telepati Posted June 15, 2012 Share Posted June 15, 2012 My hardware is; Asus P8P67 EVO INTEL P67 (B3) LGA1155 DDR3 USB3 SATA3 ATX, INTEL Core i7-2600K LGA 1155 8MB 3.4GH, Cooler Master RC 692 Advance II, Seasonic 750W, WD Caviar Green 2 TB IntelliPower 64 MB Ön Bellek 3,5" SATA II DISK, Sapphire ATI HD6950 New Cooler 2GB DDR5 256 Bit PC,Sunbeam Tuniq Tower 120 Extreme Intel/Amd, Geil Plus 16GB DDR3 1600Mhz CL9 Low Voltage, LG GH22NS50 SATA DVD-RW I cant send a photo vrbose mode cause I cant install DP4.. Im using USB method I boot from USB language screen coming I select language then click next select hardrive and click install error coming. Quote Link to comment Share on other sites More sharing options...
artur-pt Posted June 15, 2012 Author Share Posted June 15, 2012 hello remove ati6000controller and see this http://Olarila.com/forum/viewtopic.php?f=18&t=736 good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
telepati Posted June 15, 2012 Share Posted June 15, 2012 Im saying I didnt make it install DP4 and got an error before starting to install you saying remove ATI6000Controller??? I you hearing to me? How can I remove ATI6000Controller even I dont start to install? My all HD epmty I trying to clean install to DP4 when I start to install Im getting error? Quote Link to comment Share on other sites More sharing options...
artur-pt Posted June 16, 2012 Author Share Posted June 16, 2012 hi are u reading to me ? if u don't know, dont speak what u don't know from the installer in s/l/e what kind of image are u installing ? man... good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
telepati Posted June 17, 2012 Share Posted June 17, 2012 hi are u reading to me ? if u don't know, dont speak what u don't know from the installer in s/l/e what kind of image are u installing ? man... good hack Sorry man I read and understand wrong... Sorry again.... Quote Link to comment Share on other sites More sharing options...
magnifico Posted June 17, 2012 Share Posted June 17, 2012 Jack Sparrow...listen me please But for mountain wich fake smc you use? Because my fakesmc have error ....( hardwaresensore by kozlek) Hey man i wait your news Quote Without PC Link to comment Share on other sites More sharing options...
artur-pt Posted June 18, 2012 Author Share Posted June 18, 2012 hi i use the last one from slice rev 609 from kzolek i dont know good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
magnifico Posted June 18, 2012 Share Posted June 18, 2012 ok..rev 609 work perfect. But for me mountain is again immature operative system Quote Without PC Link to comment Share on other sites More sharing options...
maly Posted June 20, 2012 Share Posted June 20, 2012 Hi artur, i installed ML dp4 in my pro book laptop, there was no difficulty at all but the colour are weird like: the blue is not blue but purple blue, yellow is golden yellow I have intel HD 3000 kext files, do you think if i delete intel HD 4000 kext files (2files) will be ok or ML will be unstable!! Thank you in advance artur. Quote Link to comment Share on other sites More sharing options...
artur-pt Posted June 20, 2012 Author Share Posted June 20, 2012 hi i think u problem is not related to that hd4000 is for ivy cpu so if u dont have a ivy cpu that kexts are not loaded what i can say about that is for the intel hd work good use in the dsdt the patch dual link if u lcd is above 1366x768 good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
dblois Posted July 3, 2012 Share Posted July 3, 2012 Does this work for Ivy Bridge processors with Z77 motherboards? Quote Link to comment Share on other sites More sharing options...
artur-pt Posted July 3, 2012 Author Share Posted July 3, 2012 hi the intel hd 4000, is not yet well supported use last chimera to boot and will see the hd 4000 ivy is all experimental good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
iLegendary Posted July 13, 2012 Share Posted July 13, 2012 I have a Kernel Panic in verbose mode.... IOPciFamilyKext..dont read Hey, I'm getting the same error. Do you know how you fixed it? I followed the normal procedure.. Previously this had happened to the install USB but I fixed it somehow, I think it was after adding NullCPUManagement.kext but it is not working for an installed copy which gets the same error.. Kernel version is set as 11.0.0.. This is wrong? Help! EDIT: Nevermind I got it to work, just had to start from scratch.. Quote Link to comment Share on other sites More sharing options...
