Video Guide - Hackintosh USB Port Mapping with Hackintool
se for bigsur com clover ainda não
melhor criar um injector no catalina ou usando opencore
-Donations-
Link to comment
Share on other sites
6 hours ago, viniciuszardo said:
não entendi... as usbs3 não funcionam com clover e usbinjectall , isso?
se for bigsur n~çao tem o patch pro clover no bigsur. o opencore já tem isso built in
-Donations-
Link to comment
8 hours ago, rositaott said:
I hope I can manage to do this, I can't log on my hackintosh after updating to BigSur 11.3 yesterday, usb mouse and kbord not working 😅
disable xhci patch and start remap ur usb2 first
-Donations-
Link to comment
5 hours ago, rositaott said:
Thank You! Lucky I have multi OS boot that I can log in with and modify my config  🥰
https://www.olarila.com/topic/14220-video-guide-usb-port-mapping-guide-2021-bigsur-113-with-no-xhci-port-limit/
  • Thanks 1
-Donations-
Link to comment
On 8/4/2020 at 11:07 AM, MaLd0n said:
Donation with BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
Donation with PicPay @danielnmaldonado
Donation with Mercado Livre https://tinyurl.com/y9evkj5u
USB Remap after BigSur 11.3 check link bellow
-Downloads-
-USB Inject All by RehabMan
-Hackintool by HeadKaze
https://tinyurl.com/ymfp8fmw
-IORegistry Explorer by Apple
-Usb Connectors in ACPI Specification / Pages 524 and 525-
https://tinyurl.com/4wtntkfm
-USB Patches Clover-
https://tinyurl.com/y25r5e5m
-Some observations before start-
-We need one USB 2 stick, one USB 3 stick and one USB-C stick
-Old mobos with EHCI devices, need rename EHC1/EUSB to EH01 and EHC2/ USBE to EH02
-USB ports with devices permanently attached (eg. M.2 Bluetooth card) should be set to “Internal”
 -HSxx ports connected to USB3 ports should be set to USB3 (Skylake+)
-Internal HUBs are typically connected to ports PR11 and PR21 and therefore should be set to “Internal”
-USB-C
  • TypeC:
    • If it uses the same HSxx/SSxx in both orientations, then it has an internal switch (use “TypeC+Sw”)
    • If it uses a different HSxx/SSxx in each orientation, then it has no switch (use “TypeC”)
-Tutorial-
I used this method, and all USB ports works but not in the way was before update. my wireless dongle just works in 2 USB ports ( external in case) and my printer and external hard drive just works in those same two ports, it is uncomfortable. printer and external HDD don't works on motherboard USB ports.
Edited by capitanbelico
Link to comment
I haven't seen the video yet, but the problems can be related to the USB3 counting as two ports and USB2 counting as one. So this should be taken in consideration because the 15 port limit.
Forgive me if this has been addressed in the video.
Hacks:
Main:
Gigabyte Z390 Gaming X  - Intel i5 9400F - 16 GB DDR4 2666 - Radeon RX 570 4GB - Big Sur 11.4 / Monterrey 12 Beta 1
Backup: Gigabyte EP-45-UD3R - Intel Core2Quad 9550 @4.0Ghz - 8 GB DDR2 - GeForce 9800GT - Sierra
Link to comment
Hey @MaLd0n, what if we only activate the USB2 component (say, HSXX) for each USB2 port and JUST the USB3 component (for example, SSXX) for each USB3 port? Will that allow the USB3 ports to still function as USB3 (even if without any USB2 functionality), or will it cause problems?
Link to comment
yes
u can play with no problems
i'm using two usb2 ports(mouse/keyboard) and seven usb3
-Donations-
Link to comment
11 hours ago, MaLd0n said:
yes
Thanks @MaLd0n I'll try it out and let you know how it goes...
UPDATE: I tried it but apparently the USB3 ports need power from the USB2 as well, to power USB3 drives, so they didn't work. I wanted to basically activate ALL my USB3 ports, and ONLY the USB2 that I need, and still stay within the 15-port limit set by Mac OS. Wishful thinking!
Edited by jasperlevi
Updated with results...
Link to comment
no
we can use ports with only usb2 or usb3
example
HS04 is killed and SS04 stay work with only USB3
-Donations-
Link to comment
On 5/6/2021 at 5:00 PM, MaLd0n said:
no
example
@MaLd0n My apologies, you are correct, as always! I am now able to see (with the exception of one - a WD My Passport Wireless Pro) USB 3 devices when connected. My issue now is that my Broadcom BRCM20702 Bluetooth and Wi-Fi hub is not connecting to my Bluetooth mouse anymore. Wi-Fi seems to be doing fine. I'm attaching my ioreg file for you to have a look. Please help...
ioreg-file.rar
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
