zukulento Posted September 23, 2023 Share Posted September 23, 2023 I've installed Ventura in my SB2, but the CPU is always running high and that overheat the laptop. Usually it sits at 39°-45°, but now with the kernel task running that high temps stay at 60°+. Image showing the Activity monitor and "Top" command in the terminal I read somewhere that the cause could be a kext or ACPI that shouldn't be there, so i booted with the minimun. I tried: Boot with no files in the ACPI and only lilu, whatevergreen and VirtualSMC. Boot with only an ACPI at a time. Install Bigsurface kext. CpuFriend and CPUFriendDataProvider. Disabled backlight and audio. Also i first installed using the olarila ISO and EFI folder had the same problem. Tried using my own EFI folder and had the same problem. The installed thru the dortania guide and the same thing. Nothing of that worked Help pls Surface book 2 13.5" I7 8650U Gtx 1050TI The EFI only has the bare minimun to boot with GA. https://www.dropbox.com/scl/fi/w112pq5msttdb20lbht25/Booting-EFI-SURFACE-BOOK-2.rar?rlkey=qenrtdfxe0hocn3ab9n1os57u&dl=0 Booting EFI SURFACE BOOK 2.rar Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted September 23, 2023 Administrators Share Posted September 23, 2023 update things, remove some unnecesasary and check if work https://www.transfernow.net/dl/20230923C8xtgTd2 Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill [email protected] BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @[email protected] Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
zukulento Posted September 25, 2023 Author Share Posted September 25, 2023 On 9/23/2023 at 8:09 AM, MaLd0n said: update things, remove some unnecesasary and check if work https://www.transfernow.net/dl/20230923C8xtgTd2 Hey! I tried but its the same thing. I have a DSDT file, the thing with that is that it gives me this "ACPI Error". I was advice that i should delete the entry that gives me error, but i dont know how. Here is the EFI with that DSDT file. https://www.dropbox.com/scl/fi/tlck3y2dvlru4i4zk7r4o/EFI.rar Quote Link to comment Share on other sites More sharing options...
zukulento Posted September 25, 2023 Author Share Posted September 25, 2023 I fix the issue. It was a problem with the LID sensor. Im going to to a little guide and post it here Quote Link to comment Share on other sites More sharing options...
