Administrators MaLd0n 1,001,055 Posted September 30, 2018 Author Administrators Share Posted September 30, 2018 u need test other uefi driver Link to post Share on other sites
datnx 0 Posted September 30, 2018 Share Posted September 30, 2018 How to use other uefi driver? Please guide me as I am a new member! Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted September 30, 2018 Author Administrators Share Posted September 30, 2018 just replace inside drivers64UEFI Link to post Share on other sites
datnx 0 Posted October 1, 2018 Share Posted October 1, 2018 I use Etcher to create usb installer but I did not find drivers64UEFI directory inside Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted October 1, 2018 Author Administrators Share Posted October 1, 2018 u need mount EFI Link to post Share on other sites
datnx 0 Posted October 1, 2018 Share Posted October 1, 2018 I have an EFI directory. Please give me OsxAptioFix3Drv-64.efi file. Thanks very much! Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted October 1, 2018 Author Administrators Share Posted October 1, 2018 OsxAptioFix3Drv-64.efi.zip Link to post Share on other sites
datnx 0 Posted October 1, 2018 Share Posted October 1, 2018 I tried two ways: - Delete AptioMemoryFix-64.efi and copy OsxAptioFix3Drv-64.efi into the drivers64UEFI directory. - Rename OsxAptioFix3Drv-64.efi to AptioMemoryFix-64.efi and replace in drivers64UEFI directory. The computer screen still stops here: +++++++++++++++++++++++++++++++++++++++ Link to post Share on other sites
mathewgx 1 Posted October 1, 2018 Share Posted October 1, 2018 @MaLdOn , trying to get Mojave on my Dell 5570 but have a problem. On High Sierra 10.3 with same refi folder , everything is Ok. I think the problem is with Intel 620 injection. If injected progress stops with the attached error. If I disable graphics injection from clover boot then Mojave starts but Intel 620 shows only 7mb. Please , help. Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted October 1, 2018 Author Administrators Share Posted October 1, 2018 I tried two ways: - Delete AptioMemoryFix-64.efi and copy OsxAptioFix3Drv-64.efi into the drivers64UEFI directory. - Rename OsxAptioFix3Drv-64.efi to AptioMemoryFix-64.efi and replace in drivers64UEFI directory. The computer screen still stops here: +++++++++++++++++++++++++++++++++++++++ idk, u need some tests and check what cause it Added in 57 seconds: @MaLdOn , trying to get Mojave on my Dell 5570 but have a problem. On High Sierra 10.3 with same refi folder , everything is Ok. I think the problem is with Intel 620 injection. If injected progress stops with the attached error. If I disable graphics injection from clover boot then Mojave starts but Intel 620 shows only 7mb. Please , help. update all kexts and use patch for IntelHD Link to post Share on other sites
mathewgx 1 Posted October 1, 2018 Share Posted October 1, 2018 update all kexts and use patch for IntelHD Â All my kexts are updated. What patch for IntelHD should I use? I'm on CoffeeLake Intel UH620. Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted October 1, 2018 Author Administrators Share Posted October 1, 2018 https://www.insanelymac.com/forum/topic/335018-intel-fb-patcher-v145/ Link to post Share on other sites
datnx 0 Posted October 3, 2018 Share Posted October 3, 2018 Please help me! send_me.zip Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted October 3, 2018 Author Administrators Share Posted October 3, 2018 Please help me! DSDT.aml.zip Link to post Share on other sites
datnx 0 Posted October 4, 2018 Share Posted October 4, 2018 DSDT.aml.zip (33.43 KiB) Downloaded 2 times Thank so much! Added in 3 minutes 27 seconds: How to fix nvidia geforce 940mx card? Please! Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted October 4, 2018 Author Administrators Share Posted October 4, 2018 Thank so much! Added in 3 minutes 27 seconds: How to fix nvidia geforce 940mx card? Please! optimus don't work, u need disable nvidia Link to post Share on other sites
datnx 0 Posted October 5, 2018 Share Posted October 5, 2018 I still have not found a way to boot into the Mojave installer on my computer. But I successfully installed Seirra. How to update Mojave from Seirra? Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted October 5, 2018 Author Administrators Share Posted October 5, 2018 I still have not found a way to boot into the Mojave installer on my computer. But I successfully installed Seirra. How to update Mojave from Seirra? https://www.insanelymac.com/forum/topic/335018-intel-fb-patcher-v146/ Link to post Share on other sites
mathewgx 1 Posted October 6, 2018 Share Posted October 6, 2018 @MaLd0n , sir can you help me with my new coffeelake laptop (intel i5-8250) ? I need a dsdt (and ssdt if needed) for Mojave. Also can you provide me a config.plist for Mojave , because as far as I know a patch for Intel 620 is needed. Also , If i'm not asking too much could you include patch that can make trackpad works as I2C mode? Because without it trackpad is not very smooth. Thnaks in advance for your time. Send me Mac-Dell.zip Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted October 6, 2018 Author Administrators Share Posted October 6, 2018 @MaLd0n , sir can you help me with my new coffeelake laptop (intel i5-8250) ? I need a dsdt (and ssdt if needed) for Mojave. Also can you provide me a config.plist for Mojave , because as far as I know a patch for Intel 620 is needed. Also , If i'm not asking too much could you include patch that can make trackpad works as I2C mode? Because without it trackpad is not very smooth. Thnaks in advance for your time. DSDT.aml.zip  Video https://www.insanelymac.com/forum/topic/335018-intel-fb-patcher-v146/ I2C u need read site and check a correct patch for u Link to post Share on other sites
mathewgx 1 Posted October 10, 2018 Share Posted October 10, 2018 Off topic , but after forum upgrade I don't find the "new posts" option. Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted October 10, 2018 Author Administrators Share Posted October 10, 2018 Off topic , but after forum upgrade I don't find the "new posts" option. [ref]mathewgx[/ref], i put some options again, i need remove some things, conflicts Link to post Share on other sites
ElPingU 0 Posted October 13, 2018 Share Posted October 13, 2018 MaLd0n, After "partial successful" Mojavi install on my HP Probook 4540s Audio is not working at all .... I was trying to create my own DSDT file but seems impossible to me to find the text file to patch ... After running "RunMe.app" the only file file that I can think I can use is the one with the name xxxx.ioreg, I was trying to load that file but nothing loads.... here is my zip file created by RunMe.app Could you please point me on the right direction in order to create my DSDT file Thanks Send me Fernandos-MacBook-Air.zip Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted October 13, 2018 Author Administrators Share Posted October 13, 2018 [ref]ElPingU[/ref], DSDT.aml.zip Link to post Share on other sites
ElPingU 0 Posted October 13, 2018 Share Posted October 13, 2018 Mald0n, Thank you for your prompt reply and the file as well Do I need to change the Inject Number on the Plist???? right now is on "1" Thanks Link to post Share on other sites
