btd684 Posted December 16, 2023 Share Posted December 16, 2023 Hi Friends, i have need help to install a new release of open core and new macos sonoma system for my hp laptop. can anyone help me with the installation? i'm current having some trouble (will list at the end of this) Hardware: Hp envy 13 ah-0051wm bios version: Insyde f32 Processor Name: Intel Core i5-8250U KabyLake R (idk what efi version should I choose since it's between the 7th and 8th gen, tried efi for kabylake but it shows a X on boot, while coffelake efi gave me a bunch of text but i cant scroll up but it's likely to be an error with cpu) Intel UHD Graphics 620 Drive Model: WDC PC SN520 SDAPNUW-256G-1006 Network Card: Intel Wireless-AC 9260 160MHz Please let me know if it's supported or not, which efi folder to use or even a customized efi would be nice. and also, I watched a video on youtube says that I have to use a tool named GenSMBIOS to get a serial code and machine model, which is not mentioned in oralia's installation guide(which only show that I have to flash the os image then replace the efi file, it said that i have to get a working serial at the beginning but not mentioned at which step). Thanks. Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted December 16, 2023 Administrators Share Posted December 16, 2023 -NoteBook KabyLake Download HERE -Bios/UEFI in full default settings(CSM to Disable with AMD GPU - Sata to Ahci - Secure Boot Disable on mobiles) -Delete old EFI folder and paste new. Don't use merge files -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead -Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill [email protected] BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @[email protected] Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
btd684 Posted December 16, 2023 Author Share Posted December 16, 2023 Just now, MaLd0n said: -NoteBook KabyLake Download HERE -Bios/UEFI in full default settings(CSM to Disable with AMD GPU - Sata to Ahci - Secure Boot Disable on mobiles) -Delete old EFI folder and paste new. Don't use merge files -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead -Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen sorry but do I have to reflash the OS image after getting the wrong efi folder? also is there some "limit" about a certain types/ brand of usb drive? if there is then I think I have to switch to another flash drive will a sd card with a usb2.0 sd card reader work since i'm lazy to remap my usb 3.0 drive Quote Link to comment Share on other sites More sharing options...
btd684 Posted December 17, 2023 Author Share Posted December 17, 2023 21 hours ago, MaLd0n said: -NoteBook KabyLake Download HERE -Bios/UEFI in full default settings(CSM to Disable with AMD GPU - Sata to Ahci - Secure Boot Disable on mobiles) -Delete old EFI folder and paste new. Don't use merge files -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead -Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen ty it worked for ventura but not sonoma Quote Link to comment Share on other sites More sharing options...
Join the conversation
