Adrian Rapetti Posted November 10, 2021 Share Posted November 10, 2021 (edited) Hello, I am new to hackintosh, it turns out that when I wanted to install olarila mojave on my netbook, I couldn't do it but in turn apparently it damaged the bios, I get the following errors Formset DBC39F3D-0413-41B2-9285-46CA7BA94473 failed to load storage: PwdCredVar. status: Device error Formset 78D3BC87-78A3-4996-B813-1844050889F7 failed to load storage: Setup Status: Device error Formset 45FE5A54-F13D-72D8-6732-88E219CE2877 failed to load storage: PasswordState status: Device error Formset E1277EC4-E1AF-4223-8D45-C8730B882621 failed to load storage: SecureBootOption status: Device error and several more is like the bios was modified and it does not let me change the boot part, the disk recognizes it when I want to install for example windows 10 but in the bios it appears as -Empty- all this happened after you want to install the clover It stays in ********************** and does not continue to someone what may have happened, I also tell them to reset the bios, nothing, remove the battery Nothing, I made a short circuit to clean the bios, nothing is like it crashed and I cannot modify anything, because I give the bios to record when I want to play something and it does not record anything, I also change it but it remains the same? it is an intel celeron N2806 @ 1.60GHz. I hope you can help me thank you and apologies for being so extensive greetings. Edited November 10, 2021 by Adrian Rapetti Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted November 11, 2021 Administrators Share Posted November 11, 2021 celeron dont have native support use load optmized default Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill [email protected] BTC 1BDzsV4bw3DVCiffFAeNKsdEzqkPXNVrXR ETH BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ PicPay @danielnmaldonado PiX @[email protected] Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Adrian Rapetti Posted November 11, 2021 Author Share Posted November 11, 2021 Hello thanks for answering and what would I have to do to make an optimized load by default? I ask you why I do not understand, the machine does not allow me to modify the bios and therefore it does not take any UEFI in the bios? Quote Link to comment Share on other sites More sharing options...
Adrian Rapetti Posted November 13, 2021 Author Share Posted November 13, 2021 I need to know if you can help me since with my little knowledge, my papers were burned, the bios does not recognize the internal disk, but windows when I want to install any version, yes? Look online but it is all the other way around, the bios recognizes the disk but not windows? Another test I did was to try to install windows to boot from an external one, I did it in GPT and in UEFI and it worked that way? I tried to delete the CMOS but only modify the date, but not another thing, the weird thing is also that it creates the bootloader, for example windows bootloader, but when the disk does not recognize the bios does nothing, that I modified the clover ?, so much damage could it have done ?, I know there are some live cd for Check the bios, but I can't find them, others talk about reprogramming the eepromm but I don't have that tool to do it, I don't know what to do because the machine is unusable, you have another idea? I have no idea how to do an opencore or nothing like that Do you know another tool? Thank you very much in advance if you can give me a hand, greetings and hugs Quote Link to comment Share on other sites More sharing options...
Join the conversation
