ugooh Posted July 17, 2011 Share Posted July 17, 2011 Hi this is as far as i get no matter what i do. please help. Quote Link to comment Share on other sites More sharing options...
oldnapalm Posted July 18, 2011 Share Posted July 18, 2011 Have you tried this? http://www.insanelymac.com/forum/index.php?showtopic=261819 Quote Link to comment Share on other sites More sharing options...
ugooh Posted July 19, 2011 Share Posted July 19, 2011 Have you tried this?http://www.insanelymac.com/forum/index.php?showtopic=261819 Yes same result. Quote Link to comment Share on other sites More sharing options...
AKZam Posted July 19, 2011 Share Posted July 19, 2011 Yes same result. Â I have a similar result also (either gets stuck at waiting for DSMOS, DSMOS has arrived), or it progresses past this and the screen goes black with nothing happening. What hardware are you trying on ugooh? Wondering if this is a Sandy Bridge thing. Quote Link to comment Share on other sites More sharing options...
ugooh Posted July 19, 2011 Share Posted July 19, 2011 I have a similar result also (either gets stuck at waiting for DSMOS, DSMOS has arrived), or it progresses past this and the screen goes black with nothing happening. What hardware are you trying on ugooh? Wondering if this is a Sandy Bridge thing.  Hi AKZam my Sony Vaio VPCEB12FX spec in brief Motherboard: CPU Type DualCore Intel Core i3-330M, 2133 MHz (16 x 133) Motherboard Name Sony VPC-EB12FX Motherboard Chipset Intel Ibex Peak-M HM55, Intel Ironlake-M System Memory 3760 MB (DDR3-1066 DDR3 SDRAM) DIMM1: Power Quotient MFCBG423PA0102 2 GB DDR3-1066 DDR3 SDRAM (7-7-7-20 @ 533 MHz) (6-6-6-18 @ 457 MHz) DIMM3: Power Quotient MFCBG423PA0102 2 GB DDR3-1066 DDR3 SDRAM (7-7-7-20 @ 533 MHz) (6-6-6-18 @ 457 MHz) BIOS Type AMI (09/23/09) Display: Video Adapter Intel® Graphics Media Accelerator HD (1793074 KB) Video Adapter Intel® Graphics Media Accelerator HD (1793074 KB) 3D Accelerator Intel GMA HD Monitor Generic PnP Monitor [NoDB] (12007) Multimedia Audio Adapter Intel Ibex Peak HDMI @ Intel Ibex Peak PCH - High Definition Audio Controller [b-2] Audio Adapter Realtek ALC269 @ Intel Ibex Peak PCH - High Definition Audio Controller [b-2] Storage: IDE Controller Intel® 5 Series 4 Port SATA AHCI Controller IDE Controller Ricoh PCIe Memory Stick Host Controller IDE Controller Ricoh PCIe SD Bus Host Adapter Disk Drive Ricoh Memory Stick Disk Device Disk Drive Ricoh SD/MMC Disk Device Disk Drive ST9500325AS (500 GB, 5400 RPM, SATA-II) Optical Drive Optiarc DVD RW AD-7585H Thanks for your concern and looking forward to making it work with your assisstance. Quote Link to comment Share on other sites More sharing options...
S_Coaster Posted August 2, 2011 Share Posted August 2, 2011 I followed the procedure and i boot from the usb key, it loads all the kexts, and then it hangs/stops where the image is showing. (PCI Configuration Begin..) I tried newer chameleon versions than the ones u recommended the same thing happens, also my BIOS resets everytime i reach that point. Any ideas on how this could be fixed? specs: Mobo: Gigabyte ex58-UD4 CPU: Intel Core i7 940 GPU: Gigabyte GTX560Ti OC 1GB 6 gig of ram Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 2, 2011 Author Administrators Share Posted August 2, 2011 I followed the procedure and i boot from the usb key, it loads all the kexts, and then it hangs/stops where the image is showing. (PCI Configuration Begin..) I tried newer chameleon versions than the ones u recommended the same thing happens, also my BIOS resets everytime i reach that point. Any ideas on how this could be fixed? specs: Mobo: Gigabyte ex58-UD4 CPU: Intel Core i7 940 GPU: Gigabyte GTX560Ti OC 1GB 6 gig of ram npci=0x2000? Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
S_Coaster Posted August 2, 2011 Share Posted August 2, 2011 npci=0x2000? Â i have no idea what that means..... u mean typethat in the bootloader before i initiate install? Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 2, 2011 Author Administrators Share Posted August 2, 2011 i have no idea what that means..... u mean typethat in the bootloader before i initiate install? Yes Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
S_Coaster Posted August 2, 2011 Share Posted August 2, 2011 trying it in 20 mins, thank you very much for your swift reply...i will update as soon as i try it! Quote Link to comment Share on other sites More sharing options...
S_Coaster Posted August 2, 2011 Share Posted August 2, 2011 ok, it worked, thus the installation moved forward, i then got a grey screen with the "beachball" spinning on the top left, and then i got a kernel panic because "no HPETs were found..." I fiddled with my bios settings, tried with both HPET ON @ 32BIT, again @ 64bit and again with HPET completely disabled. still get the same error... do you recommend a different bootloader? error: "No HPETs available...CPU(S) configured incorrectly thank you for your time. Quote Link to comment Share on other sites More sharing options...
