Vijay Kumar Vishwakarma Posted August 13, 2020 Share Posted August 13, 2020 (edited) Hi @MaLd0n, Thank you for your Fully Patched DSDT. It fixed so many things on my hackintosh. But Bluetooth Device is not detecting after using you DSDT. (I have followed your USB Patching Video Guide (USBPorts.kext) which you have added on 4th August) I searched on Internet regarding this and found that I need to use SSDT-EC-USBX.aml. I checked your DSDT and found that you have already added USBX and Device(EC) in my DSDT. I figure out that, in my case bluetooth is only detected only if I disable EC0 using SSDT-EC.aml. Please find the attached SSDT-EC.aml and USBPorts.kext file.SSDT-EC.amlUSBPorts.zip I have also created RunMe file for both cases (With and without SSDT-EC.aml). Please find below the links of RunMe files. Bluetooth Detecting/Working (DSDT + SSDT-EC.aml): https://wetransfer.com/downloads/86315a96f05dec4fff63e891bdb5162b20200813065359/22d38a/grid Bluetooth not Detecting/Working (Only DSDT): https://wetransfer.com/downloads/9f11152228836ec5ce06168cced6de0620200813092704/a03985/grid Could you please add SSDT-EC.aml thing in my patched DSDT. 🙂 Or is there any other way available. Note: After using SSDT-EC.aml, battery status is not updating instantly (update after 30-40sec, if plug and unplug power source from my laptop). [Battery Status is working fine by using only DSDT]. Please HELP!!!!!!! 🙏 Thank you very much for your work. 🙂 Edited October 13, 2022 by Vijay Kumar Vishwakarma Issue Solved Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 13, 2020 Administrators Share Posted August 13, 2020 try now DSDT.aml.zip Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Vijay Kumar Vishwakarma Posted August 14, 2020 Author Share Posted August 14, 2020 (edited) 10 hours ago, MaLd0n said: try now DSDT.aml.zip 42.34 kB · 0 downloads Boot stucked at- ApplePS2Controller: Notification consumer published: ApplePS2Keyboard Update: stucked at same line after renaming EC0 to EC under ACPI Patch Edited August 14, 2020 by Vijay Kumar Vishwakarma Checked EC0 to EC rename 1 Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 15, 2020 Administrators Share Posted August 15, 2020 start from zero with ec0 to ec and _sta rtc fix with no dsdt/ssdt Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Vijay Kumar Vishwakarma Posted August 15, 2020 Author Share Posted August 15, 2020 5 hours ago, MaLd0n said: start from zero with ec0 to ec and _sta rtc fix with no dsdt/ssdt System booted with EC0 to EC and _STA RTC Fix [No DSDT/SSDT]. 🤩 But Bluetooth is not detected in this case too. 