free1975yuly 0 Posted January 19, 2019 Share Posted January 19, 2019 free1975yuly, DSDT.aml.zip (39.66 KiB) Downloaded 3 times check here Arquivo Comprimido.zip (487.37 KiB) Downloaded 2 times Did you add PNLF in that DSDT? Because no method working here (I tried use AppleBacklightFixUp.kext + PNLF.aml from RehabMan, I tried AsusACPIBacklightPanel (sended by you)...nothing. I had to add PNLF in Clover, because without this check I have no backlight slyder in options and fn+f5 or fn+f6 does not work. Thanks! Link to post Share on other sites
Administrators MaLd0n 1,001,056 Posted January 19, 2019 Author Administrators Share Posted January 19, 2019 [ref]free1975yuly[/ref], don't need it, whatevergreen have a brightness control now Added in 14 seconds: check if have PNLF in ur DSDT Link to post Share on other sites
free1975yuly 0 Posted January 20, 2019 Share Posted January 20, 2019 free1975yuly, don't need it, whatevergreen have a brightness control now Added in 14 seconds: check if have PNLF in ur DSDT Since DSDT is maded by you, I still cannot read in DSDT (I'm beginner with this!), that is the reason I asked you for. With enabled PNLF in Clover the slyder is present also the brightness key functioning...but that's all: just 2 levels of screen brightness (100% and 10%, when black I cannot revert back so I have to restart), I have whatevergreen in Clover kexts also. Still not managed the keyboard backlights to sleep. Thanks again for your time! Link to post Share on other sites
iamrahulmaurya 0 Posted January 26, 2019 Share Posted January 26, 2019 Link to post Share on other sites
rageodo 0 Posted January 27, 2019 Share Posted January 27, 2019 hey the youtube video is done for notebooks. Does anyone have a mirror? Link to post Share on other sites
Administrators MaLd0n 1,001,056 Posted January 27, 2019 Author Administrators Share Posted January 27, 2019 [ref]rageodo[/ref], i'll update in this week Link to post Share on other sites
uran0s 0 Posted February 10, 2019 Share Posted February 10, 2019  Olá Mald0n, Envio em anexo file runme.zip com ficheiros para criação DSDT, e se possÃvel, ajuda a remodelar a pasta clover, sff. Portátil LENOVO Ideada 520, i7-8550U, ntel® UHD Graphics 620, GeForce® 940MX. Obrigado, Até já, joana.zip Link to post Share on other sites
Administrators MaLd0n 1,001,056 Posted February 11, 2019 Author Administrators Share Posted February 11, 2019 Portátil LENOVO Ideada 520, i7-8550U, ntel® UHD Graphics 620, GeForce® 940MX. CLOVER.zip novo SEND_ME depois de reiniciar Link to post Share on other sites
uran0s 0 Posted February 11, 2019 Share Posted February 11, 2019 CLOVER.zip novo SEND_ME depois de reiniciar  Desde já, muito obrigado. Assim de repente, continua a não dar audio, wifi, usb3. Quando faço sleep, ele desliga de facto o ecrã. mas fica a piscar a luz das teclas, é normal? A NVIDIA só dará no High Sierra? Ou nem ai dará? Abraço e obrigado uma vez mais. http://www.nunolima.com/download/joana2.zip Link to post Share on other sites
Administrators MaLd0n 1,001,056 Posted February 11, 2019 Author Administrators Share Posted February 11, 2019 Assim de repente, continua a não dar audio, wifi, usb3. Quando faço sleep, ele desliga de facto o ecrã. mas fica a piscar a luz das teclas, é normal? DSDT.aml.zip se for o wifi que veio no note, não vai funcionar Audio, injeta via clover, o codec é alc230 usb 3 https://Olarila.com/forum/viewtopic.php?p=65287#p65287 novo send me depois de reiniciar Link to post Share on other sites