S_Coaster Posted August 2, 2011 Share Posted August 2, 2011 ok, it worked, thus the installation moved forward, i then got a grey screen with the "beachball" spinning on the top left, and then i got a kernel panic because "no HPETs were found..." I fiddled with my bios settings, tried with both HPET ON @ 32BIT, again @ 64bit and again with HPET completely disabled. still get the same error... do you recommend a different bootloader? error: "No HPETs available...CPU(S) configured incorrectly thank you for your time. Â I also tried forceHPET=Yes, still no luck, AppleIntelCPUPowerManagement.kext is becoming a pain in the a** Ok, if i remove that kext along with it's AppleIntelCPUPowerManagementClient.kext, will i be able to move on with the installation? if not, is there a workaround? again, thnx Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 2, 2011 Author Administrators Share Posted August 2, 2011 do you use Auto-Patcher? Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
S_Coaster Posted August 2, 2011 Share Posted August 2, 2011 i followed the instructions on the tutorial, meaning i restored the image, copied the contents of "packages" over, installed "EXTRA LION DP4" and then "chameleon" on the target usb. i did not use "Auto Patcher". I tried ForceHPET=Yes but no luck there either (i typed that flag right after the one u gave me for pci, so it looked like "npci=0x2000 ForceHPET=Yes" Other than installing a newer version of chameleon because the versions u attached to your tutorial, when installed on my usb stick, wont even let the computer move from POST, it hangs the entire system as soon as i plug it in (i found a couple of chameleon ver. with the brazilian flag from kexts.com aswell, they all have the same effect, any other version works fine and boots) what's auto patcher? will it help? picture follows: Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 22, 2011 Author Administrators Share Posted August 22, 2011 enable HPET in bios setup Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
rexmale Posted August 31, 2011 Share Posted August 31, 2011 Hi, I've tried your method, but my laptop won't boot from the USB stick. My laptop specs like this : Lenovo Thinkpad Edge E420 1141-7UA, Intel® Core™ i5-2410M (2.3GHz turbo boost up to 2.9GHz, 3MB L2 Cache), Intel® HD 3000 Graphics, RAM 2GB DDR3, HDD 750GB, Intel® Wireless 802.11b/g/n It's a sandy bridge, is your method works on sandy bridge? Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 31, 2011 Author Administrators Share Posted August 31, 2011 It's a sandy bridge, is your method works on sandy bridge? yes post a photo Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
robinson37 Posted September 1, 2011 Share Posted September 1, 2011 he ehcho el metodo pero no consigo instalar se reinicia la pc en cuanquier modo de boot caracteristicas Board dh67bl+i5+ati hd5670+4ram no se que pasa gracias Quote Link to comment Share on other sites More sharing options...
rexmale Posted September 1, 2011 Share Posted September 1, 2011 yes post a photo Nothing happens as my laptop wont boot from that USB stick. I have successfully install Lion on VMWare Workstation and run Software Update to update to 10.7.1 (11B26) Quote Link to comment Share on other sites More sharing options...
destr0 Posted September 5, 2011 Share Posted September 5, 2011 Mald0n, I'm getting an error with my kernel panic. I have the same laptop as Anerik70, and its the lapic.c kernel. Can you check my thread below this? (How to install Lion GM on HP DV7 4269WM) Quote Link to comment Share on other sites More sharing options...
jamesraikikon Posted September 14, 2011 Share Posted September 14, 2011 help help i had sony viao with vpceb34en model number having i3 2.40 and 5470 512 after i had made the installation disk i got the error as pci configuration begin and then used npci=0x2000 but does not works then i used 10.6.7 kexts as iopcifamily and apple acpi kexts but after wards i got the achi error unable to take control from bios since bios does not have advance configuration so i need to use the dsdt but cat make it due to compilation error plz help......................... dsdt and dsdt.dsl.zip Quote Link to comment Share on other sites More sharing options...
Cassio Posted September 14, 2011 Share Posted September 14, 2011 http://Olarila.com/forum/viewtopic.php?f=19&t=452 Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
kext755 Posted September 26, 2011 Share Posted September 26, 2011 Hi I had a problem here: "Run the installers "Extra Lion" and "Chameleon RC5". Â ... Run the installers "Extra Lion" and "Chameleon". Remember to click on Change Install Location... and select the USB drive as destination, or they will be installed on the running system. With the installer USB ready, boot it and install Lion to an HD partition. Â Â I didn't install "Extra Lion" , just Chameleon 2.1 r1544.pkg. After I restarted there is an error booting (error 3F which is a "reserved" error). I see the BIOS splash screen but everything is locked. So is there anything to configure in the BIOS or hardware so Chameleon can boot? I set the SATA Mode to ACHI, anything else? - 1 memory stick? - HPET Mode - 64-bit mode? - ACPI Power mode: Set it to S3(STR) This is the first time I try using Chameleon and I've read a lot but maybe I missed something? Quote MB: DFI LanParty UT x58 (BIOS LX58D429) CPU: Intel Core i7-930 GFX: ATI Radeon HD6870 1GB, PCIex16 slot3 nVidia GF 9800GT passive(for testing) Memory: 3x4GB Corsair Dominator (model CMP12GX3M3A1600C9) HDD: Mushkin SSD DVD: Optiarc DVD RW AD-7203S Link to comment Share on other sites More sharing options...
Term_s Posted October 1, 2011 Share Posted October 1, 2011 thank you for this guide maldon, its working very nice. Quote Link to comment Share on other sites More sharing options...
Jedispara Posted December 1, 2011 Share Posted December 1, 2011 Just out of curiosity, does this work with a 10.7.2 installer from the app store. More importantly, does the "Extra Lion" work with this version of the installer. Quote Link to comment Share on other sites More sharing options...
