Yosa Tristian Posted November 18, 2020 Share Posted November 18, 2020 Hi, @MaLd0n My device is Acer Aspire 5 A514-51KG-36UX i3-7020u, Intel HD 620, 8GB RAM, 1 TB WDC HDD Split for Windows (C:/ D:/ E:/) and MacOS (Dual Boot) I don't know how to fix it. Sometimes my partition not appear at all. In macOS (Finder) some time only D:/ some time only C:/ incloude EFI Partition. I try to mount in Disk Utility it can't. When im using Catalina, HDD is work 100%. Now I can not edit EFI system and config.plist please help me, big thanks Quote Link to comment Share on other sites More sharing options...
adhitore Posted November 18, 2020 Share Posted November 18, 2020 5 hours ago, Yosa Tristian said: Hi, @MaLd0n My device is Acer Aspire 5 A514-51KG-36UX i3-7020u, Intel HD 620, 8GB RAM, 1 TB WDC HDD Split for Windows (C:/ D:/ E:/) and MacOS (Dual Boot) I don't know how to fix it. Sometimes my partition not appear at all. In macOS (Finder) some time only D:/ some time only C:/ incloude EFI Partition. I try to mount in Disk Utility it can't. When im using Catalina, HDD is work 100%. Now I can not edit EFI system and config.plist please help me, big thanks did you install catalinasata kext provided from opencore guide? Quote Link to comment Share on other sites More sharing options...
lukakeiton Posted November 18, 2020 Share Posted November 18, 2020 I had same error. Create SSDT for your HDD/SSD and add to EFI and config.plist Quote AMD Ryzen 9 3900X ASUS ROG STRIX X570-E GAMING Sapphire Nitro+ Radeon RX 590 8GB CORSAIR Vengeance LPX 32GB DDR4 3600Mhz Link to comment Share on other sites More sharing options...