uran0s 0 Posted February 11, 2019 Share Posted February 11, 2019 DSDT.aml.zip novo send me depois de reiniciar  Que alternativas tenho para o wifi? adaptador externo USB? Audio já funciona, USB3 também. Sleep ainda não funciona bem, após wake up fica super lento o mac!? Envio novo runme. http://www.nunolima.com/download/joana3.zip Link to post Share on other sites
Administrators MaLd0n 1,001,056 Posted February 11, 2019 Author Administrators Share Posted February 11, 2019 [ref]uran0s[/ref], atualiza o sistema pro 10.14.3 e veja se resolve o problema depois do sleep Link to post Share on other sites
uran0s 0 Posted February 11, 2019 Share Posted February 11, 2019 uran0s, atualiza o sistema pro 10.14.3 e veja se resolve o problema depois do sleep vou testar, enquanto isso, quanto à gráfica NVIDIA, só em High Sierra? Link to post Share on other sites
Administrators MaLd0n 1,001,056 Posted February 11, 2019 Author Administrators Share Posted February 11, 2019 [ref]uran0s[/ref], nem em high sierra, é optimus, não funciona Link to post Share on other sites
uran0s 0 Posted February 11, 2019 Share Posted February 11, 2019 uran0s, nem em high sierra, é optimus, não funciona  Ok, obrigado por tudo MaLd0n. O sleep continuou a não acordar bem após actualização, tudo o resto funciona bem. Ainda assim e não conseguindo a NVIDIA a funcionar perde o interesse no hack, pois é para trabalhar em CAD, e a IGPU é fraca para esse fim. Um grande obrigado por toda a ajuda. Cumprimentos Link to post Share on other sites
Administrators MaLd0n 1,001,056 Posted February 11, 2019 Author Administrators Share Posted February 11, 2019 [ref]uran0s[/ref], tem de comprar notebook não optimus para poder usar a nvidia, muitos com a nvidia 1060 e 1080 Link to post Share on other sites
origindevx 0 Posted February 12, 2019 Share Posted February 12, 2019 I installed MacOS 10.14.3 (Mojave) to a USB flash drive (USB 3.0 interface) and this error occurred: Stop "end Randrom seed" (not a string of "+"). Please tell me, how to fix it? Link to post Share on other sites
Administrators MaLd0n 1,001,056 Posted February 12, 2019 Author Administrators Share Posted February 12, 2019 [ref]origindevx[/ref], what hardware? Link to post Share on other sites
origindevx 0 Posted February 12, 2019 Share Posted February 12, 2019 Thank you for your reply: thinkpad x270 Intel i5 7200U(Kaby Lake) 8GB memory Intel GMA HD 620 HDD 500G*1 Link to post Share on other sites
Administrators MaLd0n 1,001,056 Posted February 12, 2019 Author Administrators Share Posted February 12, 2019 [ref]origindevx[/ref], use config2.plist, follow it https://Olarila.com/forum/viewtopic.php?f=50&t=8685 Link to post Share on other sites
origindevx 0 Posted February 12, 2019 Share Posted February 12, 2019 Whether with a config2.plist file, I don't want to download an image file. Thank you! Link to post Share on other sites
Administrators MaLd0n 1,001,056 Posted February 13, 2019 Author Administrators Share Posted February 13, 2019 [ref]origindevx[/ref], config2.plist.zip Link to post Share on other sites
origindevx 0 Posted February 13, 2019 Share Posted February 13, 2019 [ref]MaLd0n[/ref], Thank you. I'm going to test. Need to use that Clover folder? Link to post Share on other sites
Administrators MaLd0n 1,001,056 Posted February 13, 2019 Author Administrators Share Posted February 13, 2019 [ref]origindevx[/ref], use our clover folder for ur chipset Link to post Share on other sites
origindevx 0 Posted February 13, 2019 Share Posted February 13, 2019 Whether with a config2.plist file, I don't want to download an image file. Thank you! Added in 45 minutes 47 seconds: I tested it, but it was still the error. Link to post Share on other sites
