Guest Eryk
Lenovo B580 20144 - touchpad and wifi problems
Hi,
I've got a little problems. I succesfully installed Catalina with help from a friend, but even he wasnt able to make touchpad and wifi to work properly.
My touchpad is Synapticsย *SYN0334 (Lenovo pointing device). With current kexts etc it work till I putย two fingers on it. Then it freezes and wont work anymore.... Physical buttons (left and right mouse buttons) dont work either. I dunno whick kext use to make it work... I dont need support for 3+ fingers. I want only to make it work good enough to get rid of physical mouse...
Another problem is wifi. Main problem is that this is Dell 1702ย PCI\VEN_168C&DEV_002B&CC_0280 so its Atheros which is not officialy supported in Catalina... I tried Atherosย installer for macOS Mojave and Catalina 2.0 with disabled SIP, but it didnt work... Do I really have to change card to some Broadcom?
ย
Please tell me what you want me to send (config.plist etc), and I'll post it asap.
Thanks for reply :)
Link to comment
Share on other sites
about wifi, check this, (maybe you already did)
Build 1: Intel i5-6600 Skylake, GA-B150m-D3H, 8GB DDR4, ASROCK Radeon RX 590 Phantom Gaming X 8G OC, ย 512GB - LENSE20512GMSP34MEAT2TA (NVMe) - windows / Patriot Burst 240 Sata macOS Catalina, Fractal Design Meshify C Mini Dark TG, Corsair RM650x, Catalina 10.15.4./ Win10ย ย Build 2: Toshiba Tecra z40-c-11e, Intel Core i5 6200U Skylake, 8GB DDR3, Intel HD Graphics 520, Kingston UV500 240GB (SUV500/240G), BroadCom BCM94360CS2ย  +ย 12+6 Pin WIFI wireless card module to NGFF M.2,,ย Catalina 10.15.4ย ย Build 3: Optiplex 790, Intel Core i3 (2nd Gen) 2120 / 3,3GHz, Intel Q65 Express, 8GB DDR3 (4x2GB), MSI GTX 760 - 2GB, Patriot Burst SSD 120GB,ย BroadCom BCM94360CS2ย  +ย 12+6 Pin WIFI wireless card module to NGFF M.2,ย Catalina 10.15.4.ย Build 4:ย Lenovo L340-15IRH Gaming Laptop - Type 81LK (81LK0034CK), Intel Core i5 9300H (2,40-4,10GHz), 8GB DDR4 2400MHz (1x8), Intel UHD Graphics 630,ย Catalina 10.15.4ย / Windows 10 (Patriot Burst 240GB SATA3 SSD / M.2 PCIe SSD 512GB), DW1820a, atm not work: Wifi 5GHz, only 2,4 and BT.
Link to comment
Well I tried almost everything... I think that only what left is just buy on Ali any supported half-mini-pcie card based on BCM... For now I managed to use my android phone as router (usb tethering) so maybe its problematic (without usb cable there's no internet) but internet finally works without lan cable :P
Now I want to get rid of mouse so I really want to fix this touchpad... Any solutions anyone?ย
Link to comment
Show urs EFI/Clover folder
Link to comment
19 minutes ago, erystr said:
Heres my full EFI folder :)
post one full dump
Donation with Paypal HERE
Donation with Stripeย HERE
Donation with BuyMeaCoffeeย HERE
Donation with Mercado Livre HERE
Donation with Binanceย 0xdbe48ef6b158f1dd0035d7f49555c99e52f72714
Donation withย BTCย 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
Donation with PicPayย @danielnmaldonado
Donation with PiXย @danielnmaldonado@gmail.com
:guitar
Problems with Paypal Donate?ย Checkย HERE
Donated? Send me PM with files or useย DSDT Patch Requests
Link to comment
33 minutes ago, erystr said:
https://drive.google.com/open?id=1EPCah0dy1oQvsaP0UYiB7QLp4ddFxK7S
here you have this created fileย :)ย donated :)ย
check if work
CLOVER.zip
ur trackpad is just a correct kext
what wifi card?
ย
:guitar
Link to comment
Well I dont really know does this fixed this because now after your fix i have error "OCABC:ย found legacy aptiomemoryfix driver!" and I cant boot OSX xD
I replaced files from your archive and merged the same folders (like kexts with kexts etc)ย
Edited by erystr
Link to comment
43 minutes ago, erystr said:
and I cant boot OSX
post one photo
:guitar
Link to comment
Clover even doesnt start. This error i mentioned only displays at booting...ย
back to ur old efi folder and disable _dsm to xdsm patch, put my dsdt into clover/acpi/patched
:guitar
Link to comment
35 minutes ago, erystr said:
With a little problems but I recovered working backuped efi (i write it on hack).
ever stay with one bootable usb with ur files in efi partition, easy boot to system if need
:guitar
Link to comment
Okay, i put dsdt and it oots up succesfully but I dunno how to disableย _dsm to xdsm patch...ย
Also, while touchpad is freezed I invented that when i put 4 fingers separated on touchpad, it gets back to "normal", until i put 2 fingers again on it...
Link to comment
Sorry for bothering anybody... Problem is solved.
I deleted all voodool2c kexts, left only voodoo-input/hda/ps2 and also I deleted existing ps2 and downloaded Rehabman's ps2 kext and now after restart everything works perfectly except 3+fingers gestures, and some more advanced 2-finger gestures like zoom in/out.
But I'm very happy with working fully working touchpad+buttons+2f-scroll... Only wifi card left but I'm still searching for working broadcom cardย :Pย
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
The popup will be closed in 15 seconds...