😔 RunMe file: https://filebin.net/1c8z1zvbbtpgbrff Note: While playing with my system, I have noted some points which may help you to figure out the problem/solution: If the below code is executed (code under EC0), bluetooth not detected, if I disable EC0 with Method (_STA), bluetooth detected. In case of EC0 disabled, bluetooth detect only if I first boot Windows 10. After that, macOS Big Sur. In my opinion, some code under EC0 is restricting Bluetooth to enable. [Need to remove if possible]. Device (EC0) { Name (_HID, EisaId ("PNP0C09") /* Embedded Controller Device */) // _HID: Hardware ID Name (_GPE, 0x14) // _GPE: General Purpose Events Name (OKEC, One) Name (_CRS, ResourceTemplate () // _CRS: Current Resource Settings { IO (Decode16, 0x0062, // Range Minimum 0x0062, // Range Maximum 0x01, // Alignment 0x01, // Length ) IO (Decode16, 0x0066, // Range Minimum 0x0066, // Range Maximum 0x01, // Alignment 0x01, // Length ) }) Method (_REG, 2, NotSerialized) // _REG: Region Availability { If ((Arg0 == 0x03)) { OKEC = Arg1 OSTP () ECFG (One) MSFG = (S0ID & One) PBOV = (PB1E & One) } } OperationRegion (ECMM, SystemMemory, 0xFC7E0800, 0x1000) Field (ECMM, AnyAcc, Lock, Preserve) { CDPR, 1, LCDS, 1, , 5, ISEN, 1, HTBN, 8, HTBT, 8, LMEN, 1, , 4, RFEN, 1, Offset (0x04), ADAP, 3, Offset (0x05), CORE, 2, Offset (0x06), Offset (0x07), , 5, IOAC, 1, PTPS, 1, Offset (0x08), Offset (0x0A), DNLV, 8, Offset (0x0D), GC6F, 1, NGPS, 1, Offset (0x13), C1FR, 16, G1FR, 16, Offset (0x20), DNBF, 1, , 2, BBMS, 1, , 3, Offset (0x2A), S1TV, 8, Offset (0x2D), DISM, 1, Offset (0x2E), CLCD, 1, Offset (0x30), , 7, WAMK, 1, KBLK, 1, Offset (0x32), DSTP, 8, RH2T, 8, RH1T, 8, Offset (0x3B), ALTO, 1, HSAS, 1, Offset (0x3E), GPUE, 1, VGAO, 1, GC6O, 1, , 1, , 1, , 1, , 1, Offset (0x3F), FCTR, 1, FCMP, 1, PWOK, 1, Offset (0x40), GPUD, 1, Offset (0x41), BNEI, 1, Offset (0x42), BNEO, 1, Offset (0x43), Offset (0x5D), ERIB, 16, Offset (0x61), SMST, 8, SMAD, 8, SMCM, 8, SMD0, 256, BCNT, 8, SMAA, 24, SMBN, 8, Offset (0xA0), Offset (0xA1), , 1, VIDO, 1, TOUP, 1, Offset (0xA2), ODTS, 8, OSTY, 4, , 1, PBOV, 1, ECRD, 1, ADPT, 1, PWAK, 1, MWAK, 1, LWAK, 1, RWAK, 1, WWAK, 1, UWAK, 1, KWAK, 1, TWAK, 1, CCAC, 1, AOAC, 1, BLAC, 1, PSRC, 1, BOAC, 1, LCAC, 1, AAAC, 1, ACAC, 1, S3ST, 1, S3RM, 1, S4ST, 1, S4RM, 1, S5ST, 1, S5RM, 1, CSST, 1, CSRM, 1, OSTT, 8, OSST, 8, THLT, 8, TCNL, 8, MODE, 1, , 2, INIT, 1, FAN1, 1, FAN2, 1, FANT, 1, SKNM, 1, SDTM, 8, FSSN, 4, FANU, 4, PCVL, 6, SWTO, 1, TTHR, 1, TTHM, 1, THTL, 1, TFCT, 1, NPST, 5, CTMP, 8, CTML, 8, EST3, 8, SKTB, 8, SKTC, 8, DPOT, 8, EST1, 8, EST2, 8, , 1, LIDF, 1, PMEE, 1, PWBE, 1, RNGE, 1, BTWE, 1, Offset (0xB9), BRTS, 8, S35M, 1, S35S, 1, , 1, MSFG, 1, FFEN, 1, FFST, 1, Offset (0xBB), WLAT, 1, BTAT, 1, WLEX, 1, BTEX, 1, KLSW, 1, WLOK, 1, AT3G, 1, EX3G, 1, PJID, 8, CPUJ, 3, CPNM, 3, GATY, 2, Offset (0xC0), BTY0, 1, BAM0, 1, BAL0, 1, , 1, BMF0, 4, BST0, 8, BRC0, 16, BSN0, 16, BPV0, 16, BDV0, 16, BDC0, 16, BFC0, 16, GAU0, 8, BAT0, 8, BPC0, 16, BAC0, 16, BCG0, 16, BFCB, 16, BTPB, 16, BOL0, 1, BFS0, 1, Offset (0xDB), ORRF, 1, Offset (0xDC), Offset (0xDD) } OperationRegion (ERAM, EmbeddedControl, Zero, 0xFF) Field (ERAM, ByteAcc, Lock, Preserve) { Offset (0x5F), ERBD, 8, SMPR, 8, Offset (0x62) } OperationRegion (CCLK, SystemIO, 0x1810, 0x04) Field (CCLK, DWordAcc, NoLock, Preserve) { , 1, DUTY, 3, THEN, 