Hackintosh Guide - Catalina / Big Sur on Mobos Series 100, 200, 300, 400 and 500 with OpenCore Bootloader
  • Replies 734
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Fixed it. Need to set XHCI handoff enabled in BIOS.
Buenos días Cuando el ordenador entra en reposo y quiero activarlo tocando el mouse o el teclado se reinicia. Probé muchas cosas, como darkwake, y nada funciona. Alguna solución? Saludos y g
same folder serie 100/200/300
Pessoal, meu problema está sendo o seguinte:
tenho 2 gigabyte z370m aorta gaming, em uma não consegui sair do 2º boot para a configuração final do Catalina.
Na segunda mobo consegui passar por esta etapa, mas toda vez que chega na configuração do Osx Catalina a máquina restarta, as vezes na logo, as vezes na config de rede, as vezes ativação da siri, mas não passa disto e não consigo sair disto.
Alguém sabe me dizer onde estou errando?
Eu agradeço desde já.
mobo: gigabyte z370m Aorus Gaming
Cpu i7-9700 Coffee Lake, Cache 12MB, 3.0GHz (4.7GHz Max Turbo), LGA 1151 - BX80684i79700
Ram:2x Crucial Ballistix Sport LT, 16GB, 2666MHz, DDR4, CL16, Vermelho - BLS16G4D26BFSE
Fonte:CX 750m Corsair.
Link to post
Share on other sites
Not sure if this was solved but mine did this. I needed to boot with SATA ports in bios disabled. Then update IntelMausiEthernet to IntelMausi. Seems unrelated I know.
I also added SATA-Unsupported.kext. You can see in IOReg you compatible ID for your SATA. You can see in the kext where it has the matching one. So not only are we booting with SATA now it's also not using the Generic driver.
SATA-unsupported.kext.zip
Link to post
Hi Maldon,
Is there any chance you could help with ACPI, SSDT files?
I am trying to get OC working to install Catalina 10.15.2 on my build:
AMD Ryzen 7
Aorus x570i Pro wifi
5700 XT
I can't run the app you linked in the first post as I don't have Macos installed on this machine, just Windows.
Thank you in advance!
Link to post
  • MaLd0n changed the title to Hackintosh Guide - Catalina / Big Sur on Mobos Series 100, 200, 300, 400 and 500 with OpenCore Bootloader
:cap-Please Disable Your ADBlocker-:cap
