Administrators MaLd0n 1,001,031 Posted October 20, 2018 Author Administrators Share Posted October 20, 2018 [ref]nhox.tjger[/ref], DSDT.aml.zip Link to post Share on other sites
ElPingU 0 Posted October 20, 2018 Share Posted October 20, 2018 Unread post by MaLd0n » 14 Oct 2018, 15:38 warning is nothing, just ignore  Mald0n, just want to give you a heads up ... I forgot to mention to you that I have a HP Probook 4540s. Here are the results.. 1) Install Mojave from Oralila USB 2) Install Clover from Oralila USB FILES Folder 3) Copy the Oralila USB EFI\Clover Folder to Mac Hard Drive EFI Partition 4) Reboot 5) After Reboot Everything Works with the exception of "Audio" The way I fixed my audio was using RehabMan Clover UEFI hotpatch ... Very Happy now !!!! Everything works !!!! Thanks for your help !! Link to post Share on other sites
Administrators MaLd0n 1,001,031 Posted October 20, 2018 Author Administrators Share Posted October 20, 2018 [ref]ElPingU[/ref], Link to post Share on other sites
nhox.tjger 0 Posted October 21, 2018 Share Posted October 21, 2018 by MaLd0n » 20 Oct 2018, 22:48 nhox.tjger, DSDT.aml.zip (28.24 KiB) Downloaded 1 time thanks MaLd0n. Link to post Share on other sites
Administrators MaLd0n 1,001,031 Posted October 21, 2018 Author Administrators Share Posted October 21, 2018 [ref]nhox.tjger[/ref], Link to post Share on other sites
manoloman 0 Posted October 22, 2018 Share Posted October 22, 2018 I think the problem arise when I copied a file from Windows 10 to a partition that I can see from Mac. Check a screen shoot of the kernel panic. Mr MaLd0n sorry but this happened again. Same steps. I did what you comment me, about fresh install.... i must do a fresh install every time this happens? I'm still need access to files and programs in Windows until i get my hackintosh working properly any help or suggestions about how to avoid this will be appreciated. thanks, thank and thanks one more time Link to post Share on other sites
Administrators MaLd0n 1,001,031 Posted October 22, 2018 Author Administrators Share Posted October 22, 2018 [ref]manoloman[/ref], what u use for windows load hdd/ssd with mac os? Link to post Share on other sites
manoloman 0 Posted October 22, 2018 Share Posted October 22, 2018 manoloman, what u use for windows load hdd/ssd with mac os? MaLd0n i use an SSD NVMe Samsung 256gb, there i only keep my windows installation. Then in my internal disk, i have two partitions, one of 50gb for macOS HighSierra 10.13.6 and the other partition to "share" my files between Win/Mac in exFat file format. Any idea? Link to post Share on other sites
Administrators MaLd0n 1,001,031 Posted October 22, 2018 Author Administrators Share Posted October 22, 2018 [ref]manoloman[/ref], check here some info about dual boot https://Olarila.com/forum/viewtopic.php?f=28&t=6656 Link to post Share on other sites
manoloman 0 Posted October 23, 2018 Share Posted October 23, 2018 manoloman, check here some info about dual boot viewtopic.php?f=28&t=6656 MaLd0n I found the problem! The kernel panic related with apple.filesystem was produced by AppleBacklightFixup.kext. At least for me that kext produced the KP. Once i erased i could boot without problem. Weird that i could see now brightness slider on display settings, itsn't the best but i could live. Now i'm fighting trying to get touchpad work, but even with the guides you gave me i couldn't patch my DSDT. Thanks for your time bro Link to post Share on other sites
key46 0 Posted October 24, 2018 Share Posted October 24, 2018 Hi MaLd0n. I am a noob. can you please help my fix error. thanks you this is my send_me.zip https://www64.zippyshare.com/v/AmC8qKgs/file.html Link to post Share on other sites
Administrators MaLd0n 1,001,031 Posted October 24, 2018 Author Administrators Share Posted October 24, 2018 [ref]key46[/ref], DSDT.aml.zip  Added in 16 seconds: [ref]manoloman[/ref], Link to post Share on other sites
key46 0 Posted October 24, 2018 Share Posted October 24, 2018 Hi MaLd0n after using the DSDT you send me then I have 0% battery how can I fix it thank you for awesome work here. Link to post Share on other sites
