linusrg Posted December 19, 2021 Share Posted December 19, 2021 I am attempting to boot the Big sur precompiled iso on my legacy laptop with a sandy bridge cpu. I am assuming this is because the iso is made for uefi systems. Would it be possible to get it to boot on a legacy system? (Yes ik big Sur doesn't have ogpu support for that chip but I have a way that I am gonna use to try and fix that)Â Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted December 19, 2021 Administrators Share Posted December 19, 2021 https://www.olarila.com/topic/20908-guide-easy-fast-and-perfect-hackintosh-vanilla-step-by-step-clover-and-opencore-bootloader/ Clover and Opencore have support for legacy systems Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill [email protected] BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @[email protected] Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
dnakruemel Posted December 19, 2021 Share Posted December 19, 2021 pretty sure sandy bridge already had uefi support, i could have a look on ur device firmware if you post the notebook model number Quote Link to comment Share on other sites More sharing options...
linusrg Posted December 20, 2021 Author Share Posted December 20, 2021 2 hours ago, dnakruemel said: pretty sure sandy bridge already had uefi support, i could have a look on ur device firmware if you post the notebook model number sure it is the the protege r830 from Toshiba. I also found out the other stuff I had to do and I did copy the sandy bridge folder over, but the laptop still refuses to boot the usb. Quote Link to comment Share on other sites More sharing options...
dnakruemel Posted December 20, 2021 Share Posted December 20, 2021 So u need to check your laptop setup. If using Legacy OpenCore, use CSM, otherwise turn it off. Some Chipsets have an "UEFI Mode" option, mine can switch from "Windows EFI" to "Other OS"; MacOS will NOT boot with Windows EFI mode. Boot from USB2-Port. Also, if u had windows installed, id clear the secure-boot-keys, but beware, youll get boot issues in windows if you do this! Â Could you specify more on the state of error? Are you able to select your flashed USB drive to boot or does it not even pop up? Can you verify USB is bootable in another system? (dont need to install there) Quote Link to comment Share on other sites More sharing options...
linusrg Posted December 20, 2021 Author Share Posted December 20, 2021             The USB will boot in another PC. Secondly, where do I get or enable csm. 3rdly the laptop sees the USB it    just can't    boot From it. Quote Link to comment Share on other sites More sharing options...
dnakruemel Posted December 20, 2021 Share Posted December 20, 2021 Its hard to tell, it seems that toshiba created a custom menu here which i do not find online. So if you select boot from USB it just ignores and skips it? Thats a sign of EFI not being recognized then; did you put the folder called EFI on the stick or the contents of it? Mainboard searches for an EFI folder on the EFI partition. Â For disabling CSM, it should be in a boot or device or general section, really different on various vendors. My ASUS desktop board has tons of submenus, but if yours is a bit simpler maybe post some images of the options we have to play around with? If all fails, maybe do try the OpenCore legacy; if i read documentation correct u need extra files, but we need @MaLd0nblessing for that. Lets try have a look at toshiba bootloader first. Â Quote Link to comment Share on other sites More sharing options...
linusrg Posted December 20, 2021 Author Share Posted December 20, 2021     It attempts to boot it but then it says failed to Boot this device please insert a bootable device and press any key.     Quote Link to comment Share on other sites More sharing options...
linusrg Posted December 20, 2021 Author Share Posted December 20, 2021      It attempts to boot it but then it says failed to Boot this device please insert a bootable device and press any key.                         https://drive.google.com/drive/folders/1DlB9gquAgXFXBJ9aZ-mwZy_ThMsidkJf?usp=sharing here is what my bios looks like s sss s s I cannot remove the extra S's this site is buggy in Firefox lol Quote Link to comment Share on other sites More sharing options...
dnakruemel Posted December 20, 2021 Share Posted December 20, 2021 Screenshot 2021-12-20 at 22.32.43.zip  can u check these options and see what u can set there? Quote Link to comment Share on other sites More sharing options...
linusrg Posted December 20, 2021 Author Share Posted December 20, 2021  There is an option between fdd and HDD under your first highlight, as for the second highlight the pic I uploaded that just has an advanced tab is what is in that menu     Quote Link to comment Share on other sites More sharing options...
dnakruemel Posted December 21, 2021 Share Posted December 21, 2021 (edited) So with the options exhausted, it might be worth a shot stepping your BIOS up from 2.1 to 4.1, i found installer here https://support.dynabook.com/support/modelHome?freeText=1200013843 You should go to the text field and choose the most accurate model and OS type ( its usually an installer that starts in windows, then reboots and finishes up in bios) Be patient, and stay connected to power. Dont abort, this can easy render your device complete trash (can be fixed by soldering to serial connectors but thats a whole other level) Available devices are Portege R830 (PT320A-03N007) Portege R830 (PT320A-03N00701) Portege R830 (PT320A-06K031) Portege R830 (PT320A-0HM00701) Portege R830 (PT320A-0HN007) Portege R830 (PT320C-01G018) Portege R830 (PT320C-01H018) Portege R830 (PT320C-01J018) Portege R830 (PT320C-01K018) Portege R830 (PT320C-05L02L) Â Â Â Â Â Â If you dont wanna go this route, id suggest using legacy addon for OpenCore. Visit dortania manual for that, and try boot with legacy. Edited December 21, 2021 by dnakruemel Quote Link to comment Share on other sites More sharing options...
linusrg Posted December 22, 2021 Author Share Posted December 22, 2021 Even after the bios update it fails to boot, so I think I have to go the legacy method. I am sorry to say though I cannot find the part of the guide that you mentioned. Where can I find it? Quote Link to comment Share on other sites More sharing options...
linusrg Posted December 22, 2021 Author Share Posted December 22, 2021 ok so I did get the usb to boot by following the OC guide to add legacy support but now it jut hangs at a blinking cursor. Any ideas? Quote Link to comment Share on other sites More sharing options...
dnakruemel Posted December 26, 2021 Share Posted December 26, 2021 Hey sorry i had to leave for christmas. Sounds like EFI is working now but actual ISO Kernel cant be executed. Did u use USB2 Port? Quote Link to comment Share on other sites More sharing options...
linusrg Posted December 26, 2021 Author Share Posted December 26, 2021 Nah dw about it. I did try both a usb 2 and 3 port. Quote Link to comment Share on other sites More sharing options...
dnakruemel Posted December 27, 2021 Share Posted December 27, 2021 Hm maybe we shall call in @MaLd0n at this point. Maybe post the EFI Folder you made on the USB drive with legacy option so Mald0n can check if its created correctly. If so, save it, re-write ISO and drop EFI Folder in again. Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted December 27, 2021 Administrators Share Posted December 27, 2021 for legacy try it Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill [email protected] BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @[email protected] Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
linusrg Posted December 27, 2021 Author Share Posted December 27, 2021      I am using open core though  not clover.        Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted December 27, 2021 Administrators Share Posted December 27, 2021 i never use opencore in old hardware need check manual Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill [email protected] BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @[email protected] Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
linusrg Posted December 27, 2021 Author Share Posted December 27, 2021 Are you saying I should try clover instead? I'll do that Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted December 27, 2021 Administrators Share Posted December 27, 2021 u can try with this efi folder with this options above https://tinyurl.com/3usvbpfv Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill [email protected] BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @[email protected] Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
linusrg Posted December 27, 2021 Author Share Posted December 27, 2021 (edited) when I try to install that clover boot manager tool on my Mac the installation fails. Any ideas? Edited December 27, 2021 by linusrg Quote Link to comment Share on other sites More sharing options...
Join the conversation
