viniciusmi00
A help for x79 (C602) users
For all users of x79 (C602) cards, who are having trouble getting Catalina and BigSur to work with Clover or OpenCore.
After spending days trying to get my x79 stop giving Kernel Panic in BS I was successful with a Patch. I realized that there are still people with difficulties in Catalina too, so I will leave some tips that can help you to get Catalina and BigSur.
For Power Management work in Catalina and BigSur there is a Patch in Kernel and Kext Patches, in KextsToPatch:
Name*        Find*.                      Replace*                     Comment
com.apple.driver.AppleIntelCPUPowerManagement                        7511B9                   EB11B9                        10.15, 11
com.apple.driver.AppleIntelCPUPowerManagement                        3E7538                   3E9090                         10.15, 11
Like a:
For BigSur not to get a Kernel Panic in IOPCIFamily there is a Patch in the ACPI, in DSDT.
Patches        Find*.                                                  Replace*
UNC0 _HID to XHID                                                       554E43 30085F48 4944                   554E43 30085848 4944
UNC1 _HID to XHID - UNC1 to Dual CPU                   554E43 31085F48 4944                   554E43 31085848 4944
Note*: UNC1 only required for cards with 2 processors
Like a:
You can use my EFI as an example, just stay tuned as I removed some essential files to get smaller.
EFI.zip
Note: In CPU > Type, you can remove these codes and put your CPU's code to appear correctly in "About this Mac"
To find the code of your CPU, just open the IOJones App and find the reference for your CPU (probably above the AppleACPICPU). The code for your cpu is found in the "cpu-type" property. Just reverse the order by placing the last 2 numbers first and the first two numbers last.
Edited by viniciusmi00
  • Like 3
i7 3930k (Sandy Bridge-E) - Rampage IV Extreme (x79) Bios 4901 Modified to NVME - AMD RX 5700XT - 16GB (4x4GB) Ripjaws 1866MHz - Monterey 12.3.1 - Clover 5146
Link to comment
Share on other sites
Hi, first of all, thanks for the help.
I am having problems updating to BigSur and I believe a relationship with what you comment.
First of all I do not load the AppleIntelCPUPowerManagement, I understand that it is only used on laptops.
The second thing is that I am using OpenCore 0.6.3 and a patched DDST from Marl0n, initially I used the SSDT-UNC.aml from the official opencore guide but same Kernel Panic in IOPCIFamily .
I have included the UNC0 _HID to XHID patch but continue with the Panic :-( .
This is my EFI tree:
├── BOOT
│   └── BOOTx64.efi
└── OC
    ├── ACPI
    │   └── DSDT.aml
   │   └── DSDT-UNC.aml
    ├── Bootstrap
    │   └── Bootstrap.efi
    ├── Drivers
    │   ├── HfsPlusLegacy.efi
    │   └── OpenRuntime.efi
    ├── Kexts
    │   ├── AirportBrcmFixup.kext
    │   │   └── Contents
    │   │       ├── Info.plist
    │   │       ├── MacOS
    │   │       │   └── AirportBrcmFixup
    │   │       └── PlugIns
    │   │           ├── AirPortBrcm4360_Injector.kext
    │   │           │   └── Contents
    │   │           │       └── Info.plist
    │   │           └── AirPortBrcmNIC_Injector.kext
    │   │               └── Contents
    │   │                   └── Info.plist
    │   ├── AppleALC.kext
    │   │   └── Contents
    │   │       ├── Info.plist
    │   │       └── MacOS
    │   │           └── AppleALC
    │   ├── Lilu.kext
    │   │   └── Contents
    │   │       ├── Info.plist
    │   │       └── MacOS
    │   │           └── Lilu
    │   ├── NoTouchID.kext
    │   │   └── Contents
    │   │       ├── Info.plist
    │   │       └── MacOS
    │   │           └── NoTouchID
    │   ├── NullCPUPowerManagement.kext
    │   │   └── Contents
    │   │       ├── Info.plist
    │   │       ├── MacOS
    │   │       │   └── NullCPUPowerManagement
    │   │       └── Resources
    │   │           └── English.lproj
    │   │               └── InfoPlist.strings
    │   ├── SATA-unsupported.kext
    │   │   └── Contents
