artur-pt Posted October 11, 2013 Share Posted October 11, 2013 hello one of essentials is : en0 > lan card en1 > wifi card and read carefully the link good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
Nscxp2005 Posted October 12, 2013 Share Posted October 12, 2013 Hi there, I would if you can help me. I managed to load the Elan driver on boot but the only thing that works is just the keyboard. I have to plug in a USB Mouse to be able to install OSX. Do you know why this may be the case? Thanks NSCXP2005 Quote Link to comment Share on other sites More sharing options...
mendietinha Posted October 12, 2013 Share Posted October 12, 2013 it´s better to install the os x with usb mouse and after that install the elan kext Quote Se quando viaja faz o que quer, quando viajar, não leve a mulher ----  No PM support. Use the forum..Dell Latitude i7 8565U 16Gb 256Gb M.2 Intel UHD620 (macOS 14.3) OC Lenovo Core I5 6200U 8Gb 256Gb HD520 (macOS 14.4b) OC Ryzen 7 5700X 32Gb 2Tb nvme RTX 3060TI 8Gb (W11) Link to comment Share on other sites More sharing options...
Nscxp2005 Posted October 12, 2013 Share Posted October 12, 2013 OK. Thanks. Quote Link to comment Share on other sites More sharing options...
Rinnefy Posted October 15, 2013 Share Posted October 15, 2013 I still can't get Intel HD 4600 working. Is it because I'm using VGA monitor? Quote Link to comment Share on other sites More sharing options...
minh_vv Posted October 15, 2013 Share Posted October 15, 2013 hello after install new kext must boot -f -v or in clover withoutcaches space bar in GUI good hack  Hi Artur, After try to reinstall and disable Virtual T in Bios, results is success. Can you show me how to make Intel HD graphic 4000 work with Clover bootloader. Is these a link or video with more detail?(i'm newbie in Hackintosh ) Thanks so much! Minh_vv Quote Link to comment Share on other sites More sharing options...
artur-pt Posted October 15, 2013 Share Posted October 15, 2013 hello about the intel hd 4000 http://Olarila.com/forum/viewtopic.php?f=28&t=3111 clover http://Olarila.com/forum/viewtopic.php?f=28&t=3198 good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
asrul125 Posted October 17, 2013 Share Posted October 17, 2013 I have successfully installed 10.8.5 on my laptop (Qosmio F60-S543) but I am confused with The graphics drivers (Nvidia Geforce 330M) looks've read (inject) but my screen resolution is 1024 x 768. Ideally 1366x768. Please help. Thank you. Quote Link to comment Share on other sites More sharing options...
iDont Posted October 18, 2013 Share Posted October 18, 2013 I just want to try this out. I created a bootable usb via windows. Restart then select the USB but doesn't display any message or any text at all. its just a blinking cursor(like a command prompt). 10.8 works fine but i haven't tried this one 10.8.5 Quote Link to comment Share on other sites More sharing options...
RezaJufree Posted October 21, 2013 Share Posted October 21, 2013 Hey, I Just installed 10.8.5 but My problem is my Graphics, I mean yeah they all are fine but my Graphics is kind a blurred and give a some shadow when something has a black and white color. pls how i can fix this thing it's so annoying. oh yeah by the way my graphics card is gt 520m Quote Link to comment Share on other sites More sharing options...
artur-pt Posted October 21, 2013 Share Posted October 21, 2013 hello the nvidia don't work only intel hd 3000 http://Olarila.com/forum/viewtopic.php?f=28&t=2193 good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
RezaJufree Posted October 21, 2013 Share Posted October 21, 2013 hello the nvidia don't work only intel hd 3000 http://Olarila.com/forum/viewtopic.php?f=28&t=2193 good hack  Really? My laptop is Standalone Graphic. So i cant install mountain lion then? and 10.8.5 is Pre-Installed those Graphic and all working the Resolution is 1366x768 and all is perfect but the graphic very blurry and shadowing. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
criddle Posted November 1, 2013 Share Posted November 1, 2013 I have been trying to install Mountain Lion thru usb for a couple of hours . And it locks up after i boot pen drive into Clover and click on OSX hard disk to install ... I am trying to install on a Hp Pavilion A6755y AMD Phenom x4 Special Edition . I was wondering if my system is compatible or if i was doing something wrong? Quote Link to comment Share on other sites More sharing options...
artur-pt Posted November 1, 2013 Share Posted November 1, 2013 hello amd cpu is not supported http://www.insanelymac.com/forum/forum/318-amd-development/ good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
choioi Posted November 19, 2013 Share Posted November 19, 2013 Hello, give more details, which bootloader did you install, what's the error without safe boot? are you booting from USB? Clover or Chameleon? Try forcing another SMBIOS, a more recent model which is supported by Mountain Lion. Â IM boot from USB, CLOVER, same problem with DELL latitude e6400 . this version of Mac OS x is not supported on this platform reason: Mac-F22788A9 anyway how Try forcing another SMBIOS?? Quote Link to comment Share on other sites More sharing options...
