Hidden.be Posted August 1, 2018 Author Share Posted August 1, 2018 Run the RunMe.app and send me files. Â Here is RunMe Files.. The RunMe is a Awesome App. Send me Mys-MacBook-Pro.zip Quote Link to comment Share on other sites More sharing options...
Mirone Posted August 1, 2018 Share Posted August 1, 2018 try this: CLOVER.zip Quote Link to comment Share on other sites More sharing options...
Hidden.be Posted August 2, 2018 Author Share Posted August 2, 2018 try this: CLOVER.zip (1.46 MiB) Downloaded 1 time  No result.Not Working Quote Link to comment Share on other sites More sharing options...
Mirone Posted August 2, 2018 Share Posted August 2, 2018 What exactly did not work? Quote Link to comment Share on other sites More sharing options...
Hidden.be Posted August 2, 2018 Author Share Posted August 2, 2018 What exactly did not work? Â Battery icon and battery status... Audio issue: Audio works good but But sometimes it makes a crackling sound. after reboot laptop audio works fine.. And trackpad is working but system preferences/trackpad empty .. Brightness refresh rate missing... Send me Mys-MacBook-Pro.zip Quote Link to comment Share on other sites More sharing options...
Mirone Posted August 3, 2018 Share Posted August 3, 2018 And trackpad is working but system preferences/trackpad empty .. https://www.insanelymac.com/forum/topic/315768-blank-trackpad-setting-in-sierra/ Audio issue: Audio works good but But sometimes it makes a crackling sound. after reboot laptop audio works fine.. Use:[hideurl=https://bitbucket.org/RehabMan/os-x-eapd-codec-commander/downloads/] codeccommander.kext[/hideurl] Battery icon and battery status... No idea... Brightness refresh rate missing... Make sure you have AppleBacklightInjector.kext installed. Quote Link to comment Share on other sites More sharing options...
Hidden.be Posted August 3, 2018 Author Share Posted August 3, 2018 Make sure you have AppleBacklightInjector.kext installed.  Already installed ...but no result..  Use: codeccommander.kext  Can I use "had-verb" Quote Link to comment Share on other sites More sharing options...
