onemanosx
I followed the guide, everything worked well, thanks very much for the help. im trying to figure out how to do this patch on the last days, and finally achieved because of this post :)
glad the guide worked well for you!! :guitar
Donate
Gitter Chat
MSI B360 Gaming Arctic
Link to comment
Share on other sites
does not work(
of course it wont work. You did not patch clover with I2C patches nor did you implement windows emulation patch.
https://imgur.com/GmxhQuE
https://imgur.com/v8HUNqN
Use these files, reboot and generate new sendme files.
Archive.zip
Donate
Gitter Chat
Link to comment
[ref]zzmagus[/ref], Your voodooI2C kext is corrupt. Weird.
Download new kexts here. https://github.com/alexandred/VoodooI2C/releases. Use only voodooI2C and VoodooI2CHID kexts.
Rebuild cache and permissions.
Use terminal and type:
sudo kextcache -i /
Reboot and generate send me files.
Donate
Gitter Chat
Link to comment
[ref]zzmagus[/ref], Your track pad is now working in Polling mode as per kernel log and IOReg. Please confirm.
kernel: (kernel) VoodooGPIOSunrisePointLP::Loading GPIO Data for SunrisePoint-LP
kernel: (kernel) VoodooGPIOSunrisePointLP::VoodooGPIO Init!
kernel: (kernel) VoodooGPIOSunrisePointLP::VoodooGPIO Initializing Community 0
kernel: (kernel) VoodooGPIOSunrisePointLP::VoodooGPIO Initializing Community 1
kernel: (kernel) VoodooGPIOSunrisePointLP::VoodooGPIO Initializing Community 2
kernel: (kernel) VoodooI2CPCIController::pci8086,9d60 Starting I2C controller
kernel: (kernel) VoodooI2CPCIController::pci8086,9d60 Set PCI power state D0
kernel: (kernel) VoodooI2CPCIController::pci8086,9d60 Publishing nub
kernel: (kernel) VoodooI2CControllerDriver::pci8086,9d60 Probing controller
kernel: (kernel) VoodooI2CControllerDriver::pci8086,9d60 Found valid Synopsys component, continuing with initialisation
kernel: (kernel) VoodooI2CControllerNub::pci8086,9d60 SSCN not implemented in ACPI tables
kernel: (kernel) VoodooI2CControllerNub::pci8086,9d60 FMCN not implemented in ACPI tables
kernel: (kernel) VoodooI2CControllerDriver::pci8086,9d60 Warning: Error getting bus config, using defaults where necessary
kernel: (kernel) VoodooI2CControllerDriver::pci8086,9d60 Publishing device nubs
kernel: (kernel) VoodooI2CControllerDriver::pci8086,9d60 Found I2C device: SYNA2B33
kernel: (kernel) VoodooI2CControllerDriver::VoodooI2CDeviceNub Warning: Incompatible APIC interrupt pin (0x57 > 0x2f) and no GPIO interrupts found; if your chosen satellite implements polling then VoodooI2CDeviceNub will run in polling mode.
kernel: (kernel) VoodooI2CHIDDevice::SYNA2B33 Warning: Could not get interrupt event source, using polling instead
Donate
Gitter Chat
Link to comment
did not help...
Try replace FakeSMC+ ACPIBatteryManager with SMCBatteryManager + VirtualSMC kext.
sudo kextcache -i /
Reboot and generate new send me files with new battery kext and virtualsmc
Donate
Gitter Chat
Link to comment
I did not find any improvements ...
Lets try Interrupt mode and see if situation improves.
DSDT-Interrupt.aml.zip
Reboot and generate new send me files.
Donate
Gitter Chat
Link to comment
The touchpad worked fine, but the settings do not open
I dont understand what you mean by settings do not open. No sendme file.
Donate
Gitter Chat
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
