  • Sky
  • Blueberry
  • Slate
  • Blackcurrant
  • Watermelon
  • Strawberry
  • Orange
  • Banana
  • Apple
  • Emerald
  • Chocolate
  • Charcoal
Hackintosh Guide - Sierra / High Sierra / Mojave / Catalina on Serie 100/200/300/400 with Clover Bootloader
Than started the notebook on which is running W7 and tryed to see any executable file on your zipped folder.
The app "RunMe" it's only for macOS.
Share this post
Link to post
Share on other sites
Ok, I asked from beginning, if someone can light up my mind on how proceed to install macOS into my clevo machine. It's about 3 months already that I'm searching around but still didn't found how get this job done. A friend on an hackintosh group advised me to join this blog... so I'm here .
I would really appreciate your teaching about :-)
Share this post
Link to post
what hardware?
Share this post
Link to post
That's the hardware:
Clevo D900 (Yorkfield Intel core2 Extreme X9650... plus Nvidia geforce 8800M gtx (2 times in SLI)... ChipsetP965/G965 and southbridge 82801HB/HR),
Thank you
Share this post
Link to post
If I understand correctly, should follow these steps:
1)Download image of sierra
2)burn it and install on my hdd
3)run your RunMe-app and send you the results
Is it that right ?
Share this post
Link to post
Is it that right ?
yes
post there. LGA 775 topic
Share this post
Link to post
Good Morning Sir,
just a practice question: have downloaded raw image of High Sierra. My understanding is that that's an image and not an installation disk that will start installing mac OS once starting up my pc. Do I'm wrong?
If so, I do have to use W32 image to create an installation USB stick and than install from there ?
Than after installed should I use your RunMe.app?
Thank you and please excuse me for some other questions will arise :-)
Share this post
Link to post
Hi Maldon, can you help me to fix or check my clover?
My specs is :
Laptop Asus A456URK
Intel Core i5 7200U
Intel HD Graphics 620
Nvidia Disable
4GB Ram
HDD HFS+
I'm running High Sierra 10.13.4
Thanks in advance
NOT A UNTOUCHED TABLES
CLOVER.zip
Share this post
Link to post
@MaLd0n I will be upgrading to a z370 Aorus Gaming 5 board and an 8700K once it arrives tomorrow. I wanted to know if it is possible to make a DSDT for this board. I will send my RunMe results once I have everything up and running tomorrow evening. Thank you in advance for all the amazing work you do.
Share this post
Link to post
k
just send me
Share this post
Link to post
Hi MaLd0n.
Please help me to set config.plist + error dsdt RehabMan-MaciASL-2018-0507.zip (site insanelymac [Guide] Sierra / High Sierra on the series 100/200/300 / SkyLake / KabyLake / CoffeeLake-DSDT series) MaLd0n Asus ROG STRIX Z370 F Gaming.zip
Extract the origin of the F4 boot clover + RunMe.app
https://www99.zippyshare.com/v/nsQcczrH/file.html
Help me solve the problem .
Share this post
Link to post
Hi MaLd0n.
u have a dsdt full patched
Share this post
Link to post
Hi MaLd0n,
Thanks for the great guide and all the information you provide. My Hackintosh is working with ethernet and sound, I think sleep is broken as I had a random restart...
This is what I have done so far by following this guide:
-Installed HS 10.13.4 from Olarila image.
-Installed Clover 2.4 r4458
-MausiEthernet.kext for ethernet (working)
-SATA-RAID-unsupported.kext so I could install to SSD (it was not showing up)
-Sound (working already)
-WebDriver-387.10.10.10.30.106 for GTX1080 (working)
Send me Chriss-iMac.zip
F4 Clover ChrisiMac.zip
Many thanks :)
Share this post
Link to post
Hi MaLd0n,
CLOVER.zip
Share this post
Link to post
Wow thanks for the quick reply. I'll leave it running now and see if it comes out of sleep ok.
About this Mac > iMac Pro (2017), CPU shows as "3.7 GHz 6-Core Intel Xeon E5" where it should be 8700K, shall I manually edit .string file?
Ta!
Share this post
Link to post
Ta!
8700k only manual edit, not good, some updates broke it, just a cosmetic
Share this post
Link to post
So I left the mac on and it went to screensaver, then black screen. Then by itself it rebooted.
Possibly a bios setting?
Share this post
Link to post
Use GUI/Hide
https://clover-wiki.zetam.org/Configura ... I#gui_hide
Thank you pernacabeluda I will try that now, how best to find the correct GUID info? ;)
I tried this but it does not hide the option (copied guid from Clover- space bar):
PS how to make CODE box like you :?:
Hide
FileVault Prebooter
HD(2,GPT,30FFF746-CE96-4B49-A944-74850C4EA960)
Share this post
Link to post
