Install MacOS Catalina / Big Sur / Monterey on Mobos Serie 300 / 400 / 500 / 600 with Intel 8th / 9th / 10th / 11th / 12th Gen Desktop Processors using OpenCore or Clover bootloader
-Donations-
Link to comment
Share on other sites
Thank you,
This is not my first hackintosh. I start with Tiger looong time ago, blind ( no graphics during install) need to use pen and paper with the commands to make the installation. All the way to Big Sur on the PC I use now, a z370n wifi. I make the update to the dev version of Big Sur on the z370 with the use of your guides.
Link to comment
6 hours ago, dotzil said:
I send you my files
send me files via PM
-Donations-
Link to comment
On 12/15/2020 at 11:17 PM, MaLd0n said:
Mine worked with your material that you made available, macOS Big Sur final version already copied to the flash drive, open with Clover Configuration I set up EFI and pasted the folder that made it available, I only have an onboard video card.
Thank you in advance.
Gigabyte Z490 Gaming X
i5 10400
8 Gb Ram 3200Mhz
512 NMVE M.
Edited by franklin20
Link to comment
On 1/7/2021 at 7:31 PM, tito550 said:
(oc failed to load configuration)
https://tinyurl.com/y7puzwv9
disable csm and reset nvram
-Donations-
Link to comment
com a pasta do tópico vc só precisa do dsdt
-Donations-
Link to comment
Hello, I was able to successfully upload Big Sur using OpenCore, however since I don't have a dedicated GPU I'm getting problems with DRM and Sleep, I generated Send_me ... Can you generate a .dsdt as a solution? Thanks for attention... 3=)
My Hardware is:
MOBO: Aorus Pro B460M
Processor: I5 - 10400
Gpu: Only IGPU
Wifi/Bluetooth card: FV-T919
My Send_me: https://drive.google.com/file/d/1POElBPcfGe-sig4OjDlQVActzS7IKMjh/view?usp=sharing
Link to comment
12 hours ago, marq78 said:
Hello
use only one topic ;)
-Donations-
Link to comment
I can't erase the first one, sorry! I don't think I'm allowed, sorry
I commented in the other publication first, but only after I realized that this was something more like hardware
Edited by marq78
Link to comment
Hi @MaLd0n,
Setup:
CPU: i5 10400
MOBO: Gigabyte B460M DS3H
GPU: Sapphire RX 5500XT Nitro+
Bootloader: OpenCore EFI
OS: Bigsur
I can run the first step of the install (format disk and start copying files)
After copying files it reboots and stuck in reboot loop.
What can I do?
Video:
http://ddfwj7npcq62r.cloudfront.net/2021/VID-20210122-WA0004.mp4
Link to comment
19 minutes ago, Renttor said:
Hi @MaLd0n,
use my folder from first post
-Donations-
Link to comment
use bios/uefi in default
u don't need change nothing
-Donations-
Link to comment
I did a config reset on BIOS, it is a new MOBO.
I also tried to use Clover folder. I was able to install Bigsur with it.
But when try to boot, it keeps in another loop.
The message is like:
AMFI: SIP is off, allowing vpre dump for pid ...
Process[n] crashed: logd. Too many corpses being created.
apfs_get_firmlink_target_vnode:2007: vnode_lookupat(Library) dailed with error
video:
VID-20210123-WA0000.mp4
Link to comment
25 minutes ago, Fantastic said:
Is there a way to install MacOS Mojave on Z490 motherboards?
u can try with fakecpuid
-Donations-
Link to comment
Are these values compatible?
Cpuid1Data EB060800 00000000 00000000 00000000
Cpuid1Mask FFFFFFFF 00000000 00000000 00000000
Without these values the system doesn't even begin booting.
With these values it gets stuck at the image you see in the attachment.
Tested SMBIOS 19,1 and 19,2
Any other idea?
Ok, made it work with such patch, SMBIOS iMacPro1,1
Sweet...
Archive.zip
Edited by Fantastic
Link to comment
19 hours ago, Fantastic said:
Any other idea?
use catalina or bigsur with native support for ur hardware
-Donations-
Link to comment
6 hours ago, Amos Chan said:
Hi, I used your usb efi to install big sur, but stuck at "check the volume".
what ur hardware?
-Donations-
Link to comment
1 hour ago, MaLd0n said:
what ur hardware?
Processor: Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz (8 CPUs), ~2.1GHz
iGPU: Intel(R) UHD Graphics 128M
dGPU: NVIDIA GeForce MX250
Motherboard:X512FLC(I/O - 0284 for Intel 400 Series Chipset Family On-Package Platform Controller Hub)
Disk: intel SSDPEKNW512G8 ( 512 GB / SSD )
Audio:Realtek(R) High Definition Audio
Wifi:Atheros Qualcomm Atheros QCA9377 Wireless Network Adapter / Azurewave
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
