zsolt.molnarrr Posted September 5, 2013 Share Posted September 5, 2013 Hello there! My setup is: Acer 7750G, Intel Core i7(2Ghz), 4Gb DDR3 ram, Intel HD3000 + AMD Radeon HD 6650M(2Gb), Athereos WLan+Lan, Realtek Sound etc... I'm using Clover(v2.09) and I get panic every time before I reach the installer. I've only deleted Nvidia and Intel graphic kexts, (but the system behaved totally the same when Kernelcache and ALL graphics kexts were removed). When I use the default bootflags of Clover with only -f (instead of -v) bootflag I can see instantly the apple logo but it crashes a few moments later, otherwise I see the black background loading of the drivers and panic. Please help me I'm new to this as you can see and I've been for 3 days now:( Regard, Zsolt Quote Link to comment Share on other sites More sharing options...
artur-pt Posted September 6, 2013 Share Posted September 6, 2013 hello clover flags not the same as chameleon if u hit 1 when u boot u go to chameleon in clover gui options (o) boot withoutcaches good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
zsolt.molnarrr Posted September 6, 2013 Share Posted September 6, 2013 Changing to Chameleon bootloader and booting with "-f GrapicsEnabler=No" worked for me and I succesfully managed to complete the installation. Thank you for the help! (Edit: All graphics kexts and kernelcache were removed with TransMac.) Quote Link to comment Share on other sites More sharing options...
idoliki Posted September 7, 2013 Share Posted September 7, 2013 Okay, I solved the crackling issue.. After all tries, the problem was the bootloader.. I used Chimera, Chameleon, Clover.. I installed all kinds of bootloaders and then I tried to boot from the USB's bootloader (Clover, version older i think) and the audio was crackling just a bit.. I enabled SSE2 and now it's perfect. I moved the USB's Clover to EFI of my main volume and now it's all good with sound.. Just a silly question.. Everytime I restart my computer I have to enable SSE2 and to put 48000 Hz in Audio Midi Setup. Is there a way to make that change forever? Because it's a bit boring to always check that every time I restart my pc? Other than that, it's great! Thanks pernacabeluda for everything! Quote Link to comment Share on other sites More sharing options...
jeet92 Posted September 7, 2013 Share Posted September 7, 2013 NTFS -fs warning (device /dev/disk0s3, pid 112): ntfs_system_inodes_get():Windows is hibernated. Will not be able to remount read-write. Run chkdsk. Was my old error. after moving the kexts I now have: NTFS -fs warning (device /dev/disk0s3, pid 76): ntfs_system_inodes_get():Windows is hibernated. Will not be able to remount read-write. Run chkdsk. Quote Link to comment Share on other sites More sharing options...
artur-pt Posted September 7, 2013 Share Posted September 7, 2013 hello what kext have u removed ? u remove the *capri.* ? good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
praetorius Posted September 8, 2013 Share Posted September 8, 2013 If you want to use Chameleon press 1 at boot  at which point do I press "1"? on boot-up, I press F8 on Asus board to select boot device 1. do I highlight the USB installer, press 1 then press enter? 2. do I highlight the USB installer, press enter then 1? (if i don't press 1 here, i am presented with the Clover bootloader) Since I tried option #2 yesterday, it booted in Verbose mode, then came back out to the Apple Screen with the rotating wheel and did not progress further. Do I delete the Intel or whatever kexts using transmac? Quote Link to comment Share on other sites More sharing options...
CosmoHack Posted September 11, 2013 Share Posted September 11, 2013 Hello! This is my first Hackintosh install and honestly, I need some help since I have been trying to install this for 3 days but I am having some problems that aren't allowing me to do it right. First of all, my computer: Intel i7 2600K Gigabyte GA-Z68P-DS3 Rev 1.0 BIOS F4 2 x G Skill F3-12800CL9-4GBXL MSI GeForce GT520 Essentially, the problem I am facing is the message "System uptime in nanoseconds: xxxxxxxxx". This happens while booting, before the installation starts. I have tried: - Adding the DSDT.aml of my motherboard to the extra folder. No success. - Deleting the graphic video kexts. This leads to a message that says "PCI Configuration Begin". - Adding some arguments (I don't remember each of them, they were several) like: -v -x PCIRootUID=0 npci=0x2000 GraphicsEnabler=No I have been reading a lot but I have no idea of what to do. Which way should I go? Thank you. Quote Link to comment Share on other sites More sharing options...
artur-pt Posted September 11, 2013 Share Posted September 11, 2013 hello what are u using for the install ? check u bios configs ACPI 2.0 support ACPI APIC support Execute Disable Bit (NX bit) HPET support (High Precision Event Timer) Enhanced Intel SpeedStep Enhanced Halt State (C1E) all enabled HPET mode: 64-bit SATA mode: AHCI Limit maximum CPUID: Disabled good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
CosmoHack Posted September 11, 2013 Share Posted September 11, 2013 hello what are u using for the install ? check u bios configs ACPI 2.0 support ACPI APIC support Execute Disable Bit (NX bit) HPET support (High Precision Event Timer) Enhanced Intel SpeedStep Enhanced Halt State (C1E) all enabled HPET mode: 64-bit SATA mode: AHCI Limit maximum CPUID: Disabled good hack Hello Artur, thanks for answering. Here is my config: ACPI 2.0 support - Does not appear in my BIOS. ACPI APIC support - Does not appear in my BIOS. Execute Disable Bit (NX bit) - If it is the same as "No-Execute memory protect", then it is Enabled. HPET support (High Precision Event Timer) - Enabled. Enhanced Intel SpeedStep - Does not appear in my BIOS. Enhanced Halt State (C1E) - Does not appear in my BIOS. HPET mode: 64-bit - OK SATA mode: AHCI - OK Limit maximum CPUID: Disabled - OK I didn't change anything, that was also the config I was using to boot to the installation. Quote Link to comment Share on other sites More sharing options...
