artur-pt Posted October 4, 2012 Author Share Posted October 4, 2012 Hello try to use this modified kext http://netkas.org/?p=1072 are u sure u note is 64 bit capable use system info present here in forum Hardware to see u dev id post photo good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
ojpd Posted October 28, 2012 Share Posted October 28, 2012 Question: Do I really need to have a DSDT?? I have gotten everything I need to work just by using multishit, my only real problem is a CMOS problem in which everytime I reboot my OSX partition it resets the bios date and time which affects only my bios and my Windows partitions.. The CMOS Reset doesn't change my Mac partition's date and time, as in my OSX install is OK.. But my Bios and Windows partition TIME always gets messed up everytime I reboot or shutdown my OSX install. Quote Link to comment Share on other sites More sharing options...
artur-pt Posted October 28, 2012 Author Share Posted October 28, 2012 hello i think u problem is other see this http://www.osx86.net/view/3323-local_time_toggle_time_reset_to_utc_fix_...html good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
ojpd Posted October 29, 2012 Share Posted October 29, 2012 hello i think u problem is other see this http://www.osx86.net/view/3323-local_time_toggle_time_reset_to_utc_fix_...html good hack  THANK YOU SO MUCH!!!!! It has literally been more than 3 months of trying to figure out how to fix this, all this time I thought I had the cmos reset bug... I recommend you add this in your post install thread. Thanks again!! Quote Link to comment Share on other sites More sharing options...
desperado Posted October 30, 2012 Share Posted October 30, 2012 2 question: do i've to use extra folder from lion usb installation metod??? I follow this guide, but my installer hangs on : PCI CONFIGURATION BEGIN( i've gtx 550ti) What shoukd i do?? Thanks Quote Lion 10.8.4, q6600 - p5e3 deluxe GTX 550 ti 1 gb - 8 gb ddr3 corsair 1600 Link to comment Share on other sites More sharing options...
Cassio Posted October 30, 2012 Share Posted October 30, 2012 Try replacing IOPCIFamily by this one and boot with -f http://Olarila.com/forum/viewtopic.php?f=27&t=1706 Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
desperado Posted October 30, 2012 Share Posted October 30, 2012 Try replacing IOPCIFamily by this one and boot with -f http://Olarila.com/forum/viewtopic.php?f=27&t=1706 Â Before follow your tip, i used chamaleon wizard to create create org.chamaleon.boot.plist (before there wasn't) and i flag npci=0x2000. installation starts, than i cross my finger Quote Lion 10.8.4, q6600 - p5e3 deluxe GTX 550 ti 1 gb - 8 gb ddr3 corsair 1600 Link to comment Share on other sites More sharing options...
desperado Posted October 31, 2012 Share Posted October 31, 2012 Before follow your tip, i used chamaleon wizard to create create org.chamaleon.boot.plist (before there wasn't) and i flag npci=0x2000. installation starts, than i cross my finger I installed ML correctly. Now i've to fix a couple of things (erhernet, hdd seen as external, audio, sleep) Thanks 4 your support. Quote Lion 10.8.4, q6600 - p5e3 deluxe GTX 550 ti 1 gb - 8 gb ddr3 corsair 1600 Link to comment Share on other sites More sharing options...
sheravi Posted October 18, 2013 Share Posted October 18, 2013 I apologize if this has already been answered, but I can't seem to find the answer to my question. I'm currently using Windows 8 on a MacBook Pro Retina as my main laptop, but I don't need to access the Mac partition that often. My plan was to take my existing Mac partition and somehow convert it for use within Virtualbox so I can just whip that out from time to time. Is there a way to do this? Quote Link to comment Share on other sites More sharing options...
