mendietinha Posted September 28, 2013 Share Posted September 28, 2013 is your chipset hm77? Quote Se quando viaja faz o que quer, quando viajar, não leve a mulher ----  No PM support. Use the forum..Dell Latitude i7 8565U 16Gb 256Gb M.2 Intel UHD620 (macOS 14.3) OC Lenovo Core I5 6200U 8Gb 256Gb HD520 (macOS 14.4b) OC Ryzen 7 5700X 32Gb 2Tb nvme RTX 3060TI 8Gb (W11) Link to comment Share on other sites More sharing options...
PimentelX86 Posted September 28, 2013 Share Posted September 28, 2013 Hello. Kext Edited: http://www.4shared.com/zip/p_No1-HY/NVDAGF100Halkext.html You need have a usb stick, put the kext inside it. Intall by terminal installation How install: 1 - Repair permissions: https://sites.google.com/site/oldnapalm/como-instalar-kexts 2 -Move the kext to S/L/E: http://www.insanelymac.com/forum/topic/224491-kernel-panic-deletando-kext-pelo-single-user-s-ou-pelo-terminal-do-dvd-de-instalacao/ 3 - Update cache: touch /System/Library/Extensions  All guides are in portuguese, so translate with google. I hope it works Quote Link to comment Share on other sites More sharing options...
iDont Posted September 29, 2013 Author Share Posted September 29, 2013 is your chipset hm77? Â Yes. Yes it is HM77 Quote Link to comment Share on other sites More sharing options...
mendietinha Posted September 29, 2013 Share Posted September 29, 2013 check if your intel hd3000 dev id is 0x0116. if so, this is how i solve my problem to activate the video: you need a smbios of macbook pro 8.1 and GraphicsEnabler=Yes if your chipset is hm77 you may need to edit AppleIntelSNBGraphicsFB and change the IOPCIPrimaryMatch 0x1C3A8086 to IOPCIPrimaryMatch 0x1E3A8086 and in the line that appear your dev id let just it and remove others. in my case was like this IOPCIPrimaryMatch 0x01068086 0x11068086 0x16018086 01168086 01268086 and i change to IOPCIPrimaryMatch 0x01168086 and i did but don't know if it's mandatory, delete the AppleIntelFramebufferCapri. Quote Se quando viaja faz o que quer, quando viajar, não leve a mulher ----  No PM support. Use the forum..Dell Latitude i7 8565U 16Gb 256Gb M.2 Intel UHD620 (macOS 14.3) OC Lenovo Core I5 6200U 8Gb 256Gb HD520 (macOS 14.4b) OC Ryzen 7 5700X 32Gb 2Tb nvme RTX 3060TI 8Gb (W11) Link to comment Share on other sites More sharing options...
iDont Posted September 30, 2013 Author Share Posted September 30, 2013 check if your intel hd3000 dev id is 0x0116. if so, this is how i solve my problem to activate the video: you need a smbios of macbook pro 8.1 and GraphicsEnabler=Yes if your chipset is hm77 you may need to edit AppleIntelSNBGraphicsFB and change the IOPCIPrimaryMatch 0x1C3A8086 Â Hi. May i know what kext editor did you use? Because my editor cant open the kext. I use this sudo /Applications/TextEdit.app/Contents/MacOS/TextEdit [space] [drag the file to terminal] Quote Link to comment Share on other sites More sharing options...
iDont Posted September 30, 2013 Author Share Posted September 30, 2013 Hello. Kext Edited: http://www.4shared.com/zip/p_No1-HY/NVDAGF100Halkext.html You need have a usb stick, put the kext inside it. Intall by terminal installation How install: 1 - Repair permissions: https://sites.google.com/site/oldnapalm/como-instalar-kexts 2 -Move the kext to S/L/E: http://www.insanelymac.com/forum/topic/224491-kernel-panic-deletando-kext-pelo-single-user-s-ou-pelo-terminal-do-dvd-de-instalacao/ 3 - Update cache: touch /System/Library/Extensions  All guides are in portuguese, so translate with google. I hope it works  HOLY cow it works! I Deleted the ATI, and all the AppleINTELHD kext then boot to -v cpus=1 GraphicsEnabler=Yes And it works! although the flash of firefox is not working even though i installed flash and Sometimes it lags. And also i got this opengl not supported on mac. Seems like im only one having this issue. Tried to search on this forum Do you think its because of the deleted kext? EDIT: Can i boot to HDD using usb again and change the org.chameleon.boot and check the GraphicsEnabler? Thank you very much Quote Link to comment Share on other sites More sharing options...
