Jadyn Dutko Posted September 6, 2022 Share Posted September 6, 2022 I'm trying to install macOS monterey (I have used the correct EFI folder and replaced the default one according to different guides on this site), and the installer will boot and I can control it. I cannot get my internal SSD to show up when it's time to select what drive to install macOS on. I don't want to wipe the drive as I have Windows installed on it, so I was hoping I could do some kind of jank dual-boot (with Windows being the priority boot option and having macOS accessible in the BIOS). I partitioned the drive and encrypted the Windows side of things, and allocated space for macOS and left it unencrypted, but no matter what I do, I can't get it to show up in Disk Utility. In case you were wondering, my system specs are: CPU: Intel Core i7-1165G7 GPU: Intel Iris Xe Graphics (TigerLake) RAM: 16GB DDR4 3200MHz (soldered) SSD: 512GB Intel 660p (partitioned and part-encrypted) Manufacturer: Asus Any help at all would be appreciated! Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted September 6, 2022 Administrators Share Posted September 6, 2022 u need format ur ssd and use guid and apfs Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill [email protected] BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @[email protected] Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Jadyn Dutko Posted September 7, 2022 Author Share Posted September 7, 2022 (edited) 18 hours ago, MaLd0n said: u need format ur ssd and use guid and apfs My SSD is already using GPT, but I also want to keep my Windows installation intact as is, is there any way to format the partition as APFS on Windows and have MacOS be happy with it? Edited September 7, 2022 by Jadyn Dutko typo Quote Link to comment Share on other sites More sharing options...
AppleIIGuy Posted September 9, 2022 Share Posted September 9, 2022 I would suggest buying a second ssd. install os x on that. Quote Remember Always have a tested working backup before you try anything. Asrock Z590 pro4 i7-11700KF 32 Gb Rx 5600XT 8GB Link to comment Share on other sites More sharing options...
Jadyn Dutko Posted September 10, 2022 Author Share Posted September 10, 2022 I wiped my SSD completely and it's simply not showing up in Disk Utility. I did make a Windows bootdisk and a backup so I can restore everything, but this has been very frustrating. Is there an issue with PCIe 3.0 NVMe drives on TigerLake? Quote Link to comment Share on other sites More sharing options...
jcb2016 Posted September 19, 2022 Share Posted September 19, 2022 I wiped my SSD completely and it's simply not showing up in Disk Utility. I did make a Windows bootdisk and a backup so I can restore everything, but this has been very frustrating. Is there an issue with PCIe 3.0 NVMe drives on TigerLake?Did you ever fix this? I'm coming back into the hackintosh world after years off being gone. You have similar specs as me but I'm using a hp envy x360 literally same. Did you ever get Monterey to detect your SSD? In know it's a nvme ?ThanksSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted September 20, 2022 Administrators Share Posted September 20, 2022 try this kext SATA-unsupported.kext.zip Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill [email protected] BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @[email protected] Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Maanav Parmar Posted September 24, 2022 Share Posted September 24, 2022 Just a quick question, which EFI Folder did you use for your Tiger Lake device? Quote Link to comment Share on other sites More sharing options...
Jadyn Dutko Posted October 4, 2022 Author Share Posted October 4, 2022 On 9/24/2022 at 11:54 AM, Maanav Parmar said: Just a quick question, which EFI Folder did you use for your Tiger Lake device? The Notebook TigerLake EFI folder. On 9/20/2022 at 3:37 AM, jcb2016 said: Did you ever fix this? I'm coming back into the hackintosh world after years off being gone. You have similar specs as me but I'm using a hp envy x360 literally same. Did you ever get Monterey to detect your SSD? In know it's a nvme ? Thanks Sent from my iPhone using Tapatalk I never got it working, haven't checked this forum for a while. I'll try the kext that Maldon sent and let you know how that goes. If it helps narrow anything down, this behavior is exhibited in the Windows installer too, even when booting off of a USB flashed by Windows' Media Creation Tool. Quote Link to comment Share on other sites More sharing options...
Arpan Posted October 13, 2022 Share Posted October 13, 2022 go to setup menu on bios and go to advance  mode by pressing f7 and the after that a menu appears and the go to advance option under advance option choose Advance\VMD setup menu under that disable that just Done ; trust me bro it works and I have done exact same method because Asus has latest bios so we have to gone through all of this bullshit   1 Quote Link to comment Share on other sites More sharing options...
atul pandey Posted February 20 Share Posted February 20 On 10/13/2022 at 10:58 PM, Arpan said: go to setup menu on bios and go to advance  mode by pressing f7 and the after that a menu appears and the go to advance option under advance option choose Advance\VMD setup menu under that disable that just Done ; trust me bro it works and I have done exact same method because Asus has latest bios so we have to gone through all of this bullshit  Bro you have saved me from throwing my laptop in trash I was trying to fix this fu**** is from last 11 hours i bought a new 1 tb SSD to just install it . By the way after disabling vdm now my windows is crashing. But still a big thanks to you bro 😄 Quote Link to comment Share on other sites More sharing options...
Join the conversation
