René Rhéaume Posted August 3, 2022 Share Posted August 3, 2022 Hello, I installed macOS Big Sur 11.6.8 on a Lenovo Thinkcentre M93p Tiny (about the same physical size as a Mac Mini) having its stock Core i5-4570T CPU only Intel HD 4600 integrated graphics in Firmware settings, minimum VRAM is set to 64MB and limit is set to Maximum. Also, VT-d is disabled. and 3 display outputs : VGA, HDMI and DisplayPort For macOS installation, I used the Haswell Notebook (the Desktop variant crashes) EFI folder from this site for my installer USB key, then added the -igfxvesa boot-arg to its OpenCore config.plist . After installation, I was able to make it bootable without the USB key. However, graphics acceleration is disabled, making any software having Chromium-based code, such Google Chrome, Microsoft Edge and Visual Studio Code, unusable. On VGA, I am limited to a 1280x1024 resolution, and removing the -igfxvesa option changes nothing (same limitations as before, but no worsening) About This Mac reports Intel HD 4600 Graphics with only 5 MB of VRAM I read on other forums you must not use VGA output for this hardware on macOS. So I stopped using it. On HDMI, I can go up to 1920x1200 (yes, that's an older 27" 16:10 monitor), but still no acceleration About This Mac reports Intel HD 4600 Graphics with 8 MB of VRAM The above mentionned apps are still unusable. I have not tried DisplayPort yet as I must get a DisplayPort cable. My questions are : Can I get graphics acceleration with the HDMI output? How do I enable graphics acceleration? No problem with purchasing a DisplayPort cable. Thank you in advance. Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 3, 2022 Administrators Share Posted August 3, 2022 U can test little video patch with platform id 0300220D and device-id 12040000 for example Quote <key>PciRoot(0x0)/Pci(0x2,0x0)</key> <dict> <key>AAPL,ig-platform-id</key> <data>AwAiDQ==</data> <key>device-id</key> <data>EgQAAA==</data> <key>framebuffer-fbmem</key> <data>AAAAAw==</data> <key>framebuffer-patch-enable</key> <data>AQAAAA==</data> <key>framebuffer-stolenmem</key> <data>AAAABA==</data> </dict> Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
René Rhéaume Posted August 4, 2022 Author Share Posted August 4, 2022 (edited) I tried the patch and I get the same result as before. That is, using the HDMI output. Edited August 4, 2022 by René Rhéaume Adding a precision Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 4, 2022 Administrators Share Posted August 4, 2022 Read in link bellow https://github.com/acidanthera/WhateverGreen/blob/master/Manual/FAQ.IntelHD.en.md Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
datafeedexpert Posted August 4, 2022 Share Posted August 4, 2022 On 8/4/2022 at 12:09 AM, René Rhéaume said: Hello, I installed macOS Big Sur 11.6.8 on a Lenovo Thinkcentre M93p Tiny (about the same physical size as a Mac Mini) having its stock Core i5-4570T CPU only Intel HD 4600 integrated graphics in Firmware settings, minimum VRAM is set to 64MB and limit is set to Maximum. Also, VT-d is disabled. and 3 display outputs : VGA, HDMI and DisplayPort For macOS installation, I used the Haswell Notebook (the Desktop variant crashes) EFI folder from this site for my installer USB key, then added the -igfxvesa boot-arg to its OpenCore config.plist . After installation, I was able to make it bootable without the USB key. However, graphics acceleration is disabled, making any software having Chromium-based code, such Google Chrome, Microsoft Edge and Visual Studio Code, unusable. On VGA, I am limited to a 1280x1024 resolution, and removing the -igfxvesa option changes nothing (same limitations as before, but no worsening) About This Mac reports Intel HD 4600 Graphics with only 5 MB of VRAM I read on other forums you must not use VGA output for this hardware on macOS. So I stopped using it. On HDMI, I can go up to 1920x1200 (yes, that's an older 27" 16:10 monitor), but still no acceleration About This Mac reports Intel HD 4600 Graphics with 8 MB of VRAM The above mentionned apps are still unusable. I have not tried DisplayPort yet as I must get a DisplayPort cable. My questions are : Can I get graphics acceleration with the HDMI output? How do I enable graphics acceleration? No problem with purchasing a DisplayPort cable. Thank you in advance. Use this Properties for Your Display HD 4600 <key>PciRoot(0x0)/Pci(0x2,0x0)</key> <dict> <key>AAPL,ig-platform-id</key> <data>AwAiDQ==</data> <key>AAPL,slot-name</key> <string>Internal@0,2,0</string> <key>device-id</key> <data>EgQAAA==</data> <key>device_type</key> <string>VGA compatible controller</string> <key>enable-hdmi20</key> <data>AQAAAA==</data> <key>framebuffer-con0-enable</key> <data>AQAAAA==</data> <key>framebuffer-con0-type</key> <data>AAgAAA==</data> <key>framebuffer-con1-enable</key> <data>AQAAAA==</data> <key>framebuffer-con1-type</key> <data>AAgAAA==</data> <key>framebuffer-con2-enable</key> <data>AQAAAA==</data> <key>framebuffer-con2-type</key> <data>AAgAAA==</data> <key>framebuffer-fbmem</key> <data>AACQAA==</data> <key>framebuffer-patch-enable</key> <data>AQAAAA==</data> <key>framebuffer-stolenmem</key> <data>AAAwAQ==</data> <key>framebuffer-unifiedmem</key> <data>AAAAgA==</data> </dict> 1 Quote Link to comment Share on other sites More sharing options...
René Rhéaume Posted August 5, 2022 Author Share Posted August 5, 2022 Using a DisplayPort cable instead of an HDMI one changed nothing Unfortunately, what datafeedexpert posted did not improve the situation. Looking the WhateverGreen Intel FAQ, there is a line about STOLEN memory. Where and when this line is outputted to the console? I can't see it. Quote Link to comment Share on other sites More sharing options...
René Rhéaume Posted September 5, 2022 Author Share Posted September 5, 2022 OK, the problem was I was editing the wrong config.plist, i.e. not the one effectively used by OpenCore. When I understood that, I simply had to change the platform ID in the config.plist file inside the hidden ESP partition that I mounted with ESP Mounter Pro. Thanks nevertheless. Quote Link to comment Share on other sites More sharing options...