artur-pt Posted September 30, 2013 Share Posted September 30, 2013 hello try this kext  HD 3000.zip  install it run disk util repair permissions in the volume boot -f -v GraphicsEnabler=No good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
iDont Posted October 1, 2013 Author Share Posted October 1, 2013 hello try this kext  [attachment=0]HD 3000.zip[/attachment]  install it run disk util repair permissions in the volume boot -f -v GraphicsEnabler=No good hack  Hi.. Still didnt work. I always got stuck on SNB Framebuffer. Quote Link to comment Share on other sites More sharing options...
artur-pt Posted October 1, 2013 Share Posted October 1, 2013 hello only don't work with u.. http://Olarila.com/forum/viewtopic.php?p=31990#p31990 good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
iDont Posted October 2, 2013 Author Share Posted October 2, 2013 hello only don't work with u.. http://Olarila.com/forum/viewtopic.php?p=31990#p31990 good hack  Hi. Yup it really doesnt work with me. I wonder why I remove the edited appleIntelHD and SNB and now everything is working. I am currently using my mac. I got the internet working Thanks for the help Quote Link to comment Share on other sites More sharing options...
artur-pt Posted October 2, 2013 Share Posted October 2, 2013 hello in that way u have a unuseful machine.. ML without graphics.. nothing works.. good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
iDont Posted October 2, 2013 Author Share Posted October 2, 2013 hello in that way u have a unuseful machine.. ML without graphics.. nothing works.. good hack  HI. Its okay. Ill just download xcode and use it to learn objective c. Thanks for the help Quote Link to comment Share on other sites More sharing options...
mendietinha Posted October 3, 2013 Share Posted October 3, 2013 delete the framebuffercapri and try this one see if it helps you:  AppleIntelSNBGraphicsFB.kext.zip  smbios mbp 8.1 and GraphicsEnabler=Yes Quote Se quando viaja faz o que quer, quando viajar, não leve a mulher ----  No PM support. Use the forum..Dell Latitude i7 8565U 16Gb 256Gb M.2 Intel UHD620 (macOS 14.3) OC Lenovo Core I5 6200U 8Gb 256Gb HD520 (macOS 14.4b) OC Ryzen 7 5700X 32Gb 2Tb nvme RTX 3060TI 8Gb (W11) Link to comment Share on other sites More sharing options...
iDont Posted October 3, 2013 Author Share Posted October 3, 2013 delete the framebuffercapri and try this one see if it helps you: [attachment=0]AppleIntelSNBGraphicsFB.kext.zip[/attachment]  smbios mbp 8.1 and GraphicsEnabler=Yes  Hi. I remove the framebuffercapri Installed the hd3000 kext and the SNBGraphics you gave then boot to GraphicsEnabler=Yes It boots to gui environment and everything is working fine. Although i am not sure if my system is using the intel HD3000 kext right now or the other kext given by PimentelX86. I look the launcher app and i think its running smoothly at first then begins to lag again and the notification bar on the left side of the screen when i scroll theres no pink glitch happening but when i restart it comes back. And the vlc player still reports open gl not found. So im not sure if the HD3000 kext is working now or not Maybe not? Im not sure. Thanks Quote Link to comment Share on other sites More sharing options...
mendietinha Posted October 3, 2013 Share Posted October 3, 2013 see in about this mac what is the video being used. if intel hd3000 delete the other video kexts and repair permissions. and make sure that you install the kexts from the pendrive that you remove to install or the kexts in the system can be without info.plist and it won't work. also, if you have system info check your dev id of the intel hd 3000. i can help you to get it working, just see if it is the intel hd active. Quote Se quando viaja faz o que quer, quando viajar, não leve a mulher ----  No PM support. Use the forum..Dell Latitude i7 8565U 16Gb 256Gb M.2 Intel UHD620 (macOS 14.3) OC Lenovo Core I5 6200U 8Gb 256Gb HD520 (macOS 14.4b) OC Ryzen 7 5700X 32Gb 2Tb nvme RTX 3060TI 8Gb (W11) Link to comment Share on other sites More sharing options...
iDont Posted October 3, 2013 Author Share Posted October 3, 2013 see in about this mac what is the video being used. if intel hd3000 delete the other video kexts and repair permissions. and make sure that you install the kexts from the pendrive that you remove to install or the kexts in the system can be without info.plist and it won't work. also, if you have system info check your dev id of the intel hd 3000. i can help you to get it working, just see if it is the intel hd active. Â HI. I think IntelHD3000 and SNB is being used. I think its active. I check the terminal via kextstat and i saw the SNB and HD3000 loaded. I double check ofcourse by removing the NVDA kext(i create a backup of it just in case) and booted via GraphicsEnabler=Yes and it still works Everything is working fine i guest but i still have that glitchy thing on notification menu and the open gl problem. The device ID of my intel graphics card is 1026 Â Thanks Quote Link to comment Share on other sites More sharing options...
