prajjwal12 Posted March 12, 2021 Share Posted March 12, 2021 hey , I am having trouble installing new powercolor rx550 4gb(lexa) i tried fakeid: 0x67FF1002 please help !!!! a320h motherboard 3200g 16gb config.rar ethernet and audio : also works alternative if audio works then ethernet won't gigabyte a320h.s2h motherboard config.rar Quote Link to comment Share on other sites More sharing options...
anto barreca Posted March 12, 2021 Share Posted March 12, 2021 (edited) 1 hour ago, prajjwal12 said: hey , I am having trouble installing new powercolor rx550 4gb(lexa) i tried fakeid: 0x67FF1002 please help !!!! a320h motherboard 3200g 16gb config.rar ethernet and audio : also works alternative if audio works then ethernet won't gigabyte a320h.s2h motherboard config.rar 5.97 kB · 0 downloads Try Gfxutil. The latter, launched from a terminal window, with the -f display option, then "gfxutil -f display", should show the GPU device to insert in the plist https://imgur.com/gallery/FRu8xBp Edited March 12, 2021 by anto barreca Quote Link to comment Share on other sites More sharing options...
prajjwal12 Posted March 14, 2021 Author Share Posted March 14, 2021 On 3/12/2021 at 11:39 PM, anto barreca said: Try Gfxutil. The latter, launched from a terminal window, with the -f display option, then "gfxutil -f display", should show the GPU device to insert in the plist https://imgur.com/gallery/FRu8xBp Thanks man!!! Works thanks for your help !!! Please can you help me with one more issue... I have motherboard a320m which has a combined socket for audio n Ethernet so every time I am appleAlc.kext audio works and when I m using only realtekrtl8111.kext ethernet works and when I am using both only audio works .. please help!! 1 Quote Link to comment Share on other sites More sharing options...
anto barreca Posted March 14, 2021 Share Posted March 14, 2021 12 minutes ago, prajjwal12 said: Thanks man!!! Works thanks for your help !!! Please can you help me with one more issue... I have motherboard a320m which has a combined socket for audio n Ethernet so every time I am appleAlc.kext audio works and when I m using only realtekrtl8111.kext ethernet works and when I am using both only audio works .. please help!! You are welcome imagine happy to have helped you, for the audio have you tried to change the layout? I'll look around 😜 Quote Link to comment Share on other sites More sharing options...
prajjwal12 Posted March 15, 2021 Author Share Posted March 15, 2021 (edited) Boot-args: -v alcid=1 npci=0x2000 shikigva=128 watchdog=0 -no_compat_check (by default) I tried this boot-args: acid=1 ncpi=0x2000 audio is working but it's too much glitchy but no ethernet Edited March 15, 2021 by prajjwal12 Quote Link to comment Share on other sites More sharing options...
