koolkunal247
No sound after sleep and brightness keys remapping pls help
[ref]koolkunal247[/ref], device is LPCB/KBD0?
Keyboard device KBD0
Added in 3 minutes 43 seconds:
Can you like patch it for me it’s very confusing
When I press Fn+F2 which is my brightness I get 3c=72 down and if I press F2 result comes Q1C
Now I don’t understand when we patch what should I replace Q** with ?
Link to comment
Share on other sites
[ref]koolkunal247[/ref], It is always good practice to upload your sendme files so others can easily extract extra information from it.
Donate
Gitter Chat
MSI B360 Gaming Arctic
Link to comment
when I'm patching the keys I get this
Your KBD0 device path is wrong. Hence, the error.
Your I2C track pad is not detected because you did not implement windows emulation or "OS Check Fix".
I wonder why you are not using the patched DSDT posted HERE ?
Your kext folder needs cleaning up. I2C SSDT is obviously not working.
Donate
Gitter Chat
Link to comment
[ref]koolkunal247[/ref], Replace clover folder.
CLOVER.zip
Open terminal type :
sudo kextcache -i /
Press ENTER
Reboot.
Upload new sendme.
Donate
Gitter Chat
Link to comment
Man you're amazing ! My touchscreen started to work
My Trackpad stopped working I've connected a wireless mouse and created the send me file
Do you have access to windows and check the ACPI ID of the track pad?
https://imgur.com/FIJPN8P
Donate
Gitter Chat
Link to comment
no ill have to install windows for that currently m only on Macos
My suspicion your trackpad is PS2.
Replace DSDT with new one and replace VoodooPS2Controller kext.
Reboot and upload new send me. Check if track pad works with this voodoops2 kext. Do not remove VoodooI2C and VoodooI2cHID kexts!
Archive.zip
Donate
Gitter Chat
Link to comment
[ref]koolkunal247[/ref], Seems like everything is working good. For your brightness hotkeys, follow the instructions at the link here https://Olarila.com/forum/viewtopic.php?f=28&t=8396.
A picture of the console when hotkeys are pressed is required. Otherwise, its a pretty straight forward process. Good Luck!
Donate
Gitter Chat
Link to comment
I reinstalled Mac and tried and the brightness keys are working and now the only thing doesn’t work is gestures on my trackpad is it because it’s ps2 ?
need to read rehabman voodoops2controller support. I think can work with few gestures but need to configure. I never used laptop with ps2 trackpad
Donate
Gitter Chat
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Hey! Welcome to Olarila.com  Please Disable Your ADBlocker!
The popup will be closed in 15 seconds...
