Lion installation via USB stick using Chameleon
Hi
I've got a problem with both Extra and chamaleon install: I can't change Install Location.
The first time, in 1st step, I press "Continue" button it jump to "Type of installation" (From 1st step to 3rd one directly), I press "Continue"; then appears "Change Install Location" Button; I press it and I enter in a loop returning to 1st step and when I press again "Continue" Button I return to step with "Change Install Location" Button and again 1st step and again change ... ad infinitum ;-). Of course if I don't press "Change Install Location" Button and press "Install" they are installed on the running system.
As I said before I've got the same problem with both Extra Lion and chameleon.
I'm trying to do the Lion installation USB stick on a computer with Mac OSX Leopard on VirtualBox on W7.
Thanks in advance for your help
ok solved. i had to install snow leopard. extra and chamaleon installs don't work with leopard.
Link to comment
Share on other sites
ExtraLionDP4 não me deixa instalar o "usb leão". A opção "Escolha o destino"
Eu não posso mudar, é como se essa opção não está ativada. Qualquer ajuda? Obrigado.
ExtraLionDP4 not let me install the "usb lion". The option "Select destination"
I can not change, it is as if this option is not enabled. Any help? Thank you.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Hey! Welcome to Olarila.com  Please Disable Your ADBlocker!
Support Olarila Vanilla Hackintosh by making a donation HERE
The popup will be closed in 15 seconds...
