ricardogcs Posted November 10, 2018 Share Posted November 10, 2018 For anyone else, if you see the below at the boot manager you need to go into the disk utility, delete the 35GB virtual HDD partition and recreate it using the mac OS. Thanks! Quote Link to comment Share on other sites More sharing options...
hackadventure Posted November 23, 2018 Share Posted November 23, 2018 The virtualbox machine is reaching the AppleIntel8254XEthernet: Ethernet address xx:xx:xx:xx:xx:xx and then the virtual machine stalls. It does not move ahead after waiting. What do I do? Quote Link to comment Share on other sites More sharing options...
Kaio Patrick Posted November 29, 2018 Share Posted November 29, 2018 DISCO PARA A INSTALAÇÃO DO HIGH SIERRA NÃO APARECE? / DOESN'T APPEAR ANY DISK IN HIGH SIERRA INSTALLATION? ---------------------------------------------------PORTUGUÊS ------------------------------------------------------- Problema chato, com muita dor de cabeça consegui achar uma solução! Vá em DISK UTILITY / UTILITÁRIOS DE DISCO na aba de seleção de ações Escolha o disco referente ao seu criado nas configurações do VirtualBox Aperte em Erase/apagar ou formatar, nas configurações da aba que aparece Escolha "APFS" e alguma coisa de GUID..."NÃO MUDE O NOME DO DISCO". E depois aperte em ERASE ou APAGAR(NÃO SEI COMO QUE TÁ EM PT). Reinicie e faça o procedimento padrão, e lá vai estar o disco. ---------------------------------------------------ENGLISH ------------------------------------------------------- Annoying error...after trying over and over in a strong headache I finally got the solution! Go ahead in DISK UTILITY option localizated in the action tab Select the disk that you created on the VirtualBox configuration Press Erase then will appear a tab Choose "APFS" and GUID, DO NOT CHANGE THE DISK NAME!!! Then press ARASE and restart your virtualmachine Proceed the sequence to install and the disk will be in there!! Srry about my english, I'll let you to correct my grammatic erros xD Quote Link to comment Share on other sites More sharing options...
hackadventure Posted December 8, 2018 Share Posted December 8, 2018 I am still getting stalled at - AppleIntel8254XEthernet: Ethernet address 08:00:27:5e:01:50 using Mountain Lion Virtual ISO. No one has replied about my post since November 23rd. Quote Link to comment Share on other sites More sharing options...
hackadventure Posted December 9, 2018 Share Posted December 9, 2018 After waiting for more time and disabling Network adapter and Audio I get this... Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted December 9, 2018 Author Administrators Share Posted December 9, 2018 [ref]hackadventure[/ref], Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
usd311 Posted December 14, 2018 Share Posted December 14, 2018 hey I'm stuck with the exact same problem as RoyalC with the highsierra iso. I ran the .bat and tried it manually. sure the machine name is correct. tried it with the El Capitan iso, ending in critical boot error before installation process started. anyone got similar experience and can help me? any ideas appreciated. thanks. Quote Link to comment Share on other sites More sharing options...
zojith Posted December 19, 2018 Share Posted December 19, 2018 While installing, it stuck at "Select the disk where you want to install Mac OS". There is no option to select the disk. Quote Link to comment Share on other sites More sharing options...
kpereira Posted December 19, 2018 Share Posted December 19, 2018 Nice! Works Just fine!! I used VBox in ubuntu and it works like a charm. Thanks MaLd0n, you're awesome! Adicionado a 2 minutos 33 segundos: There is no option to select the disk. if you is using HS, read the end of the tutorial, there is specific tips to run HS. Quote Link to comment Share on other sites More sharing options...
km_ Posted December 29, 2018 Share Posted December 29, 2018 RoyalC, I am in the same boat as you. But I tried on another computer and it finally got beyond the randomseed bit. The first PC I was running into this issue was an AMD system, and the one that finally started to get past the randomseed part is Intel. Is this similar to your situation? [edited] I am now getting a boot loop with all the text on the screen so now I gotta figure how to get the installer to launch... I am attaching the Vbox log file if someone can help me figure out why the Installer wont load and why it keeps rebooting... VBox.log Quote Link to comment Share on other sites More sharing options...
blackiceliru13 Posted December 31, 2018 Share Posted December 31, 2018 Hello, after install High sierra on virtual machine I can`t get into boot manager f12 doesn`t work, What I am doing wrong? Quote Link to comment Share on other sites More sharing options...
adsfsdfsdf Posted January 2, 2019 Share Posted January 2, 2019 Hello, I followed this tutorial using mountain lion, thus I did not follow the additional steps. I have gotten the OS to boot in virtual box however its totally broke. I cannot run sudo in terminal, I get a error "sudo: unable to cache user root, already exists". I try to install an app from a dmg but it asks me to authenticate with name and password - I enter my name and password and it doesn't work. I even changed password in system and still didnt work. Quote Link to comment Share on other sites More sharing options...
