Hey, I recently bought a Lenovo Ideapad C340 laptop with i7-8565u, uhd620 and nvidia mx230 2gb. I tried a lot of different images of macOS, and I used Olarila images too. But I can't get macOS running on this laptop. It remains on 2 minutes left on the installation and it doesn't finish. What can I do? Thanks
Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here
4 hours ago, MaLd0n said:
I couldn’t install macOS into my laptop hard drive but I could run it in a external hard drive but it have random reboots. Can I solve the problem with the internal hard drive?
what internal u have?
pm981?
19 minutes ago, Jordi Beltran said:
yes!
change
13 minutes ago, MaLd0n said:
change
There's no other solution? Like a patch or something? I bought the laptop recently and I don't want to dissassembly the computer yet.
no
Hi! I have been using macOS Catalina 10.15 for months booting from a pen drive and working flawless (except wifi). Now I decided to start in Xcode and I have to update my system to 10.15.6. I made a fresh installation and now I have no Graphics Acceleration and Audio, so I don't know what I can do.
https://drive.google.com/file/d/1X7GbkR6kSXzMeuwevqVZqYR9recvpGAS/view?usp=sharing (this is the folder from RunMe.app)
u need check what wifi card u have
yea i know, but that is not the important problem because i use a usb wifi adapter. The problem is the graphics acceleration and the audio. I don't know why it is working in 10.15 and not in 10.15.6
save one ioreg and post here
