Cassio Posted January 2, 2012 Share Posted January 2, 2012 into method label PAPR insert begin Return (Zero) end  into method label _CRS parent_label ^^MEM2 insert begin Return (Buffer (One)\n {\n 0x00\n }) end  into method label _PRW parent_label GLAN remove_entry  You will also need this into all code_regex External\s\(\\TNOT\) remove_matched Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
stuck Posted January 2, 2012 Author Share Posted January 2, 2012 Thanks Cassio, I'm getting a couple of errors and don't quite know how to fix it...  // into method label _CRS parent_label ^^MEM2 insert Method (_CRS, 0, NotSerialized) { If (IGDS) { Return (CRS) } Return (Buffer (One) { ¬†¬†0x00 }) } // into method label _PRW parent_label GLAN remove_entry end Invalid command // into all code_regex External\s\(\\TNOT\) remove_matched end Invalid command Quote HP DV7-6B32US i7-2670QM 2.2ghz Mobile intel HM65 Express Chipset Board CT#: PCKVP2A2F1P5YV Bios: F.02 17" display 1600x900 4Gb DDR3 Intel HD Graphics 3000 Blu-ray player Broadcom 4313 b/g/n wifi (14e4:4727) Realtek PCIe GBE ethernet (10ec:8168) Link to comment Share on other sites More sharing options...
Cassio Posted January 2, 2012 Share Posted January 2, 2012 You have to put ; after each command (unless it's the last in the file), not "end" ("end" is only when there's "begin") into method label _PRW parent_label GLAN remove_entry; into all code_regex External\s\(\\TNOT\) remove_matched; About those ¬†¬†chars I don't know, try to delete all before 0x00 and fill with spaces, maybe tabs were replaced by invalid chars. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
stuck Posted January 5, 2012 Author Share Posted January 5, 2012 Cassio and Oldnapalm, I want to thank you again for your help in getting my DSDT patched. I'm back at work this week so I haven't done much... I will be posting my Lion install steps over at tonycrap and linking my dsdt steps back to here. The all in one patch for my DV7-6B32US is attached. I repatched my DSDT using this and it works. Should I submit this patch to a specific thread? The Fn keys are weird though, the Volume keys seem to change the volume as reflected by the Icon on the task bar and the volume bar moving on the screen. But in reality, the audio volume didn't change. Also, after using the aio patch to patch a fresh dsdt (instead of patching previously patched dsdt), I started experimenting again with your suggestions to get the LHS usb to work. And it seems that Oldnapalm's patch triggered this during boot-up. The port still doesn't work, but I'm wondering if it is a good sign? Jan 5 08:16:16 localhost kernel[0]: USBF: 3.999 [0xffffff8012fb0000] The IOUSBFamily was not able to enumerate a device. Jan 5 08:16:16 localhost kernel[0]: USBF: 4.841 [0xffffff8012fb0000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in. It will keep retrying. (Port 2 of Hub at 0x1a100000) Jan 5 08:16:16 localhost kernel[0]: USBF: 8.270 [0xffffff8012fb0000] The IOUSBFamily was not able to enumerate a device. Jan 5 08:16:16 localhost kernel[0]: USBF: 9.128 [0xffffff8012fb0000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in. It will keep retrying. (Port 2 of Hub at 0x1a100000) Jan 5 08:16:16 localhost kernel[0]: USBF: 9.992 [0xffffff8012fb0000] The IOUSBFamily gave up enumerating a USB device after 10 retries. (Port 2 of Hub at 0x1a100000) Jan 5 08:16:16 localhost kernel[0]: USBF: 10. 11 [0xffffff8012fb0000] The IOUSBFamily was not able to enumerate a device. DV7-6B32US.txt.zip Quote HP DV7-6B32US i7-2670QM 2.2ghz Mobile intel HM65 Express Chipset Board CT#: PCKVP2A2F1P5YV Bios: F.02 17" display 1600x900 4Gb DDR3 Intel HD Graphics 3000 Blu-ray player Broadcom 4313 b/g/n wifi (14e4:4727) Realtek PCIe GBE ethernet (10ec:8168) Link to comment Share on other sites More sharing options...
Cassio Posted January 5, 2012 Share Posted January 5, 2012 Thanks, added your patch here http://Olarila.com/forum/packs.php Credits here http://Olarila.com/forum/viewtopic.php?f=19&t=385 About the USB issue I don't know, will let you know if I find something. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
stuck Posted January 23, 2012 Author Share Posted January 23, 2012 A little update on the USB issue... I feel like an idiot. It turns out that usb 1A has been working all along. I just couldn't tell, because it is an internal usb, and the TrueVisionHD webcam connected to it. The left side USB that I have been having problems with is actually USB 3.0 by NEC. From ubuntu, LHS USB is: USB Controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 04) 1033:0194 I tried installing the NEC/Renasys USB3 driver with/without the IOUSBFamily rollback. Eitherway it didn't work. When I plug anything into those ports, the system crashes and freezes. But since I can't even see this USB controller in my IORegEditor, I'm back to thinking this requires a DSDT fix??? (correct me if I'm wrong) Quote HP DV7-6B32US i7-2670QM 2.2ghz Mobile intel HM65 Express Chipset Board CT#: PCKVP2A2F1P5YV Bios: F.02 17" display 1600x900 4Gb DDR3 Intel HD Graphics 3000 Blu-ray player Broadcom 4313 b/g/n wifi (14e4:4727) Realtek PCIe GBE ethernet (10ec:8168) Link to comment Share on other sites More sharing options...
Cassio Posted January 23, 2012 Share Posted January 23, 2012 Have you tried this? http://www.lacie.com/us/more/index.htm?id=10112  I'm back to thinking this requires a DSDT fix??? (correct me if I'm wrong) You may be right, but I don't know any patch for this. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
stuck Posted January 27, 2012 Author Share Posted January 27, 2012 It appears that the USB 3 driver that I used from multishit IS a hack of the LaCie drivers you referenced. And when I have that installed, IORegistryExplorer does see the USB 3 controller but when anything is plugged in to it, the system locks up... Quote HP DV7-6B32US i7-2670QM 2.2ghz Mobile intel HM65 Express Chipset Board CT#: PCKVP2A2F1P5YV Bios: F.02 17" display 1600x900 4Gb DDR3 Intel HD Graphics 3000 Blu-ray player Broadcom 4313 b/g/n wifi (14e4:4727) Realtek PCIe GBE ethernet (10ec:8168) Link to comment Share on other sites More sharing options...
MAD AUDI SCIENTIST Posted May 24, 2012 Share Posted May 24, 2012 Hello, sorry for bumping this thread. I love the proces you guys had in making this laptop work. It's awesome to see how well the Olarila community gets things done. I just wanted to ask about the BCM4313 card in this machine. Did you end up getting it work? Oldnapalm mentioned that there wasnt a solution, but i was wondering if anyone has had any progress? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
