onemanosx Posted November 26, 2019 Author Share Posted November 26, 2019 o gain knowledge, can you explain to me what you did to correct? You did not patch for GPI0 controller. Check in BIOS if you can set trackpad to Advance mode. Added in 4 minutes 49 seconds: Its a SYNA2B3C. I have almost everything running but no Trackpad. Its working but it move and jumping. Remove VoodooI2CHID kext and use VoodooI2CSYNA kext. Set your device name in VoodooI2CSYNA info.plist like in the screenshot https://imgur.com/undefined Added in 12 minutes 55 seconds: Hi! My TrackPad TPD0 not working Use only VoodooI2C and VoodooI2CELAN kext.DSDT.aml.zip Reboot and extract new sendme. Quote Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina) Link to comment Share on other sites More sharing options...
kmbeatz Posted November 26, 2019 Share Posted November 26, 2019 Thank you. No I can't Set the Trackpad Mode in Bios. Its Minimalistic Bios shame on Lenovo Edit: OK I changed the Name in VodoooSynaptics Kext and deleted VoodooI2CHID.kext from SYNA2B33 to SYNA2B3C But the Trackpad is not moving anymore. In Verbose Mode I can see this Lines: pci8086,9d60 Found i2C device : SYNCA2B3C Incompatible APIC Interrupt Pin (0x57 - 0x2f) and no GPIO Interrupts found Quote Link to comment Share on other sites More sharing options...
onemanosx Posted November 26, 2019 Author Share Posted November 26, 2019 Incompatible APIC Interrupt Pin (0x57 - 0x2f) and no GPIO Interrupts found This message suggests that you should try interrupt mode with a valid pin. Quote Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina) Link to comment Share on other sites More sharing options...
kmbeatz Posted November 26, 2019 Share Posted November 26, 2019 Can you help me with that? Its beyond my skills sadly an English is not my main Language Sorry for that Quote Link to comment Share on other sites More sharing options...
onemanosx Posted November 26, 2019 Author Share Posted November 26, 2019 [ref]kmbeatz[/ref], Check if works. If not, extract new sendme after reboot with my DSDT. DSDT.aml.zip Quote Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina) Link to comment Share on other sites More sharing options...
kmbeatz Posted November 26, 2019 Share Posted November 26, 2019 Negativ I tried with VodooCHID.kext and after that with VodooSyna.kext With VodooCHID.Kext Trackpad working Partially and with VodooSyna.kext not working Send me File. http://www.mediafire.com/file/99f8l0e0ido6gki/Send_me_admins-iMac.fritz.box.zip/file Edit: I checked your edited DSDT.aml an saw that that you write SYNA2B33. I that correct? Because I have a SYNA2B3C Device Thank you sooo much sir Quote Link to comment Share on other sites More sharing options...
onemanosx Posted November 26, 2019 Author Share Posted November 26, 2019 [ref]kmbeatz[/ref], I only add the GPI0 pin. Nothing more. I didnt check against your config.plist. Disable XOSI and XDSM patches. I also see from logs that you did load VoodooI2CSYNA kext. You are still using VoodooI2CHID. Try this files. Replace (not merge) clover folder. Reboot. Extract new sendme. https://drive.google.com/file/d/1F5oyburR_OyQm-iZnZZNr-PhQ8YSMt6u/view?usp=sharing Quote Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina) Link to comment Share on other sites More sharing options...
luccasoli Posted November 26, 2019 Share Posted November 26, 2019 Check in BIOS if you can set trackpad to Advance mode. [ref]onemanosx[/ref], I dont have that option in bios =C so wouldn't it really be like me simulating apple's trackpad (with gestures)? Quote Link to comment Share on other sites More sharing options...
kmbeatz Posted November 26, 2019 Share Posted November 26, 2019 [ref]kmbeatz[/ref], I only add the GPI0 pin. Nothing more. I didnt check against your config.plist. Disable XOSI and XDSM patches. I also see from logs that you did load VoodooI2CSYNA kext. You are still using VoodooI2CHID. Try this files. Replace (not merge) clover folder. Reboot. Extract new sendme. https://drive.google.com/file/d/1F5oyburR_OyQm-iZnZZNr-PhQ8YSMt6u/view?usp=sharing Yeeeeeeeees Thank you sooooo much. Its working Perfect o mio. You are the Best. Marked Solved Quote Link to comment Share on other sites More sharing options...
