hi , im so tank you for creating this version of hackintosh , so my laptop it's asus zenbook pro ux501 vw
cpu :core i7 6700hq
ram: 4Gb ddr 4 , 8Gb ddr3 , 2133mhz
Gpu : nvidia gtx 960m , intel hd 530
hard : 128 Gb ssd , 1Tb hdd
display : 4k
please help me to boot mac os high se , i boot but so many problem !!! so many , please create a special guide or file for this laptop ,
tnx so much
hasannemati@icloud.com
Link to comment
Share on other sites
how best to find the correct GUID info?
Don't need GUID info, type exactly as my code box above.
If you want to hide Recovery too, use
        <key>GUI</key>
       <dict>
               <key>Hide</key>
               <array>
                       <string>Preboot</string>
                       <string>Recovery</string>
               </array>
Code box is the > button.
-Donations-
PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE
Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com
Link to comment
guys please help me
post a photo with error
-Donations-
Link to comment
Whoops I misunderstood. Many thanks guys 👍🏻👍🏻
Asus Maximus X Formula Z370 | i7 8700K | EVGA GTX1080 SC | High Sierra 10.13.4 (17E199)
Link to comment
@MaLd0n Here are my specs and RunMe results:
Gigabyte Z370 Aorus Gaming 5
i7-8700K currently OC to 5.0 GHZ
32 GB Crucial Ballistix DDR4 Ram
Gigabyte Aorus GTX 1080Ti 11 GB
1 TB Samsung 960 EVO NVME Drive - MacOS
1 TB Samsung 850 EVO SSD- Storage
3 TB WD Black- Time Machine Backups
Broadcom Wifi/BT Card BCM94360CD
EVGA Supernova G3 850 W PSU
Corsair H100i v2 Water Cooler
Lacie Thunderbolt 2 Drive
GC Alpine Ridge Thunderbolt 3 Card
https://www.dropbox.com/s/5m5srk2k5mz8hg4/Send me Seans-Hack-Pro.zip?dl=0
Link to comment
i posted it in InsanelyMac
-Donations-
Link to comment
Puedo preguntar en español?
sim
depois eu movo os posts
-Donations-
Link to comment
NOT A UNTOUCHED TABLES
CLOVER.zip
(1.94 MiB) Downloaded 3 times
Many Thanks for your help sir, btw why all kext from you is green and red? and how to make awesome cosmetics pci? and why i still need fakepciid.kext for my voodooi2c.kext and my ar9565 kext? :D thanks
Link to comment
Many Thanks for your help sir, btw why all kext from you is green and red? and how to make awesome cosmetics pci? and why i still need fakepciid.kext for my voodooi2c.kext and my ar9565 kext? thanks
things without native support u need a kext/injectors
-Donations-
Link to comment
logre instalar high sierra en una Gigabyte H110 con un i3 7100
Al principio tube un poco de problemas con la grafica, pero al reiniciar funciono perfectamente
En el reinicio pense que bootearia sin usb pero no, debe estar conectanada, intento instalar UEFI clover pero no puedo,
reinicio y me pide la usb para arrancar.
Otro problema que tengo es el audio, ya vi varios post y tutoiales, pero piden que configure en clover configurator, pero no se si para esto primero tengo que tener instalado el boot en el hd
no se si me di a entender
Link to comment
boot with usb and run it
RunMe.app
post files here
-Donations-
Link to comment
I have zenbook pro ux501 vw
ram: 4gb ddr4 2133 mgh + 8gb ddr 4 2133 mgh
hard : 128 gb ssd + 1TB hdd
cpu: core i7 6th skylake 6700hq
display :4k
keyboard backlite
gpu: Nvidia gtx 960 m + intel hd 530
but when install high Sierra gpu show's just 3mb! and I try every method on internet and this site and you tube nothing work !
and I install Nvidia web driver and any thing ... but don't work!
please help me
any one have this laptop and insatall Mac good , please call to me .., hasannemati@icloud.com
Link to comment
Boa noite pessoal, ou iniciante no hack, fiz a instalação e esta rodando liso.
Porém quando desligo meu hack reinicia.
Alguem pode me ajudar?
I7 8700
Gigabyte b360m-d3h
Gtx 1050ti
https://drive.google.com/open?id=1bsDBi ... QqR7oX4Vaq
posta o full dump
RunMe.app
roda o app e espera o fim da operação, vai gerar os arquivos no desktop
-Donations-
Link to comment
no idea, bro
google chrome have this problem too?
Hello again,
It responds to a lot of movements like the Safari example. Including Chrome. But more important than that, a strange sound comes from the speakers.
For example, when I move a window, there is a sizzling sound.
While using the Final Cut Pro, the rear speakers get a scratchy sound when they get the render.
Do you have any idea what the problem might be?
Link to comment
I7 8700
Gigabyte b360m-d3h
Gtx 1050ti
testa aí, substitui a pasta completa e reinicia
CLOVER.zip
-Donations-
Link to comment
Hello again,
update ur kexts, shiki etc
-Donations-
Link to comment
Muito obrigado, de certo aqui!!
agora está rodando liso.
Só uma dúdiva, tenho um adaptador TP-link TL-WN881ND.
é possível habilitar a wi-fi 5Ghz dele?
mas no mais está perfeito!!
Obrigado mesmo!!
Abração
Link to comment
The sound card I'm using is the Saffire Pro 24 DSP Firewire. I'm cutting it down to the end of the volume pot. And when a process that uses the Display card takes place. For example, while Final Cut Pro is running and getting render. Digital is starting to sound. It's not a constant tune but a variable sound.
I tried to remove the internal sound card and appleALC, I played with the sound settings in config.plist. I tried with DSDT and without DSDT.
I could never solve this problem.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
