Hackintosh Guide - Sierra / HighSierra / Mojave / Catalina / BigSur / Monterey on Serie 5, 6, 7, 8, 9 with Clover Bootloader / DSDT
u need a some patches in config.plist for x79 to avoid this error, the problem is not DSDT, ppl use 5+ patches for AppleIntelCPUPM
-Donations-
Link to comment
Share on other sites
Nothing changed. What I can do?
take one test
enable HT and use NullCPUPM, let me know if boot fine
NullCPUPowerManagement.kext.zip
-Donations-
Link to comment
bad, no c states
good, c3, c6, c7
-Donations-
Link to comment
Doneeeeee !
What do you think?
looks good xD
-Donations-
Link to comment
Here is my Send me file. Everything I got working by myself but only sound not working. Please check for me.
Dell Inspiron 3520, Core i3-2370M, Intel HD Graphics 3000, 4GB Ram, 500GB HDD,
Send me TYTANs-MacBook-Pro.zip
(873.91 KiB) Not downloaded yet
u need check what audio codec u have and inject correct layout-ids with AppleAlc.kext
-Donations-
Link to comment
MaldOn,
can you help me again with my dsdt.
mb : asrock z77 extreme 4
cpu : i7 3770k
GpU : gtx 970
thank you
Hendra
test all usb ports, use last clover version
CLOVER.zip
-Donations-
Link to comment
Please @MaLd0n how do I find my audio codec and also where can I find help injecting layout id with AppleALC
try a dpci manager
http://Olarila.com/files/Utils/DPCIManager.app.zip
-Donations-
Link to comment
aldita wrote: ↑12 May 2018, 08:22
MaldOn,
cpu : i7 3770k
GpU : gtx 970
thank you
Hendra
2 port usb didnt work, maybe is from asmedia asm1042
regards, Hendra
1075494131_ScreenShot2018-05-13at05_19_42.thumb.png.1e427268925c7ab14c57be314bff789a.png
Link to comment
regards, Hendra
need check if have patch for it, i think no, if dont work native u need a genericxhci kext, but this kext now cause some problems
send me new dump with new files
-Donations-
Link to comment
@MaLd0n please do help me with my audio. Got my Codec id and checked about AppleALC injection and all the guides is about realtek while I have a cirrus logic audio. Attached is an image and how do I go about it?
1196024659_IMG_20180512_230123675_HDR2.thumb.jpg.d6d04644dab3f3ed2c08082dd8a41eb3.jpg
Link to comment
aldita wrote: ↑13 May 2018, 05:58
regards, Hendra
here i send you a new imac
thanks
Send me iMac.zip
Link to comment
idk about ur codec, use VoodooHda, check InsanelyMac
-Donations-
Link to comment
thanks
replace, reboot and send me new dump, i need check
-Donations-
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