onemanosx Posted November 26, 2019 Author Share Posted November 26, 2019 (edited) Yeeeeeeeees Thank you sooooo much. Its working Perfect o mio. You are the Best. Marked Solved Are you using the files from my Google drive link? Glad I could help. Added in 6 minutes 55 seconds: onemanosx, I dont have that option in bios =C so wouldn't it really be like me simulating apple's trackpad (with gestures)? You would also like to check if there are any BIOS update. If you have Windows installed, you can also verify that I2C device "AUI1667" is detected or some other names? There are cases where ACPI table calls a different name in OSX than in Windows. Is your device having multigesture in Windows though? And trackpad pref will only show with a working Battery Status. Edited November 26, 2019 by Guest Quote Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina) Link to comment Share on other sites More sharing options...
kmbeatz Posted November 26, 2019 Share Posted November 26, 2019 Yes I replace all the files from your Folder with my Clover Folder. Gesture all working Thank you sooo much Sir. Have a nice Day Quote Link to comment Share on other sites More sharing options...
onemanosx Posted November 26, 2019 Author Share Posted November 26, 2019 Yes I replace all the files from your Folder with my Clover Folder. Gesture all working Thank you sooo much Sir. Have a nice Day Enjoy! Your DSDT is fully patched. For brightness hotkeys remapping, read the topic in Useful Links. Quote Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina) Link to comment Share on other sites More sharing options...
luccasoli Posted November 26, 2019 Share Posted November 26, 2019 [ref]onemanosx[/ref], Yes, there was an update on bios, I updated last week (they were just security fixes). I don't have windows installed at this time, but when I was with it, I extracted a DSDT with Windows, do you think this DSDT can help? here: https://drive.google.com/file/d/1MuGg4Ntz88mZU6Q4Qpcu3ySELYizrNag/view?usp=sharing Quote Link to comment Share on other sites More sharing options...
onemanosx Posted November 26, 2019 Author Share Posted November 26, 2019 I don't have windows installed at this time, but when I was with it, I extracted a DSDT with Windows, do you think this DSDT can help? Go through Device Manager in Windows. Quote Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina) Link to comment Share on other sites More sharing options...
nikhilrathore_1999 Posted November 26, 2019 Share Posted November 26, 2019 [ref]nikhilrathore_1999[/ref], ETPD@1 is not a PIN number but instead it is an ACPI ID. This guide is generic for supported I2C trackpad or touchscreen devices Can u see my trackpad details and give me a solution to fix it for working full multigesture supportIMG20191126202423.jpg.zip Quote Link to comment Share on other sites More sharing options...
onemanosx Posted November 26, 2019 Author Share Posted November 26, 2019 [ref]nikhilrathore_1999[/ref], Use VoodooI2C + VoodooI2CFTE kexts Quote Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina) Link to comment Share on other sites More sharing options...
artx.kras Posted November 27, 2019 Share Posted November 27, 2019 You did not patch for GPI0 controller. Check in BIOS if you can set trackpad to Advance mode. Added in 4 minutes 49 seconds: Remove VoodooI2CHID kext and use VoodooI2CSYNA kext. Set your device name in VoodooI2CSYNA info.plist like in the screenshot https://imgur.com/undefined Added in 12 minutes 55 seconds: Use only VoodooI2C and VoodooI2CELAN kext. DSDT.aml.zip Reboot and extract new sendme. it works! Made changes as in your DSDT, and added a GPIO pin 3F, left VoodooI2C.kext, VoodooI2CELAN.kext, VoodooPS2Controller.kext from VoodooPS2Controller.kext removed VoodooPS2Trackpad.kext and VoodooPS2Mouse.kext Now TrackPad works with all standard gestures! Thank you very much for your help, I tried to set it up for 6 months! https://drive.google.com/file/d/18Ic6W2-8ATWgJgXebIs3r7WJDCtEU89D/view?usp=sharing Quote Link to comment Share on other sites More sharing options...