Irish_Man Posted July 18, 2012 Share Posted July 18, 2012 I've installed ML GM yesterday and everything was working great (Network, Graphics, Sound) till this morning. First, I did remove AppleHDA.kext and installed VoodooHDA.kext. This morning I lost the sound. Suddenly all my Output in System Preferences turned to Digital Out. Before there was one LineOut which i used for the sound. I've never had this problem before. I really appreciate any help. Quote Gigabyte Z490 - Vision G Intel Core i7-10700K Saphire Radeon Pulse RX 580 4Gb Corsair Vengeance RGB PRO 32GB (2x16GB) DDR4 3600 C18 Samsung SSD EVO 860 500GB Corsair HX750 80Plus Platinum Link to comment Share on other sites More sharing options...
Cassio Posted July 18, 2012 Share Posted July 18, 2012 Edit Info.plist of VoodooHDA and specify ID of motherboard audio (IOPCIPrimaryMatch) http://Olarila.com/forum/viewtopic.php?f=18&t=454 Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Irish_Man Posted July 18, 2012 Share Posted July 18, 2012 Thank you very much for reply, I'll try to do that. Quote Gigabyte Z490 - Vision G Intel Core i7-10700K Saphire Radeon Pulse RX 580 4Gb Corsair Vengeance RGB PRO 32GB (2x16GB) DDR4 3600 C18 Samsung SSD EVO 860 500GB Corsair HX750 80Plus Platinum Link to comment Share on other sites More sharing options...
Irish_Man Posted July 18, 2012 Share Posted July 18, 2012 (edited) Edit Info.plist of VoodooHDA and specify ID of motherboard audio (IOPCIPrimaryMatch) http://Olarila.com/forum/viewtopic.php?f=18&t=454 Sorry but i have no idea which ID i need from this list. Can you please help with this? http://cl.ly/image/1h3w1o394745 I have changed from IOPCIClassMatch to IOPCIPrimaryMatch but don't know which ID and vendor I need UPDATE: Ok, I've downloaded the Voodoo.kext from the link you posted. Removed Voodoo.kext from Lib/Ext and installed the downloaded one. I got the sound back. Now I have to backup that because I'm afraid it will happen again. Thank you very much. Even, I don't understand how that can happen. Sound was working all day and suddenly was gone... Thank you... Edited July 18, 2012 by Guest Quote Gigabyte Z490 - Vision G Intel Core i7-10700K Saphire Radeon Pulse RX 580 4Gb Corsair Vengeance RGB PRO 32GB (2x16GB) DDR4 3600 C18 Samsung SSD EVO 860 500GB Corsair HX750 80Plus Platinum Link to comment Share on other sites More sharing options...
Cassio Posted July 18, 2012 Share Posted July 18, 2012 0x293e8086 Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Irish_Man Posted July 18, 2012 Share Posted July 18, 2012 0x293e8086 I made a copy of Info.plist with all the changes in case something goes wrong again. Once again, thank you very much for your help. Quote Gigabyte Z490 - Vision G Intel Core i7-10700K Saphire Radeon Pulse RX 580 4Gb Corsair Vengeance RGB PRO 32GB (2x16GB) DDR4 3600 C18 Samsung SSD EVO 860 500GB Corsair HX750 80Plus Platinum Link to comment Share on other sites More sharing options...
Irish_Man Posted July 21, 2012 Share Posted July 21, 2012 Hi, me again .......well, everything is working great but i just found out that these folders (etc,tmp,var) are shortcuts and they should be hidden and inside /private folder. I've checked and they are. Can I just delete them?. And "cores" folder was not there yesterday either. It's empty. Network too. Thanks.... http://cl.ly/image/2l3D2U3Y2e3w Quote Gigabyte Z490 - Vision G Intel Core i7-10700K Saphire Radeon Pulse RX 580 4Gb Corsair Vengeance RGB PRO 32GB (2x16GB) DDR4 3600 C18 Samsung SSD EVO 860 500GB Corsair HX750 80Plus Platinum Link to comment Share on other sites More sharing options...