1, Offset (0x01), FTT, 1, , 8, TSTS, 1 } Method (FANG, 1, NotSerialized) { Local0 = EIDR (Arg0) Return (Local0) } Method (FANW, 2, NotSerialized) { EIDW (Arg0, Arg1) Return (Arg1) } Method (TUVR, 1, NotSerialized) { Return (0x05) } Method (THRO, 1, NotSerialized) { ITHR (Arg0) } Method (CLCK, 1, NotSerialized) { If ((Arg0 == Zero)) { THEN = Zero FTT = Zero } Else { DUTY = Arg0 THEN = One } Return (THEN) /* \_SB_.PCI0.LPCB.EC0_.THEN */ } Method (PCLK, 0, NotSerialized) { IPCL () } Method (ITHR, 1, NotSerialized) { If ((Arg0 == Zero)) { Return (0xFF) } ElseIf ((Arg0 == One)) { Return (DUTY) /* \_SB_.PCI0.LPCB.EC0_.DUTY */ } ElseIf ((Arg0 == 0x02)) { Return (TTHR) /* \_SB_.PCI0.LPCB.EC0_.TTHR */ } Else { Return (0xFF) } } Method (IPCL, 0, NotSerialized) { Local0 = PCVL /* \_SB_.PCI0.LPCB.EC0_.PCVL */ CPPC = Local0 PNOT () } Method (_Q11, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { Notify (PS2K, 0x0405) } Method (_Q12, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { Notify (PS2K, 0x0406) } Method (_Q37, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { Debug = "=====QUERY_37=====" ^^^WMID.FEBC [Zero] = 0x08 ^^^WMID.FEBC [One] = ADPT /* \_SB_.PCI0.LPCB.EC0_.ADPT */ Notify (WMID, 0xBC) // Device-Specific Notify (ACAD, 0x80) // Status Change Sleep (0x03E8) Notify (BAT1, 0x80) // Status Change PWRS = ADPT /* \_SB_.PCI0.LPCB.EC0_.ADPT */ POWS = ADPT /* \_SB_.PCI0.LPCB.EC0_.ADPT */ PNOT () } Method (_Q41, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { Debug = "=====PROJECT_QUERY_41=====" ^^^WMID.FEBC [Zero] = One ^^^WMID.FEBC [One] = 0x8A ^^^WMID.FEBC [0x02] = One Notify (WMID, 0xBC) // Device-Specific } Method (_Q44, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { Debug = "=====PROJECT_QUERY_44=====" If ((DNLV == One)) { Notify (^^^PEG0.PEGP, 0xD1) // Hardware-Specific } ElseIf ((DNLV == 0x02)) { Notify (^^^PEG0.PEGP, 0xD2) // Hardware-Specific } ElseIf ((DNLV == 0x03)) { Notify (^^^PEG0.PEGP, 0xD3) // Hardware-Specific } ElseIf ((DNLV == 0x04)) { Notify (^^^PEG0.PEGP, 0xD4) // Hardware-Specific } ElseIf ((DNLV == 0x05)) { Notify (^^^PEG0.PEGP, 0xD5) // Hardware-Specific } Else { Notify (^^^PEG0.PEGP, 0xD1) // Hardware-Specific } } Method (_Q45, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { ^^^WMID.FEBC [Zero] = One ^^^WMID.FEBC [One] = HTBN /* \_SB_.PCI0.LPCB.EC0_.HTBN */ Notify (WMID, 0xBC) // Device-Specific } Method (_Q46, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { ^^^WMID.FEBC [Zero] = 0x02 ^^^WMID.FEBC [One] = HTBN /* \_SB_.PCI0.LPCB.EC0_.HTBN */ Notify (WMID, 0xBC) // Device-Specific } Method (_Q48, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { SGOV (0x03010001, Zero) } Method (_Q49, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { SGOV (0x03010004, One) } Method (_Q4C, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { SMID = 0x4C SMIC = 0xB2 Stall (0xFF) Stall (0xFF) } Method (_Q5A, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { Debug = "=====PROJECT_QUERY_5A=====" ^^^WMID.FEBC [Zero] = 0x09 ^^^WMID.FEBC [One] = BBMS /* \_SB_.PCI0.LPCB.EC0_.BBMS */ Notify (WMID, 0xBC) // Device-Specific } Method (_Q63, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { Notify (AAMC, 0x80) // Status Change } OperationRegion (PRT0, SystemIO, 0x80, 0x04) Field (PRT0, ByteAcc, Lock, Preserve) { P80H, 8 } Method (_Q10, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { } Method (_Q15, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { Debug = "=====QUERY_15=====" P80H = 0x15 If (IGDS) { Local0 = LIDF /* \_SB_.PCI0.LPCB.EC0_.LIDF */ Local0 = ~Local0 Local0 &= One Local0 += 0x02 If (^^^GFX0.GLID (Local0)) { ^^^GFX0.CLID |= 0x80000000 } } Notify (LID0, 0x80) // Status Change } Method (_Q1D, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { Debug = "=====QUERY_1D=====" P80H = 0x1D PCLK () } Method (_Q1E, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { Debug = "=====QUERY_1E=====" P80H = 0x1E If (CTUR) { If ((TFCT == Zero)) { CSMI (0xDA, Zero) } Else { CSMI (0xDA, One) } } } Method (_Q24, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { Debug = "=====QUERY_24=====" P80H = 0x24 Sleep (0x03E8) Notify (BAT1, 0x80) // Status Change } Method (_Q25, 0, NotSerialized) // _Qxx: EC Query, xx=0x00-0xFF { Debug = "=====QUERY_25=====" P80H = 0x25 Sleep (0x03E8) Notify (BAT1, 0x81) // Information Change Sleep (0x03E8) Notify (BAT1, 0x80) // Status Change } Name (CTSL, Package (0x19) { 0x10, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x20, 0x21, 0x22, 0x24, 0x25, 0x26, 0x28, 0x90, 0x91, 0xFE, 0x92, 0x93, 0x94, 0x95, 0x96, 0x97, 0x98, 0x99 }) Mutex (CFMX, 0x00) Method (CFUN, 4, Serialized) { Name (ESRC, 0x05) If ((DerefOf (Arg0 [Zero]) == 0x15)) { CreateWordField (Arg1, Zero, SFUN) If ((SFUN == 0x9001)){} ElseIf ((SFUN == 0x9002)) { STDT = Zero BFDT = Zero BFDT = Zero STDT = One } ElseIf ((SFUN == 0x9000)) { ESMC (Arg2) If ((ESMS != 0xFF)) { Local1 = Buffer (0x80){} Local1 [Zero] = 0x80 Local1 [One] = ESMS /* \ESMS */ Local3 = ESMB /* \ESMB */ Local1 [0x02] = DerefOf (Local3 [Zero]) Local1 [0x03] = DerefOf (Local3 [One]) Local1 [0x04] = DerefOf (Local3 [0x02]) Local1 [0x05] = DerefOf (Local3 [0x03]) Local1 [0x06] = DerefOf (Local3 [0x04]) Local1 [0x07] = DerefOf (Local3 [0x05]) Local1 [0x08] = DerefOf (Local3 [0x06]) Local1 [0x09] = DerefOf (Local3 [0x07]) Local1 [0x0A] = DerefOf (Local3 [0x08]) Local1 [0x0B] = DerefOf (Local3 [0x09]) Local1 [0x0C] = DerefOf (Local3 [0x0A]) Local1 [0x0D] = DerefOf (Local3 [0x0B]) Local1 [0x0E] = DerefOf (Local3 [0x0C]) Local1 [0x0F] = DerefOf (Local3 [0x0D]) Local1 [0x10] = DerefOf (Local3 [0x0E]) Local1 [0x11] = DerefOf (Local3 [0x0F]) Local1 [0x12] = DerefOf (Local3 [0x10]) Local1 [0x13] = DerefOf (Local3 [0x11]) Local1 [0x14] = DerefOf (Local3 [0x12]) Local1 [0x15] = DerefOf (Local3 [0x13]) Local1 [0x16] = DerefOf (Local3 [0x14]) Local1 [0x17] = DerefOf (Local3 [0x15]) Local1 [0x18] = DerefOf (Local3 [0x16]) Local1 [0x19] = DerefOf (Local3 [0x17]) Local1 [0x1A] = DerefOf (Local3 [0x18]) Local1 [0x1B] = DerefOf (Local3 [0x19]) Local1 [0x1C] = DerefOf (Local3 [0x1A]) Local1 [0x1D] = DerefOf (Local3 [0x1B]) Local1 [0x1E] = DerefOf (Local3 [0x1C]) Local1 [0x1F] = DerefOf (Local3 [0x1D]) Local1 [0x20] = DerefOf (Local3 [0x1E]) Local1 [0x21] = DerefOf (Local3 [0x1F]) BFDT = Local1 STDT = One } Else { STDT = 0x8000 } } Else { SFNO = Arg1 BFDT = Arg2 CSMI (0xCE, Arg0) } } ElseIf ((Match (CTSL, MEQ, DerefOf (Arg0 [Zero]), MTR, Zero, Zero) != Ones)) { SFNO = Arg1 BFDT = Arg2 CSMI (0xCE, Arg0) } Else { STDT = 0x8000 } } Name (OCSL, Package (0x03) { 0x80, 0x81, 0x82 }) Method (PFUN, 4, Serialized) { SFNO = Arg1 BFDT = Arg2 CSMI (0xCF, Arg0) STDT = Zero } Method (CMFC, 4, Serialized) { Name (RTVL, Package (0x04) { Zero, Zero, Zero, Zero }) Debug = "=== In CMFC method ===" If ((ObjectType (Arg0) == One)) { RTVL [Zero] = 0x8000 } ElseIf ((DerefOf (Arg0 [Zero]) < 0xFF)) { Local1 = Buffer (0x82){} CreateWordField (Local1, Zero, RTST) CreateField (Local1, 0x10, 0x0400, RTDT) If (((ToInteger (Arg0) <= 0x8F) && (ToInteger (Arg0 ) >= 0x80))) { PFUN (Arg0, Arg1, Arg2, Arg3) } Else { CFUN (Arg0, Arg1, Arg2, Arg3) } RTST = STDT /* \STDT */ RTDT = BFDT /* \BFDT */ Return (Local1) } Else { RTVL [Zero] = 0x8000 } Return (RTVL) /* \_SB_.PCI0.LPCB.EC0_.CMFC.RTVL */ } Mutex (FAMX, 0x00) Method (EIDR, 1, Serialized) { Acquire (FAMX, 0xFFFF) ERIB = Arg0 Local0 = ERRD (0x5F) Release (FAMX) Return (Local0) } Method (EIDW, 2, Serialized) { Acquire (FAMX, 0xFFFF) ERIB = Arg0 ERWT (0x5F, Arg1) Release (FAMX) } OperationRegion (ECCD, SystemMemory, 0xFC7E0800, 0x1000) Field (ECCD, AnyAcc, Lock, Preserve) { Offset (0x580), Offset (0x582), ECTB, 1, ECTE, 1, Offset (0x583), ERN1, 8, ERN2, 8, ERN3, 8, ERN4, 8, ERN5, 8, ERN6, 8, ERN7, 8, ERN8, 8, ECMD, 8, EDT1, 8, EDT2, 8, EDT3, 8, EDT4, 8, EDT5, 8, , 1 } Method (ERWT, 2, Serialized) { Local0 = Buffer (0x08){} Local0 [Zero] = 0xB1 Local0 [One] = Arg0 Local0 [0x02] = Arg1 ERCD (Local0) } Method (ERRD, 1, Serialized) { Local0 = Buffer (0x08){} Local0 [Zero] = 0xB0 Local0 [One] = Arg0 Return (ERCD (Local0)) } Mutex (CSMX, 0x00) Method (ERCD, 1, Serialized) { Acquire (CSMX, 0xFFFF) Name (ESRC, 0x64) ECTB = One ECMD = DerefOf (Arg0 [Zero]) EDT1 = DerefOf (Arg0 [One]) EDT2 = DerefOf (Arg0 [0x02]) ECTE = One While (((ESRC != Zero) && (ECTE != Zero))) { Sleep (0x0A) ESRC -= One } Local0 = ERN1 /* \_SB_.PCI0.LPCB.EC0_.ERN1 */ ECTB = Zero Release (CSMX) Return (Local0) } Method (SBAT, 2, NotSerialized) { Local0 = Buffer (0x08){} Local0 [Zero] = Arg0 Local0 [One] = 0x16 Local0 [0x02] = Arg1 Local0 [0x03] = Zero Local0 [0x04] = Zero ESMC (Local0) } Method (SBA2, 2, NotSerialized) { Local0 = Buffer (0x08){} Local0 [Zero] = Arg0 Local0 [One] = 0x36 Local0 [0x02] = Arg1 Local0 [0x03] = Zero Local0 [0x04] = Zero ESMC (Local0) } Mutex (ESCX, 0x00) Method (ESMC, 1, NotSerialized) { Acquire (ESCX, 0xFFFF) Name (ESRC, 0x05) SMD0 = Zero SMAD = DerefOf (Arg0 [One]) SMCM = DerefOf (Arg0 [0x02]) SMBN = DerefOf (Arg0 [0x03]) Local4 = DerefOf (Arg0 [0x04]) Local5 = Zero BCNT = Local4 If ((Local4 != Zero)) { Local1 = SMD0 /* \_SB_.PCI0.LPCB.EC0_.SMD0 */ While (~(Local4 == Local5)) { Local1 [Local5] = DerefOf (Arg0 [(0x05 + Local5)] ) Local5 += One } SMD0 = Local1 } SMPR = DerefOf (Arg0 [Zero]) While ((~(ESRC == Zero) && ~((SMST & 0x80 ) == 0x80))) { Sleep (0x14) ESRC -= One } If ((SMST == 0x80)) { ESMB = SMD0 /* \_SB_.PCI0.LPCB.EC0_.SMD0 */ ESMS = BCNT /* \_SB_.PCI0.LPCB.EC0_.BCNT */ } Else { Debug = "====== Sent EC SMBus command time out. ======" ESMS = 0xFF } Release (ESCX) } Method (_DSM, 4, NotSerialized) // _DSM: Device-Specific Method { If ((Arg2 == Zero)) { Return (Buffer (One) { 0x03 // . }) } Return (Package (0x02) { "acpi-wake-gpe", 0x6F }) } Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 15, 2020 Administrators Share Posted August 15, 2020 DSDT.aml.zip use usbinjectall with xhci port limit and check Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Vijay Kumar Vishwakarma Posted August 15, 2020 Author Share Posted August 15, 2020 (edited) 46 minutes ago, MaLd0n said: DSDT.aml.zip 42.33 kB · 4 downloads use usbinjectall with xhci port limit and check No Luck still bluetooth not detecting (only detect if I disable EC (manufacturer) code) RunMe link: https://filebin.net/o613wwzp90zv1jap Note: I have already tried this, renaming EC0 to EC manually in DSDT. I have tried all things as per my knowledge. 😭 Please Help to fix my bluetooth. 🙏 1 Query: What's the use of below code which is present under Device (EC): OperationRegion (ECMM, SystemMemory, 0xFC7E0800, 0x1000) Field (ECMM, AnyAcc, Lock, Preserve) { ... } Thanks! Edited August 15, 2020 by Vijay Kumar Vishwakarma Added my Query Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 15, 2020 Administrators Share Posted August 15, 2020 what ur bluetooth? Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Vijay Kumar Vishwakarma Posted August 15, 2020 Author Share Posted August 15, 2020 1 hour ago, MaLd0n said: what ur bluetooth? Intel 0x8087, 0x0aaa. Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 15, 2020 Administrators Share Posted August 15, 2020 u try last version? https://github.com/OpenIntelWireless/IntelBluetoothFirmware/releases 1 Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Vijay Kumar Vishwakarma Posted August 16, 2020 Author Share Posted August 16, 2020 4 hours ago, MaLd0n said: u try last version? https://github.com/OpenIntelWireless/IntelBluetoothFirmware/releases Yes, using latest version. Kext only loads up when bluetooth is enabled/detected at HS14 port. Quote Link to comment Share on other sites More sharing options...
Vijay Kumar Vishwakarma Posted August 16, 2020 Author Share Posted August 16, 2020 Current state of BT.PNG.zip See this image file of current state of my Bluetooth Device. Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 16, 2020 Administrators Share Posted August 16, 2020 no idea what happens 1 Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Vijay Kumar Vishwakarma Posted August 16, 2020 Author Share Posted August 16, 2020 4 hours ago, MaLd0n said: no idea what happens 😢😫 Quote Link to comment Share on other sites More sharing options...