sumitx90 0 Posted October 24, 2018 Share Posted October 24, 2018 Hello, Sir, I need your help I have a laptop of HP i3 6th Gen. 4GB Ram Intel HD 520 Integrated Graphics Amd R5 m430 Discrete Graphics 1 TB HDD with MBR Partition Table I downloaded your all necessary files required for install Mojave on this laptop Now but I a little bit afraid of how I install and dual boot windows and Mojave because windows 10 is already installed on that HDD on a partition please help me I want to dual boot mac os mojave and windows 10 with my single hard disk please i need your help your are nice person please help this noob. Link to post Share on other sites
Administrators MaLd0n 1,001,031 Posted October 24, 2018 Author Administrators Share Posted October 24, 2018 [ref]key46[/ref], battery u need a rehabman repo Added in 1 minute 5 seconds: [ref]sumitx90[/ref], info about dual boot is here https://Olarila.com/forum/viewtopic.php?f=28&t=6701 Link to post Share on other sites
Patcharapong10 0 Posted October 26, 2018 Share Posted October 26, 2018 ract original tables, press F4 Link to post Share on other sites
Administrators MaLd0n 1,001,031 Posted October 26, 2018 Author Administrators Share Posted October 26, 2018 [ref]Patcharapong10[/ref], ? Link to post Share on other sites
rj911 0 Posted October 27, 2018 Share Posted October 27, 2018 i tried everything but mac os setup is not detecting internal hdd of my laptop, and i don't think that it will detect an ssd if i put that in laptop because i think problem is caused by that sata mode which is set to RAID. thats not possible to change. so i tried to install on a usb 3.0 pen drive(16 gb) and it worked but main problem is that i can't permanently use that on a 16 gb usb drive. so i am thinking to buy "WD my passport USB 3.0 external drive". Will that hdd solve my problem.....does it have power to sustain that system. i will use android studio on it. Link(No refferal) --> https://www.amazon.in/gp/product/B079V4L9BD Link to post Share on other sites
FredBloggs 0 Posted October 29, 2018 Share Posted October 29, 2018 Dell G7-7588 files thanks Send me Freds-iMac.zip Link to post Share on other sites
Administrators MaLd0n 1,001,031 Posted October 29, 2018 Author Administrators Share Posted October 29, 2018 [ref]rj911[/ref], u need check if have solution for it, idk Added in 6 minutes 40 seconds: [ref]FredBloggs[/ref], DSDT.aml.zip Link to post Share on other sites
rj911 0 Posted November 4, 2018 Share Posted November 4, 2018 Installed it in an external HDD, its working fine.. but some problems 1- if the laptop stays inactive for some time screen turns black(its normal) but when i press a button i see a black screen with some patterns on it. 2- no brightness control show me way how can i solve these problems, including the zip file.Send me RJs-MacBook-Pro.zip Link to post Share on other sites
Administrators MaLd0n 1,001,031 Posted November 4, 2018 Author Administrators Share Posted November 4, 2018 [ref]rj911[/ref], DSDT.aml.zip -Audio "> -Battery https://bitbucket.org/RehabMan/os-x-acpi-battery-driver -Video https://www.insanelymac.com/forum/topic/335018-intel-fb-patcher-v151/ -Brightness https://bitbucket.org/RehabMan/applebacklightfixup -I2C https://github.com/alexandred/VoodooI2C Link to post Share on other sites
rj911 0 Posted November 5, 2018 Share Posted November 5, 2018 Thank you, after adding that dsdt.aml in EFI, now mac os is detecting my internal hdd. now can you help me to clone that mac os + EFI to internal hdd. Link to post Share on other sites
rj911 0 Posted November 5, 2018 Share Posted November 5, 2018 Sir, now mac os is installed in internal hdd everything is fine including brightness. but after applying dsdt patch keyboard and touchpad stops working. even when os was in external drive they were not working. i tired using Voodoo I2C kext files but no luck. that issue only appeared after dsdt.aml fix. Link to post Share on other sites
Administrators MaLd0n 1,001,031 Posted November 5, 2018 Author Administrators Share Posted November 5, 2018 [ref]rj911[/ref], if u have a I2C , check voodooI2C site Link to post Share on other sites