Averus Posted January 4, 2019 Share Posted January 4, 2019 I keep having a black screen with code on during install and the mac os X installer won't come up. my fix is to run cmd commands with closed Vbox gui Quote Link to comment Share on other sites More sharing options...
Quey_quick Posted January 23, 2019 Share Posted January 23, 2019 my fix is to run cmd commands with closed Vbox gui I tried this, still stuck on boot loop Quote Link to comment Share on other sites More sharing options...
abobora Posted February 28, 2019 Share Posted February 28, 2019 Opa... tranquilo? =) algumas perguntas bobas relacionadas - eu consigo fazer este mesmo processo pelo Hyper-V? Pois uso docker na minha maquina e eles dois não se combinam muito bem juntos =( - minha placa de vídeo é uma Geforce 1050Ti (notebook), e vi que ainda não tem driver para ela, assim perdendo o HDMI junto... já tem algum relato dela funcionando? Apesar de ter visto drivers para ela aqui, mas não vi relatos - meu note é um i7 8750H, placa de vídeo acima (é um Dell G7 15))... já é possível instalar um Mojave nele ou apenas o HS mesmo? - se não posso instalar o Mojave no note, posso instalar por VM? Ou não por conta dos driver ou algo assim? Valeu =) ----------------------------------------------- english hey man... how's going? Hope fine some silly questions related to this thread - can I do this same process using Hyper-V? Because I use Docker here and they usually don't go along very well =\ - my video card is a GeForce 1050Ti (laptop), and I noticed that there is no driver for it yet, so I'll be losing my HDMI together. Does anyone had this same situation and its working? Despite I saw the drivers here, I haven't seen anyone saying a word regarding this crd - my laptop is a i8750H, video card above ((Dell G7 15))... can I install Mojave on it or just HS? - if I can't install Mojave on the laptop, can I install it via VM? Or no because drivers or something? Cheers =) Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted February 28, 2019 Author Administrators Share Posted February 28, 2019 [ref]abobora[/ref], se o seunotebook for optimus, vc tem de desativar a nvidia e usar somente a intelHD, não é legal, se não for optimus, instale o high sierra Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
abobora Posted February 28, 2019 Share Posted February 28, 2019 então Maldon... pelo que percebi, a 1050Ti tem o Optimus... mas se eu a desabilitar, perco o HDMI, aí não terei como usar outro monitor... correto? E sobre o processo de instalar usando o Hyper-V ao invés do Virtualbox... é possível? Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted February 28, 2019 Author Administrators Share Posted February 28, 2019 [ref]abobora[/ref], vc popde deixar as duas habilitadas e ver se o HDMI funciona nunca usei Hyper V Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
abobora Posted February 28, 2019 Share Posted February 28, 2019 ok entao @MaLd0n.... vou tentar aqui primeiro por VM usando o Hyper-V... se não conseguir, vou pro virtualbox e penso no que eu farei num futuro proximo, tentarei fazer a instalação aqui no note então.. valeu =) Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted February 28, 2019 Author Administrators Share Posted February 28, 2019 [ref]abobora[/ref], Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
gelaskaca Posted April 4, 2019 Share Posted April 4, 2019 is this hackintosh only for virtual machine or also can apply on real hardware non Apple (notebook especially) ? Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted April 4, 2019 Author Administrators Share Posted April 4, 2019 [ref]gelaskaca[/ref], https://Olarila.com/forum/viewtopic.php?f=50&t=8685 Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
gelaskaca Posted April 4, 2019 Share Posted April 4, 2019 Unread post by MaLd0n » 04 Apr 2019, 08:32 gelaskaca, viewtopic.php?f=50&t=8685 thanks, i'll try. Quote Link to comment Share on other sites More sharing options...
frnk7 Posted May 10, 2019 Share Posted May 10, 2019 -Now run "Configure VM.bat" (Machine Name in .bat is Mac, if you use other name run manually and change Machine Name) After I'v selected the ISO from VirtualBox on my VM, I have to crea a file named "Configure VM.bat" with source code you had provided and run? Thanks Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted May 10, 2019 Author Administrators Share Posted May 10, 2019 [ref]frnk7[/ref], don't need, just run commands. i think files is removed after last forum updates Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