    │   │       └── Info.plist
    │   ├── SmallTreeIntel82576.kext
    │   │   └── Contents
    │   │       ├── Info.plist
    │   │       ├── MacOS
    │   │       │   └── SmallTreeIntel82576
    │   │       ├── Resources
    │   │       │   └── English.lproj
    │   │       │       └── InfoPlist.strings
    │   │       └── _CodeSignature
    │   │           └── CodeResources
    │   ├── USBInjectAll.kext
    │   │   └── Contents
    │   │       ├── Info.plist
    │   │       ├── MacOS
    │   │       │   └── USBInjectAll
    │   ├── VirtualSMC.kext
    │   │   └── Contents
    │   │       ├── Info.plist
    │   │       └── MacOS
    │   │           └── VirtualSMC
    │   ├── VoodooTSCSync.kext
    │   │   └── Contents
    │   │       ├── Info.plist
    │   │       └── MacOS
    │   │           └── VoodooTSCSync
    │   ├── WhateverGreen.kext
    │   │   └── Contents
    │   │       ├── Info.plist
    │   │       └── MacOS
    │   │           └── WhateverGreen
    │   └── XHCI-unsupported.kext
    │       └── Contents
    │           └── Info.plist
    ├── OpenCore.efi
    ├── Resources
    │   ├── Audio
    │   ├── Font
    │   ├── Image
    │   └── Label
    ├── Tools
    │   └── OpenShell.efi
    ├── config-BigSur.plist
    ├── config-catalina.plist
    └── config.plist
Can you give me a hand please?
Edited by Hector Melendez
Link to comment
On 11/16/2020 at 6:35 AM, viniciusmi00 said:
@Hector Melendez I don't know what it can be, I'm also not good with OpenCore. Mine is functional, see if it can help you.
Hi Dear .. first i want to say thank you .. i tried every config and images but this second efi folder you shared solved my problem and now i can install Big Sur 11.1 image with your efi but i have little issues . my usb 3 and wifi dosnt work .. can you make this efi opencore folderbetter for me ?
Asus P9x79
i7 3820 ( i want upgrade to e5 2697 v2 )
Asus ROG Strix 5500XT / 5700XT ( but in 5700xt geekbench gpu test , my pc was restarted every time )
Link to comment
Hello, I watch this EFI. I already make chances this file to my Xeon E5 2630 v2 and RX 470, but the system not Iniciatialize, only the apple screen remains and does not enter to login
Link to comment
Asus P9x79
I'm also not getting my USB 3.0 to work. The "GenericUSBXHCI.kext" kext is not working on Big Sur. I am looking for a solution, but so far I haven't found it. Is your USB 3.0 also controlled by Asmedia ASM 1042?
I abandoned OpenCore, I had some problems. I'm just using Clover. See if my EFi folder solves your problem.
Note: I already changed the SMBIOS serial before I sent you the Clover. You can test this folder without having to change the SMBIOS serial.
https://drive.google.com/file/d/1hiIk9gt4HAp0nr4N4x7eSmmauFJzqm_S/view?usp=sharing
Link to comment
yes yes .. exactly ASMedia® USB 3.0 controller
if you found a solution , please share with us
again , thank you for everythink
Link to comment
On 1/28/2021 at 2:08 PM, JakubW said:
Hey guys,
I got PM to work fully in OC, I followed the official OC guide and generated the SSDT with Piker's script and set up the Omni Patch. Config bit for OC attached, as well as Output from AppleIntelnfo
Hi mate, do you have x86platformplugin loaded in ioregistry?
Thanks for sharing the .plist. Do you mind sharing the ssdt so I can compare with mine?
Thanks in advance.
Link to comment
Hey, no the x86platformplugin plugin isn't loaded, it wouldn't load anyway, just the kext patches
And here is the SSDT, nothing big, most of the job was done with Pikers script.
SSDT-PM.aml
Link to comment
got improvements on SSDT and loading x86 platform plugin, now it is loading correctly and Mac single core turbo is displayed correctly. To generate it I sues the script with following attributes
./ssdtPRGen.sh -p 'E5-2670' -x 1 -target 0 -c 3 -cpus 1 -l 8 -mode custom -d 3
You need to extract amps from your motherboard and copy APIC.aml to your desktop.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Hey! Welcome to Olarila.com  Please Disable Your ADBlocker!
The popup will be closed in 15 seconds...
