Hackintosh Guide - Sierra / HighSierra / Mojave / Catalina / BigSur / Monterey on Serie 5, 6, 7, 8, 9 with Clover Bootloader / DSDT
25 minutes ago, fallen00sniper said:
couldn't figure out how to edit the post after reboot, here's the run_me from ssd
  • Thanks 1
-Donations-
Link to comment
Share on other sites
1 hour ago, fallen00sniper said:
As far as I can tell all seems fine, appears to run the same or better
dsdt is not load, in oc u need add entrie in config.plist
-Donations-
Link to comment
7 minutes ago, fallen00sniper said:
fixed, forgot I had to do that for OC. USB 2.0 ports have moved from their own place to USB 3.0 as a Hub.
is not OC, is my dsdt
is a correct way for serie 8+
-Donations-
Link to comment
8 minutes ago, fallen00sniper said:
So everything is good to go?
Removal of clover is just remove prefpane and delete from EFI?
looks good
  • Thanks 1
-Donations-
Link to comment
10 minutes ago, fallen00sniper said:
Awesome, Thank you again!
enjoy
-Donations-
Link to comment
Hi Mr. MaLd0n,
I installed mac OS sierra on my laptop,
Below is my EFI folder, please help me fix it!
Many thanks~
Have a problem when install & first boot,
I need boot arg with nv_disable=1 and -x,
I can't mount my HDD disk so i can copy clover configator to mount EFI folder,
File attach is USB install macOS sierra (link: https://drive.google.com/open?id=1EFchcujAjADpKmvfz2iIA3TvY6ox_nMs)
Laptop information:
- asus N56VB
- CPU: intel core i5 3230m
- 1st card Intel HD 4000, 2nd card on: Nvidia GT740M 2G (monitor size 1920x1080)
- sound card Reaktek alc663
- wifi atheros AR9565
- lan Qualcomm atheros AR8161 Ethernet
- HDD HGST 750gb
Link to comment
7 hours ago, namtt1129 said:
Hi Mr. MaLd0n
follow full steps here
-Donations-
Link to comment
Ola madlon  ,eu instalei o catalina 10.15.3 usando a imagem do site   numa ga z97x gaming3   ,usei a pasta 5 to 9 chipset series ,aparentemente tudo funcionou so que na usb eu recebo a mensagem USB HAS NO POWER ,a usb so tem corrente para periferico mt basico como pendrive e mouse sem iluminação. Eu queria pedir um dsdt , deveria arrumar isso antes ou depois da dsdt?
Tentei achar algum guia de usb aqui mas não consigo .
Edited by steelfox
esqueci coisas
Link to comment
On 2/26/2020 at 11:24 AM, sams motion said:
i need dsdt and ssdt for my device
u need post files
15 minutes ago, steelfox said:
Ola
tem de patchear o dsdt sempre
-Donations-
Link to comment
1 hour ago, steelfox said:
Consegui enviar compactando em rar :)
deleta a pasta efi e cola essa lá
https://filebin.net/29gj1gcd39d7sajq/EFI.zip?t=hw5uh35t
-Donations-
Link to comment
Guest fallen00sniper
On 2/22/2020 at 10:45 PM, MaLd0n said:
looks good
So I got a really really good deal on a 4790k, will I need to make any changes before I install it or do I need a new dsdt or just make a new cpu ssdt?
you set me up with a solid OC boot.
Link to comment
don't need generate new
yes, oc is solid
-Donations-
Link to comment
Dell XPS One AiO 27
Procesor: i7-3770S
Ram: 2x4GB DDR3 (kości laptopowe)
GPU: Intel HD 4000 + GT640M (-wegnoegpu)
Dźwięk ALC275
WiFi + BT DW1702 AR9485
Ethernet: AR8161
Please not connect not looking for a BT device system cataliton please
https://www117.zippyshare.com/v/ZquRZiRz/file.html?fbclid=IwAR09_ZvHq0v-LaC1s_cgJIZRIncbfvoh20HTM4aw_cuylQf79mGQfW3gwG8 ALL add BT or wifi fix ALL config.plist
Link to comment
Olá MaLd0n,
Saquei a pasta EFI OpenCore para chipset 7, 8, 9 ... e meti na pen USB, ou seja, substitui o EFI do clover e apenas usei o DSDT que tinhas criado para mim.
Ao fazer boot pela PEN apenas me aparece a opção 1. Reset NVRAM
Estou a saltar algum passo para fazer boot com o OC?
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