artur-pt Posted November 19, 2013 Share Posted November 19, 2013 hello in clover gui hit O (options) in the menu it show the smbios try to input another + recent.. good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
shadowrace Posted November 20, 2013 Share Posted November 20, 2013 Hi guys, I've been trying to make this work but I am having the worst of luck. First, I can't boot with GraphicsEnabler=Yes. Second, I still have no Audio and third is I can't sign in to iMessage. Any help would be appreciated and I will be in your debt. I really need to make this work. Here are my specs: Intel Core i7-3770 Gigabyte H61M-DS2 3.0 AMD Radeon Sapphire 5570 1GB I already tried different Framebuffers namely, Eleumer, Baboon, Redwood, Orangutan etc. Also added SMBIOS plist. Frankly, I do not know what to do next. I feel so close to making this work but I am just out of ideas. Thanks in advance. Â Edit: At last, I've got iMessage and Audio working. All that's left is the hardest part, making the video card work. All help will be much appreciated. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
vinitb4u Posted November 26, 2013 Share Posted November 26, 2013 Hi I am also having ThinkPad t430s (i5 3320M@2.60 Ghz/Intel HD 4000 + NVS 5200M) config. with windows 8 pre installed. I am new to here. I would really appreciate help from moderators here clarifying few thing. 1> As per the above post as well as http://Olarila.com/f...php?f=27&t=3101 i got the raw file. 2> I sucssesfully burned raw file in windows to usb drive using win32diskimager then using TransMac I moved out required kext for Graphics and kernelcache. 3> But now when I boot to usb drive it shows me Clover bootloader menu ui. Upon selecting Install Mac option system hang after DSMOS Arrived error. I checked clicking gear like menu in clover it has default boot options as " -v npci-0x2000 " After searching thro' forums I tried " -v -f npci-0x2000 GraphicsEnabler=no" and "cpus=1", "-s" combinations but each time it stops at DSMOS Arrived error. Am I missing something here? I believe FakeSMC.kext required postinstallation so may not be the reason? I don't have running mac with me Is it compulsory here to have running mac in this case? If so is it impossible to install Mac with help of windows or linux? I tried pressing 1 as soon as computer boots to check if Chameleon present but nothing happens and Clover bootloader menu comesup. Any help please? Quote Link to comment Share on other sites More sharing options...
artur-pt Posted November 26, 2013 Share Posted November 26, 2013 hello some of that flags are to use with chameleon loader.. don't work with clover.. u must read about what u are trying to do.. if u hit 1 in start boot.. u go to chameleon.. if u delete the graphics kext.. if u use clover must boot withoutcaches space bar or O (option menu) give u some options to config the boot loader good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
jjk2014 Posted January 4, 2014 Share Posted January 4, 2014 I have installed ML on my PC succesfully (an HP dc7900 with Radeon6570). I can boot into the system using clover via the Installer USB. I tried installing latest Clover package, it gets installed succesfully but upon booting from hdd It freezes. So can you tell me how to Put the exact bootloader from the USB Installer to my HDD? Quote Link to comment Share on other sites More sharing options...
PimentelX86 Posted January 4, 2014 Share Posted January 4, 2014 Hello Clover is more hardest than Chameleon... if you don't know how to proceed with Clover i recommend Chameleo... Do you want continue with Clover or install Chameleon? remember chameleon is more easier... Quote Link to comment Share on other sites More sharing options...
jjk2014 Posted January 4, 2014 Share Posted January 4, 2014 The reason why I said clover bcoz I successfully installed/booted with the default clover included in the ML Raw Image. I can boot to my installed ML using USB Installer clover. But once after booting to hdd if I install chameleon/clover I cant get any of them to boot to my hdd. I get errors like "timer set to..."(I cant recall them correctly). So basically what I'm thinking is that; the clover setup from the USB works well in booting the Installed HDD. Is it possible to copy the bootloader along with the settings to the HDD? Quote Link to comment Share on other sites More sharing options...
PimentelX86 Posted January 4, 2014 Share Posted January 4, 2014 Hello I believe your mobo isn't UEFI, so you can install Chameleon, like i said it's more easier... Donwload: Donwload: http://www.insanelymac.com/forum/files/download/59-chameleon-22-svn/ But if you want you can use Clover... Everythings only need configuration... To Chameleon you need create and configure 2 main archives(use Chameleon Wizard): *org.chameleon... *SMbios In Clover you have only one: config.plist The difficulty in using clover is precisely the difficulty of configuring config.plist because it contains many parameters, in the case of Chameleon you only puts needed and let the bootloader do the rest automatically but Clover require you to adjust things for it work well .. Also you need install FakeSMC and NullCPUPM(generic power management)... So basically what I'm thinking is that; the clover setup from the USB works well in booting the Installed HDD. Is it possible to copy the bootloader along with the settings to the HDD? I don't recommend this because the config.plist that comes in bootable image has made to various hardware parameters, you only use what is necessary to do the installation, but use a hack with many unnecessary parameters in day-to-day can cause problems So, What's bootloader you'll use? Clover or Chameleon? Quote Link to comment Share on other sites More sharing options...
jjk2014 Posted January 4, 2014 Share Posted January 4, 2014 Ok. I guess I'll go with chameleon as you suggest. So that means I must do the install using chameleon.right? and can u give a quick guide on installing chameleon to hdd? Quote Link to comment Share on other sites More sharing options...
PimentelX86 Posted January 4, 2014 Share Posted January 4, 2014 Hello So that means I must do the install using chameleon.right? No. You only will install OSX, so you can install with Chameleon or Clover... and can u give a quick guide on installing chameleon to hdd? I gave To Chameleon you need create and configure 2 main archives(use Chameleon Wizard):*org.chameleon... *SMbios You need put these files in Extra folder and Extra folder must be in HD folder... Also you need install FakeSMC and NullCPUPM(generic power management)... Read in here for more info: http://Olarila.com/forum/viewtopic.php?f=28&t=1716 Quote Link to comment Share on other sites More sharing options...