Vijay Kumar Vishwakarma Posted August 17, 2020 Author Share Posted August 17, 2020 (edited) 19 hours ago, MaLd0n said: no idea what happens Hi @MaLd0n, Good News😄. Now, Bluetooth detected with Device (EC0) code enabled. Actually, I have updated my BIOS from A25 to A26 Version. Could you please patch my new DSDT file (extracted with only EC0 to EC rename) Note: Please do not patch battery in DSDT file. Battery status is working fine. RunMe file: https://we.tl/t-DgL9ccOvar Edited August 17, 2020 by Vijay Kumar Vishwakarma Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 17, 2020 Administrators Share Posted August 17, 2020 DSDT.aml.zip 1 Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Vijay Kumar Vishwakarma Posted August 17, 2020 Author Share Posted August 17, 2020 (edited) 3 hours ago, MaLd0n said: DSDT.aml.zip 38.82 kB · 2 downloads Thanks a lot! All things are working now even bluetooth with EC0 device enabled.☺️ But this DSDT broke my I2C Trackpad. 😭 Boot Error: VoodooI2CHIDDevice: :SYNA7D85 Could not find suitable _DSM or XDSM method in ACPI tables VoodooI2CHIDDevice: :SYNA7D85 Could not get HID descriptor I am using Latest version of VoodooI2C, VoodooI2CHID, VoodooInput and VoodooPS2Controller (VoodooPS2Keyboard & VoodooPS2Mouse only). RunMe file: https://we.tl/t-b3lwhK8DcS Edited August 17, 2020 by Vijay Kumar Vishwakarma Added Boot Error Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 18, 2020 Administrators Share Posted August 18, 2020 use VoodooI2CSynaptics.kext and add name SYNA7DB5 u dont need voodooinput, voodooi2c project have this plugin 1 Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Vijay Kumar Vishwakarma Posted August 18, 2020 Author Share Posted August 18, 2020 3 hours ago, MaLd0n said: use VoodooI2CSynaptics.kext and add name SYNA7DB5 u dont need voodooinput, voodooi2c project have this plugin Trackpad is still not working with VoodooI2CSynaptics.kext (added SYNA7DB5). Kext Folder contains: VoodooI2C.kext, VoodooI2CHID.kext, and VoodooI2CSynaptics.kext. Got this while booting: ACPI Error: [_DSM] Namespace lookup failure, AE_ALREADY_EXISTS (20160930/dswload-462) ACPI Exception: AE_ALREADY_EXISTS, During name lookup/catalog (20160930/psobject-310) ACPI Exception: AE_ALREADY_EXISTS, (SSDT:ACRPRDCT) while loading table (20160930/tbxfload-319) ACPI Error: 1 table load failures, 10 successful (20160930/tbxfload-342) I think, there is something wrong in DSDT. Previously, Trackpad was working fine with only VoodooI2c and VoodooI2CHID kexts using OLD DSDT (Old BIOS Version). I have compared both DSDTs and found that: New DSDT has no _DSM method under I2C but your old DSDT contains _DSM methods under I2C. Is there any difference in this? RunMe File: https://we.tl/t-R2koS1VGCd Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 18, 2020 Administrators Share Posted August 18, 2020 DSDT.TPAD.zip 1 Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Vijay Kumar Vishwakarma Posted August 18, 2020 Author Share Posted August 18, 2020 3 hours ago, MaLd0n said: DSDT.TPAD.zip 38.86 kB · 2 downloads Thank you for the DSDT 🙂 After adding this DSDT to ACPI folder, system starts normally (trackpad working) with below error codes. But on 2nd boot onwards, trackpad is not working and system bootup time increases due to slow loading of bootup lines (Please Check Start & End Video (approx 30-40sec) in attached link). This happens may be due to Kernel Panic, I got 🚫 icon on screen after 2min (check on attached [Video] End.mp4). ACPI Error: [_DSM] Namespace lookup failure, AE_ALREADY_EXISTS (20160930/dswload-462) ACPI Exception: AE_ALREADY_EXISTS, During name lookup/catalog (20160930/psobject-310) ACPI Exception: AE_ALREADY_EXISTS, (SSDT:ACRPRDCT) while loading table (20160930/tbxfload-319) ACPI Error: 1 table load failures, 10 successful (20160930/tbxfload-342) I figure out why I am getting this ACPI Error. My system's SSDT-9-ACRPRDCT.amlis conflicting with your patched DSDT.aml through _DSM Method (PEGP). RunMe files and Videos link: https://we.tl/t-PI6hMWlRIE Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 18, 2020 Administrators Share Posted August 18, 2020 this problem is about i2c, many users report some problems check github 1 Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Vijay Kumar Vishwakarma Posted August 19, 2020 Author Share Posted August 19, 2020 22 hours ago, MaLd0n said: this problem is about i2c, many users report some problems check github Thanks a lot for your support. Yes, you are correct. Whenever I remove VoodooI2C Kexts from Kext folder, system boots normally (30sec) with no TPAD working. Sometimes, TPAD works (1 in 20 times) Currently, macOS Big Sur is not supported by VoodooI2C. I need to raise an issue ticket on Voodoo Github. Could you please provide me the name of patches that you have applied to my DSDT (This will be helpful for me). Do you have any forum link for this issue? Please share with me 🙏, I haven't got much. Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 19, 2020 Administrators Share Posted August 19, 2020 47 minutes ago, Vijay Kumar Vishwakarma said: Currently, macOS Big Sur is not supported by VoodooI2C. very fine here in Lenovo mobiles. work perfect. check here, list of common patches https://www.olarila.com/topic/6874-olarila-hackbook-lenovo-ideapad-s145-mojave-catalina-big-sur-full-dsdt-patches-clover-and-opencore/#comments Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
Vijay Kumar Vishwakarma Posted August 20, 2020 Author Share Posted August 20, 2020 12 hours ago, MaLd0n said: very fine here in Lenovo mobiles. work perfect. Then, why it is not working in my laptop? ☹️🥺 Quote Link to comment Share on other sites More sharing options...
