ramzi Posted August 30, 2018 Author Share Posted August 30, 2018 [ref]Mirone[/ref], yes didnt work Added in 1 minute 6 seconds: [ref]Mirone[/ref], and my battery percent disappered and fn keys not working. Quote Link to comment Share on other sites More sharing options...
Mirone Posted August 30, 2018 Share Posted August 30, 2018 @ramzi, try this: AppleHDA-v3.zip Added in 1 minute 1 second: Mirone, and my battery percent disappered and fn keys not working. No idea, I just made some changes in your DSDT related to audio. Quote Link to comment Share on other sites More sharing options...
ramzi Posted August 30, 2018 Author Share Posted August 30, 2018 No idea, I just made some changes in your DSDT related to audio. okay you just say me which changes okay? maybe i will do it myself Added in 12 minutes 35 seconds: [ref]Mirone[/ref], with v1 nothing is working, with V2 and v3 internal speakers are working, headphones don't showing and microphone is showing but not working Quote Link to comment Share on other sites More sharing options...
Mirone Posted August 30, 2018 Share Posted August 30, 2018 How are you testing this? First, the headphone will not appear even unless you plug it in, because it is switch, do not expect ComboJack to work because it is necessary to use the KNNSpeed solution and even then it is not guaranteed that iso will work. Quote Link to comment Share on other sites More sharing options...
ramzi Posted August 30, 2018 Author Share Posted August 30, 2018 [ref]Mirone[/ref], yes headphones work when i plug. but what about microphone? Quote Link to comment Share on other sites More sharing options...
Mirone Posted August 30, 2018 Share Posted August 30, 2018 about microphone internal microphone? Quote Link to comment Share on other sites More sharing options...
ramzi Posted August 30, 2018 Author Share Posted August 30, 2018 [ref]Mirone[/ref], yes Quote Link to comment Share on other sites More sharing options...
Mirone Posted August 30, 2018 Share Posted August 30, 2018 yes try this: AppleHDA-v3_mic FIx.zip Quote Link to comment Share on other sites More sharing options...
ramzi Posted August 30, 2018 Author Share Posted August 30, 2018 [ref]Mirone[/ref], thank you very much))) internal speakers, microphone and headphones working very well. but now say me please what did you change in config.plist and dsdt? Quote Link to comment Share on other sites More sharing options...
Mirone Posted August 30, 2018 Share Posted August 30, 2018 I have to quit now, later I'll send you another kext so you can test the External Microphone, to see the modifications I made make a diff using DiffMerge. Quote Link to comment Share on other sites More sharing options...
ramzi Posted August 30, 2018 Author Share Posted August 30, 2018 [ref]Mirone[/ref], okay. no problem) Added in 35 minutes 37 seconds: [ref]Mirone[/ref], thank you again Mirone))) everything is okay. i solved my problems)i am very grateful to you for your help))) will my sound work in mojave with this applehda? or i will patch applehda again? Quote Link to comment Share on other sites More sharing options...
Mirone Posted August 30, 2018 Share Posted August 30, 2018 okay. no problem) Try this:AppleHDA-v4.zip Let me know if your external microphone works, use an iphone headset or similar. Quote Link to comment Share on other sites More sharing options...
ramzi Posted August 30, 2018 Author Share Posted August 30, 2018 [ref]Mirone[/ref], v4 not working Quote Link to comment Share on other sites More sharing options...
Mirone Posted August 30, 2018 Share Posted August 30, 2018 v4 not working try this:AppleHDA-v5.zip Quote Link to comment Share on other sites More sharing options...
ramzi Posted August 30, 2018 Author Share Posted August 30, 2018 [ref]Mirone[/ref], headphones, microphone and internal work fine. You asking me about headphones's microphone? Quote Link to comment Share on other sites More sharing options...
Mirone Posted August 30, 2018 Share Posted August 30, 2018 You asking me about headphones's microphone? yes. Quote Link to comment Share on other sites More sharing options...
ramzi Posted August 30, 2018 Author Share Posted August 30, 2018 [ref]Mirone[/ref], this file v5 also not working. for me internal microphone"s working enough. thank you again Mirone) will my sound work in mojave with this applehda? or i will patch applehda again? Quote Link to comment Share on other sites More sharing options...
Mirone Posted August 30, 2018 Share Posted August 30, 2018 will my sound work in mojave with this applehda? or i will patch applehda again? for Mojave follow these steps: http://Olarila.com/forum/viewtopic.php?f=28&t=4144 Quote Link to comment Share on other sites More sharing options...
ramzi Posted August 30, 2018 Author Share Posted August 30, 2018 for Mojave follow these steps: http://Olarila.com/forum/viewtopic.php?f=28&t=4144 okay.thanks) Quote Link to comment Share on other sites More sharing options...
Mirone Posted August 31, 2018 Share Posted August 31, 2018 Appreciate if you can post your dsdt file for our analysis. Thanks. try this:AppleHDA_ALC255_v1.zip Use Layout_id=2 in your DSDT or config.plist Quote Link to comment Share on other sites More sharing options...
ramzi Posted November 17, 2018 Author Share Posted November 17, 2018 hello. can someone help me with the updating applehda to Mojave? Added in 16 seconds: I didn't do that((( Quote Link to comment Share on other sites More sharing options...
ramzi Posted November 17, 2018 Author Share Posted November 17, 2018 I tried to do that, but I dint understand the third step "script de bcc9". Explain me/please Quote Link to comment Share on other sites More sharing options...
nadeem_khan7 Posted February 20, 2019 Share Posted February 20, 2019 even im having the same issue on my asus x541uvk☹️ Quote Link to comment Share on other sites More sharing options...
juanvascas Posted March 12, 2019 Share Posted March 12, 2019 I have a dell G7 and my microphone is not working (internal mic) may the AppleHDA v3 fix kext from Mirone work for me? I see both laptops have the alc256 Quote Link to comment Share on other sites More sharing options...
