cachiputi Posted April 18, 2021 Share Posted April 18, 2021 Hi friends, I have always used Clonezilla, to make my BackUps in Hackintosh. The truth is that Clonezilla has saved my life on many occasions. Now with my new Hackintosh on OS X Big Sur and the SSD in APFS format, I just realized that PartitionClone does not support this partition format. What programs do you use to create your full hard disk BackUps (with all its partitions)? The truth is that I did not expect that Clonezilla did not support this format, I see that any day, due to a bad update or some error, doing the Hackintosh again from scratch. Thanks. Quote Link to comment Share on other sites More sharing options...
anto barreca Posted April 18, 2021 Share Posted April 18, 2021 17 minutes ago, cachiputi said: Hi friends, I have always used Clonezilla, to make my BackUps in Hackintosh. The truth is that Clonezilla has saved my life on many occasions. Now with my new Hackintosh on OS X Big Sur and the SSD in APFS format, I just realized that PartitionClone does not support this partition format. What programs do you use to create your full hard disk BackUps (with all its partitions)? The truth is that I did not expect that Clonezilla did not support this format, I see that any day, due to a bad update or some error, doing the Hackintosh again from scratch. Thanks. I use Carbon Copy Cloner https://bombich.com/it check EFI partition if EFI folder is copied Quote Link to comment Share on other sites More sharing options...
cachiputi Posted April 19, 2021 Author Share Posted April 19, 2021 11 hours ago, anto barreca said: I use Carbon Copy Clonerhttps://bombich.com/it check EFI partition if EFI folder is copied Hello @anto barreca Can you explain step by step what process you use in CCC? It is the 1st time that I will use it and I want the copy to look good. From what little I've seen of CCC, it doesn't create a disk image, does it? just clone it, right? I will have to buy a SSD BackUp. Thanks. Quote Link to comment Share on other sites More sharing options...
cachiputi Posted April 24, 2021 Author Share Posted April 24, 2021 Hello @anto barreca?¿ Quote Link to comment Share on other sites More sharing options...
anto barreca Posted April 24, 2021 Share Posted April 24, 2021 (edited) 3 hours ago, cachiputi said: Hello @anto barreca?¿ Hi but it's that easy, there are so many tutorials on web 🙂 select disk you want clone select destinaton it will probably be asked to initialize it... Copy Edited April 24, 2021 by anto barreca 1 Quote Link to comment Share on other sites More sharing options...
James LIAO Posted November 2, 2022 Share Posted November 2, 2022 clonezilla version 3.0+ has support APFS. Quote Link to comment Share on other sites More sharing options...