onemanosx Posted November 27, 2019 Author Share Posted November 27, 2019 it works! Made changes as in your DSDT, and added a GPIO pin 3F, left VoodooI2C.kext, VoodooI2CELAN.kext, VoodooPS2Controller.kext from VoodooPS2Controller.kext removed VoodooPS2Trackpad.kext and VoodooPS2Mouse.kext Now TrackPad works with all standard gestures! Thank you very much for your help, I tried to set it up for 6 months! I guess, its worth the 6 months of effort! Enjoy the amazing multigestures! You may remove XOSI-SSDT and XOSI patch in clover as the DSDT has windows emulation implemented. Quote Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina) Link to comment Share on other sites More sharing options...
artx.kras Posted December 1, 2019 Share Posted December 1, 2019 I guess, its worth the 6 months of effort! Enjoy the amazing multigestures! You may remove XOSI-SSDT and XOSI patch in clover as the DSDT has windows emulation implemented. Thank you, delete! Quote Link to comment Share on other sites More sharing options...
onemanosx Posted December 1, 2019 Author Share Posted December 1, 2019 Thank you, delete! Quote Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina) Link to comment Share on other sites More sharing options...
artx.kras Posted December 1, 2019 Share Posted December 1, 2019 tell me where to read about sleep mode in which branch? I have a black screen after getting out of sleep, it wakes up, but the graphical shell freezes while USB, BlueTooth, Muose, keyboard work. My Send Me: https://drive.google.com/open?id=1y8Dcy1Q8IQ4wcc7qFyArVOB7dlI1tcwt Quote Link to comment Share on other sites More sharing options...
aryaone Posted December 6, 2019 Share Posted December 6, 2019 [ref]onemanosx[/ref], i tried to patch my DSDT as per your tutorial to make my i2c work, but when i try to follow your guide and delete the following: In this case, rename SBFI to SBFB and remove the following from it: CODE: SELECT ALL Interrupt (ResourceConsumer, Level, ActiveLow, Exclusive, ,, ) { 0x0000006D, } my trackpad still not detected (my APIC PIN is 47, so i think i dont need to pin it manually) please help me, here is my send_me file, and the patched dsdt.dsl https://drive.google.com/file/d/1n0yXgtKBPiNuSXBRNBz-StZUdi3JfKQN/view?usp=sharing DSDT.dsl.zip Quote Link to comment Share on other sites More sharing options...
onemanosx Posted December 6, 2019 Author Share Posted December 6, 2019 [ref]aryaone[/ref], Use VoodooI2C + VoodooI2CELAN kexts. You are correct, APIC PIN less than or equals to 47 requires no manual pinning. Quote Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina) Link to comment Share on other sites More sharing options...
m0ustafamahm0ud Posted December 6, 2019 Share Posted December 6, 2019 thank you sir for this great work i did as you did sir and tried so many times but it does not work Lenovo Ideapad L340-15IWL i7 8565U / UHD620 in windows shows me this \.SB.PCI0.I2C0.TPD0 and its IOInterruptSpecifiers is <6e 00 00 00 03 00 00 00> please help me sir to make it works and thank you again and again my files : http://s000.tinyupload.com/download.php?file_id=78849194813668178275&t=7884919481366817827553303 Quote Link to comment Share on other sites More sharing options...
onemanosx Posted December 7, 2019 Author Share Posted December 7, 2019 [ref]m0ustafamahm0ud[/ref], 1. Remove SSDT-XOSI 2. Remove OSI to XOSI rename in clover 3. Remove SSDT-ALS0 4. Remove SSDT-PNLF 5. Remove SSDT - PNLFCFL 6. Remove SSDT-XCPM Replace DSDT. Reboot. Extract new sendme. DSDT.aml.zip Quote Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina) Link to comment Share on other sites More sharing options...
