  • Sky
  • Blueberry
  • Slate
  • Blackcurrant
  • Watermelon
  • Strawberry
  • Orange
  • Banana
  • Apple
  • Emerald
  • Chocolate
  • Charcoal
Hackintosh Guide - Sierra / High Sierra / Mojave / Catalina on Serie 100/200/300/400 with Clover Bootloader
The sound card I'm using is the Saffire Pro 24 DSP Firewire. I'm cutting it down to the end of the volume pot. And when a process that uses the Display card takes place. For example, while Final Cut Pro is running and getting render. Digital is starting to sound. It's not a constant tune but a variable sound.
I tried to remove the internal sound card and appleALC, I played with the sound settings in config.plist. I tried with DSDT and without DSDT.
I could never solve this problem.
no idea about it
Share this post
Link to post
Share on other sites
Muito obrigado, de certo aqui!!
agora está rodando liso.
Só uma dúdiva, tenho um adaptador TP-link TL-WN881ND.
é possível habilitar a wi-fi 5Ghz dele?
mas no mais está perfeito!!
Obrigado mesmo!!
Abração
tem de dar uma pesquisada sobre isso, nunca usei essa placa
Share this post
Link to post
Hi MaLdOn,
I am replacing my old hack with a new one.
Specs are:
GA Z270M-D3H board
Intel i3-7100 processor
8 GB RAM
A-DATA SX6000 256 GB SSD (M.2 PCIe Gen3x2)
Can you, please, send me patched DSDT file and suggest config.plist file.
Thank you,
Aldebaran
Send me lan42-161.tmf.bg.ac.rs.zip
Share this post
Link to post
Hi MaLdOn,
Specs are:
GA Z270M-D3H board
8 GB RAM
Thank you,
Aldebaran
CLOVER.zip
Share this post
Link to post
MaLdOn,
Thank you once again. Everything is working.
Regards Aldebaran
P.S. Do I also get a BEER?
ohh
is good :D
Share this post
Link to post
make up use file HighSierra Olarila 10.13.2.raw so ad!
Share this post
Link to post
Hello. Once installed your friend has installed a paragraph and stand looking forward to your help
main asus B360G gaming card giga radeon GV 6850
34934416_1739629392798846_8386790365545365504_n.jpg?_nc_cat=0&oh=5f4ac48481cbff8854435c155a33dac8&oe=5BADE70F
Share this post
Link to post
Please Check/Send Back/Update my DSDT. File attached that you requested. Thank you for Providing a clean installer. I bought 10.6 - 10.8, trying to do my own fresh install, only to find that my Hardware is too new.
Send me Edwards-iMac.zip
Share this post
Link to post
CLOVER.zip
Share this post
Link to post
Please help me to patch dsdt for my hackintosh , hdmi nvidia cannot work only black screen only working cursor on external screen
U need disable nvidia, in clover/acpi/patched use only it
check
CLOVER.zip
send me new SEND_ME after reboot
Share this post
Link to post
I have a question. Usando sua imagem do High Sierra eu não preciso flashear o clover no pendrive, certo? Os mods eu faço já com o sistema rodando? Caso eu salve os patchs em outro pendrive, as portas USB vão estar funcionando para poder passá-los para o mac os? Obrigado.
Share this post
Link to post
Here after new boot , my laptop cannot plug hdmi without nvidia because it direct to nvidia port , missing brightness slider and sleep not working
yes, but optimus don't work in hacks, need disable nvidia
test brightness
Share this post
Link to post
Sim
extrai a imagem e "burn" o raw pelo windows ou mac
Share this post
Link to post