rakusson Posted August 12, 2012 Share Posted August 12, 2012 Hi artur-pt, It seems we have same configuration in our computer. My sound isn't working after installing Mountain Lion. I too have Alc272. How did you manage it to work?Also, I used unishit method to install ML but wont recognize my graphics card. Graphics card run fine with Chameleon after internal lcd forced edid. My Elantech trackpad works fine when I boot using unishit USB but wont work when booting through Chameleon!!! I copied all kexts from Extra/Extension folder from unishit to Chameleon but no success? any suggestion? Quote eMachines E730G Intel Core i3-350M, 3 GB DDR3, ATI Mobility Radeon HD5470,Broadcom Netlink Gigabit Ethernet BCM 5788, Realtek ALC272, Elantech PS/2 TouchPad Link to comment Share on other sites More sharing options...
artur-pt Posted August 12, 2012 Author Share Posted August 12, 2012 hello i use dsdt injection for alc272 and apple hda http://www.osx86.net/downloads.php?do=file&id=2526 this one good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
rakusson Posted August 13, 2012 Share Posted August 13, 2012 hello i use dsdt injection for alc272 and apple hda http://www.osx86.net/downloads.php?do=file&id=2526 this one good hack Hi,Thanks for tips. The problem with dsdt is that I could not compile dsdt last time so Mald0n compiled it for me. So even if I inject for alc272 there is no gurantee that I can re-compile it successfully. However, sound was working flawlessly in OS X Lion. Can I use the same kext for ML? If I have to use dsdt injection, can you give me a link of dsdt injection tutorial? Have you also tried to connect your computer with TV using HDMI? IF yes, how did you manage it? I get black screen after connecting HDMI cable with TV. sorry for asking lots of question. Quote eMachines E730G Intel Core i3-350M, 3 GB DDR3, ATI Mobility Radeon HD5470,Broadcom Netlink Gigabit Ethernet BCM 5788, Realtek ALC272, Elantech PS/2 TouchPad Link to comment Share on other sites More sharing options...
yral Posted October 4, 2012 Share Posted October 4, 2012 I just downloaded the RAW file and make a bootable usb using suse studio writer....it was boot properly and tryd the root command -v (verbose boot) -x (safe) -s (single user) -F (cache) mode. and also tryd GraphicsEnabler=no (disable graphics card drivers) USBBusFix=yes (to fix all problems with USB devices) but it's not wotking.......please help me to resolve the issue...... it stops ........please bare with me for limited picture quality.... please find the screen shot... [attachment=2]IMG_20121002_215036.jpg[/attachment] ----------------------------- [attachment=1]IMG_20121002_215127.jpg[/attachment] ------------------------------- [attachment=0]IMG_20121002_235404.jpg[/attachment] ------------------------------- i have Dell d630c laptop with c2d 2.0 processor 2 Gb of ram 80 GB of HDD Nvidia graphics thanks in advance. Quote Link to comment Share on other sites More sharing options...
yral Posted October 4, 2012 Share Posted October 4, 2012 Hey, I'm getting the same error. Do you know how you fixed it? I followed the normal procedure.. Previously this had happened to the install USB but I fixed it somehow, I think it was after adding NullCPUManagement.kext but it is not working for an installed copy which gets the same error.. Kernel version is set as 11.0.0.. This is wrong? Help! EDIT: Nevermind I got it to work, just had to start from scratch.. Hey, I'm getting the same error. Do you know how you fixed it? --------------------------------------------------------------------------- I just downloaded the RAW file and make a bootable usb using suse studio writer....it was boot properly and tryd the root command -v (verbose boot) -x (safe) -s (single user) -F (cache) mode. and also tryd GraphicsEnabler=no (disable graphics card drivers) USBBusFix=yes (to fix all problems with USB devices) but it's not wotking.......please help me to resolve the issue...... it stops ........please bare with me for limited picture quality.... please find the screen shot... [attachment=2]IMG_20121002_215036.jpg[/attachment] ----------------------------- [attachment=1]IMG_20121002_215127.jpg[/attachment] ------------------------------- [attachment=0]IMG_20121002_235404.jpg[/attachment] ------------------------------- i have Dell d630c laptop with c2d 2.0 processor 2 Gb of ram 80 GB of HDD Nvidea graphics thanks in advance. Quote Link to comment Share on other sites More sharing options...
