Hackintosh Guide - Catalina / Big Sur on Mobos Series 100, 200, 300, 400 and 500 with OpenCore Bootloader
1 hour ago, jasperlevi said:
Hey
integrated video? if yes use -igfxvesa and change smbios
Link to post
Share on other sites
  • 3 weeks later...
  • Replies 733
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Fixed it. Need to set XHCI handoff enabled in BIOS.
Buenos días Cuando el ordenador entra en reposo y quiero activarlo tocando el mouse o el teclado se reinicia. Probé muchas cosas, como darkwake, y nada funciona. Alguna solución? Saludos y g
same folder serie 100/200/300
On 5/23/2021 at 7:45 PM, MaLd0n said:
use mouse keyboard usb
Hi Mald0n using USB keyboard and mouse on port 2.0, I always have the same image on boot. at startup I see that there are problems with the usb ports :(
EDIt: fixed by disabling KErnel - XhciPortLimit
Edited by clockT
Link to post
  • 2 weeks later...
I dont know why but the installation Big Sur to copy USB Installer to my HD is okay.
But when I reboot and choose start from the HD I get this error and anything works any more 😔
somebody have this problem before?
my PC is i7-8700 in mobo h370-gaming and radeon RX 560
boot-error.jpeg.zip
Edited by Patrícia Machado
Link to post
great! everything is running now! thks MaLd0n!!
the solution was run reset nvram before continue the install process 😅
my Intel stay very hot when I am installing tools in terminal. Do you know something to disable the intel turbo boost by "default"?
Link to post
:cap-Please Disable Your ADBlocker-:cap
