  • Sky
  • Blueberry
  • Slate
  • Blackcurrant
  • Watermelon
  • Strawberry
  • Orange
  • Banana
  • Apple
  • Emerald
  • Chocolate
  • Charcoal
Hackintosh Guide - Install MacOS Catalina on Mobos Serie 400 with Intel 10th Desktop Processors using OpenCore bootloader
    -Donations with PayPal
    https://tinyurl.com/r2bvzm7
    -Donations with Bitcoin
    33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
    -Donations with PicPay
    @danielnmaldonado
    -Donation with Mercado Livre
    https://tinyurl.com/y9evkj5u
    -EFI OpenCore Folder Desktop 10th Intel Processors
    Paste this EFI folder in EFI partition in your USB STICK
    https://tinyurl.com/ybwr9kq3
    -Tutorial
    -Post Installation
    Paste EFI folder into EFI Partition in your SSD, reboot and extract one full dump with this app and post here!
    RunMe.app
    https://tinyurl.com/y9562hz7
    --DSDT PATCHES--
    -FIX ERRORS AND WARNINGS
    -FIX ACPI ERRORS
    -REMOVE UNUSED SCOPES / DEVICES
    -HIGH PRECISION EVENT TIMER
    -SATA SERIE ID
    -DMAC
    -REMOVE LINES, PROBLEMATIC and UNUSED
    -FIX K.P in REBOOT
    -NVRAM
    -REAL TIME CLOCK
    -SLPB
    -DARWIN / WINDOWS
    -XHCI
    -PLUGIN TYPE
    -HDEF
    -ARTC
    -IPIC
    -TIMR
    -SBUS
    -BUS1
    -MCHC
    -ALS0
    -SHUTDOWN
    -UAR1
    -LAN
    -FWHD
    -USBX
    -PMCR
    -PPMC
    -XSPI
    -GMM
    -kUSBCompanionIndex
    -io-device-location
    -IMEI
    -EC
    -PNLF
    -ARPT
    -GFX0
    -NVME
    -ACPI-WAKE-GPE
    -DTGP
    -ACQUIRE MUT0 0XFFFF
    -MUTEX MUT0 0x00
    -EXTERNAL REFERENCES
    -UNKNOWNOBJ
    -HDMI / HDAU
    -FULL RENAMED DEVICES
    -Credits and thanks to the old and new people in the community who developed patches, kexts and bootloaders!
    Slice, Kabyl, usr-sse2, jadran, Blackosx, dmazar, STLVNUB, pcj, apianti, JrCs, pene, FrodoKenny, skoczy, ycr.ru, Oscar09, xsmile, SoThOr, RehabMan, Download-Fritz, Zenit432, cecekpawon, Intel, Apple, Oracle, Chameleon Team, crazybirdy, Mieze, Mirone, Oldnapalm, netkas, Elconiglio, artut-pt, ErmaC, Pavo, Toleda, Master Chief and family, bcc9, The King, PMheart, Sherlocks, Micky1979, vit9696, vandroiy2013, Voodoo Team, Pike R. Alpha, lvs1974, Austere.J, CVad, headkaze, onemanosx, erroruser, Jenny David, Sampath007, Facebook Hackintosh community, Facebook Olarila community, SchmockLord, daliansky and many, many, many others!
    Share this post
    Link to post
    Share on other sites
    --UPDATE FIRST POST-
    -FOLDER
    -SCREENSHOTS
    Share this post
    Link to post
    Hi there!
    I tried the EFI folder provided herein, OC seems to start booting in verbose mode, but as soon as ~3-4 seconds later, the screen goes off and does not turn on again until I restart the computer.
    The config is:
    ASRock B460m Pro 4
    Core i5 10400f
    MSI RX 5500 XT 8G
    a 32g Corsair RAM stick
    Do you have any suggestions on what I could do? Thanks!
    Share this post
    Link to post
    3 hours ago, MaLd0n said:
    Thanks!
    I tried it to no avail. Same results: the system starts booting verbosely, but then the screen goes off. I took one side panel off my computer and noted that it's not just the screen: GPU fans come to a full stop at that same moment. So apparently, the system is not picking the GPU (a natively supported one, for that matter!)
    What can be done? Thanks again for your time
    Share this post
    Link to post
    post one video with this problem
    Share this post
    Link to post
    7 hours ago, Рауль Каримов said:
    Here’s video not sure if the running text is readable
    use bootarg -igfxvesa and clear nvram with entrie
    Share this post
    Link to post
    -igfxvesa or -radvesa? I don't have iGPU, mine is Intel Core i5 10400f, it has no integrated graphics.
    Problem solved, actually.
    The problem was that the offered OC config had iMac19,1 as system definition. I changed it to iMacPro1,1, and voila, i booted up! Perhaps that was due to absence of integrated graphics in my CPU (the iMacPro and MacPro are the only Apple systems that similarly have no iGPUs)
    Edited by Рауль Каримов
    Share this post
    Link to post
    -igfxvesa
    -radvesa is for amd cards
    Share this post
    Link to post
    Hello,
    I'm trying to install with the settings provided but stuck on the boot process:
    CPU: I5-1400
    Mobo: Gigabyte B460M DS3H
    If I connect via the external Vga (GTX1060) the boot works normally. I need to use the internal VGA to use catalina.
    https://imgur.com/a/pA0udJT
    Share this post
    Link to post
    16 hours ago, MaLd0n said:
    u need disable nvidia via dsdt/ssdt and use internal graphics
    post one dump
    My installation crashed 😕 I think it was because I tried to execute the update. I will perform a new installation tonight then I execute the file provided and send you the result. Thank you!
    Edited by jhonnyvey
    Share this post
    Link to post
    I am now trying to do a new installation but it is not working.
    I will do everything using the same files and it is on the error screen according to the images, do you have any idea?
    Share this post
    Link to post
    inject device ec
    Share this post
    Link to post
    I really don't know how to do this..
    The other time, I just copied the files and everything worked
    Share this post
    Link to post
    1 hour ago, jhonnyvey said:
    Same error. I'm using only the efi folder provide with the files.
    Problem  solved after removed disk partitions. Reinstalling now. TKS for the help.
    Share this post
    Link to post
