Run_Me
RunMe.app
i got runme from the Olarila app, not sure if it is the same one, but it is stuck trying to use ioreg... i'll download the one you linked and see if there is a change.
it didn't want to get the ioreg, so I saved it and copied from /tmp send_me and added it to the folder, hopefully it is complete.
https://drive.google.com/file/d/1WuBrEReNOLyfT7KkJ9lmsej9I2_qryz-/view?usp=sharing
Link to comment
Hi,
I am facing error while installing Catalina on pcie nvme .
During installation when installation about to complete 2 min before system restarts and post restart clover don't show the newly installed drive.
Please need your help as this is my first time to install on nvme.
Link to comment
[ref]fallen00sniper[/ref], CLOVER.zip
Added in 2 minutes 33 seconds:
[ref]prashant[/ref], what nvme u use?
-Donations-
Link to comment
[ref]prashant[/ref], some ppl use it and work good
-Donations-
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