artur-pt Posted September 11, 2013 Share Posted September 11, 2013 hello are u using nullcpupowermanagement.kext ? must use it.. to avoid cpu KP have u disable onboard graphics ? good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
CosmoHack Posted September 11, 2013 Share Posted September 11, 2013 hello are u using nullcpupowermanagement.kext ? must use it.. to avoid cpu KP have u disable onboard graphics ? good hack Hello At the moment, I am using the default USB image so, if nullcpupowermanagement.kext is inside by default, yes I am using it. The integrated gpu is disabled. Also, now I am getting PCI Configuration Begin everytime I try. Now the nanoseconds message doesnt appear. I didnt change anything! Thanks Quote Link to comment Share on other sites More sharing options...
artur-pt Posted September 11, 2013 Share Posted September 11, 2013 hello try to insert in boot npci=0x2000 good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
CosmoHack Posted September 11, 2013 Share Posted September 11, 2013 Tried it, also npci=0x3000. Now I get "system uptime in nanoseconds". Thanks Quote Link to comment Share on other sites More sharing options...
artur-pt Posted September 11, 2013 Share Posted September 11, 2013 hello -x GraphicsEnabler=No npci=0x2000 try it good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
CosmoHack Posted September 11, 2013 Share Posted September 11, 2013 Done, nanoseconds message again Thanks Quote Link to comment Share on other sites More sharing options...
artur-pt Posted September 11, 2013 Share Posted September 11, 2013 hello what are u using to boot ? clover chameleon ? good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
pernacabeluda Posted September 11, 2013 Author Share Posted September 11, 2013 Done, nanoseconds message again Thanks Post a picture of the screen. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
CosmoHack Posted September 11, 2013 Share Posted September 11, 2013 hello what are u using to boot ? clover chameleon ? good hack  Chameleon v2.1svn r2003  Post a picture of the screen.  Here is! http://img823.imageshack.us/img823/8782/kdj8.jpg The screenshot is done with the arguments -x GraphicsEnabler=no npic=0x2000 Thanks! Quote Link to comment Share on other sites More sharing options...
pernacabeluda Posted September 11, 2013 Author Share Posted September 11, 2013 Remove /System/Library/Extensions/AppleGraphicsControl.kext/Contents/PlugIns/ApplePolicyControl.kext and add -f to your boot flags. http://Olarila.com/forum/viewtopic.php?f=27&t=1627 You are using 10.8 GM (kernel 12.0.0) and not 10.8.4 (kernel 12.4.0) which this topic is about. In 10.8.4 image I added a disabler for this problematic kext. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
CosmoHack Posted September 11, 2013 Share Posted September 11, 2013 Remove /System/Library/Extensions/AppleGraphicsControl.kext/Contents/PlugIns/ApplePolicyControl.kext and add -f to your boot flags. Removed and back to the "PCI Configuration Begin" message again. Â http://Olarila.com/forum/viewtopic.php?f=27&t=1627 You are using 10.8 GM (kernel 12.0.0) and not 10.8.4 (kernel 12.4.0) which this topic is about. In 10.8.4 image I added a disabler for this problematic kext. Facepalm I am going to try with this new kernel to see what happens. Thanks! Quote Link to comment Share on other sites More sharing options...
CosmoHack Posted September 11, 2013 Share Posted September 11, 2013 Yeah! Finally working with this flags: -x -f GraphicsEnabler=No npci=0x2000 The last time I tried only the flag "-f". Go to install to see what happens. Thanks!!! Quote Link to comment Share on other sites More sharing options...
CosmoHack Posted September 12, 2013 Share Posted September 12, 2013 Hello back! I thought it would be better to install 10.8.4 instead of 10.8 and then upgrade, so I downloaded the usb image from this thread. Although I can boot the 10.8 image, I can't boot this new 10.8.4 image. I mean, the boot continues to the existing Windows installation right after POST. Tried this using Suse Image Writer, Win32 Disk Imager and UnetBootin. Any idea? Thanks. P.S: Everything is configured in the BIOS, as the 10.8 USB image boots properly. Quote Link to comment Share on other sites More sharing options...
artur-pt Posted September 12, 2013 Share Posted September 12, 2013 hello when boot from the usb hit 1 and it goes to chameleon use the same boot flags good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
tranduyquang Posted September 13, 2013 Share Posted September 13, 2013 10.8.5 is released. Can anybody make a new installation usb? Quote Link to comment Share on other sites More sharing options...
