Hackintosh Guide - Sierra / High Sierra / Mojave / Catalina on Serie 100/200/300/400 with Clover Bootloader
I'd add Gigabyte P55A-UD3 and P55A-UD6 to that list.
I have a weird thing with the Gigabyte H270-HD3.
The built in Intel 630 graphics are showing up as PCI slot 3 (Firewire)
I have a FW800 PCI card that seems to work fine in that slot.
This machine runs fine using the DSDT you did but I am wondering if this slot thing could be a clue why I can't get HDMI audio working?
I did a "Run Me" and pressed F4 before boot so you can see how this board is running with your DSDT.
Cheers
PlexiPuter
no problem about it, just appears in PCI
Link to post
Share on other sites
  • Replies 1.5k
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
https://www.olarila.com/topic/9351-video-guide-opencore-vanilla-guide-step-by-step-full-dsdt-patched-or-ssdt/
Posted Images
thanks a lot but sleep didn't work corectly,i don't know what's next
before that thanks
what happens with sleep?
log show --style syslog | fgrep "Wake reason"
Link to post
MaLdOn,
here's my send me imac, from my gigabyte z170x ud3.
can you help for tune this dsdt ?
Regards, Hendra
Update clover bootloader
replace, reboot and send me new SEND_ME
CLOVER.zip
Link to post
Hello MaLd0n,
Here is my send me from my gigabyte Z370 ultra gaming with bios F8 upgrade.
Can you help with dsdt fine tune. I lost wifi after bios upgrade
Regards, Karouteur.
u dont need update bios if u have a stable system
Link to post
Post by MaLd0n ยป 10 May 2018, 20:39
aldita wrote: โ†‘10 May 2018, 19:58
MaLdOn,
Regards, Hendra
CLOVER.zip
(3.23 MiB) Downloaded 2 times
ย
heres my new send me imacs, is there any tuning again ?
thanks you
regards, hendra
Send me iMac.zip
Link to post
thanks you
regards, hendra
Send me iMac.zip
fine
Link to post
Hi MaLd0n
I've just built another 200 series machine using a Z270-Gaming-K3 (Bios F8)
I found a DSDT on Insanely that you did for this board, which seems to run OK apart from not being able to wake it up (keyboard and mouse plugged into USB2 ports, not USB3 ports)
I've attached a "Run Me" using clover F4 so the unpatched DSDT is there as well.
If you could edit a new DSDT for this machine, that would be great!
Cheers
PlexiPuter
Send me PlexiPutersiMac.zip
Link to post
Cheers
PlexiPuter
the device have a _PRW
Link to post
OK great!
Thanks a lot MaLd0n
I can now wake it up with a bluetooth mouse with the dongle plugged into a USB2.0 port :)
I'll need to get a couple graphics cards for these two new machines now, in order to get sleep and wake working properly.
I was thinking of a Gigabyte AMD RX 560.
I've heard these are mean't to be stable?
Cheers
PlexiPuter
Link to post
OK great!
Thanks a lot MaLd0n
Cheers
PlexiPuter
i'm using a 580, native support, 560 have a native support too
Link to post
Hello
Thanks for your help
Here are the files of my install.
I'm struggling to install my Graphic card.
The rest is not perfect at all I'm pretty sure but the system is installed (badly I guess)
I'm a real Hackintosh beginner and my English is not perfect too. Sorry about that.
here's what's inside my Hackintosh
Didn't install the graphic card since it blocks at 70% during boot.
Send me FABs-iMac.zip
Link to post
Hy there, I'm brand new in this forum, searching how to start move to hackintosh my Clevo D900 (Yorkfield Intel core2 Extreme X9650... plus Nvidia geforce 8800M gtx (2 times in SLI)... ChipsetP965/G965 and southbridge 82801HB/HR) can't find anything to help me start on this job. Does anybody could give me an input about?
Please excuse me if I wrote into this post.
Thank's alot
Link to post
Hello
Thanks for your answer in FB.
u don't need kexts in L/E or S/L/E, use all kexts in clover/kexts/other
CLOVER.zip
Link to post
Thank's alot
http://Olarila.com/forum/viewtopic.php?f=50&t=6256
Link to post
Hello,
I have been using hackintosh for a very long time. From the first generation i5 processor time.
When I bought a new machine, I thought it was easy to get under. But it did not feel like I thought. And it really worked me out.
I run your program and send you the file created on the desktop. Please help solve the problem.
Suddenly restarts when any project is running. Fincal Cut, Premiere, Logic Pro etc .. Sometimes Slow graphics any windows movement etc. Netflix problem on safari.
Asus Z270F / i7 7700K / Asus Dual 1070 8GB / 2x16 Kingston 2133MHz / Fenvi FV-T919 Wifi-Bluetooth / Samsung Evo 960 NvME / TI Chipset Firewire Pcie
Thank you in advance for your support.
Send me Musics-iMac.zip
Link to post
Hello,
CLOVER.zip
replace, reboot and send me new dump, run app again
Link to post
Thank you for your interest. The second send me files are here. But netflix works on the safari and I also thank you for that.
In System Report, only NVIDIA appears in Graphics / Display, is this normal?
And the processor frequency is always traveling at high limits 4,13 MHz 4,50 MHz etc.
Edit: And nightshift not work.
Link to post
use it
yes, it's normal, hardware acceleration work, just check ioreg
back with ur ssdt for power management
Link to post
You're great,
With the last DSDT file that was submitted, the CPU frequency returned to normal.
You've made me very happy. :) I do not want to tired you anymore, I want to ask you my last questions, if you can.
Is it ok to use FakeSMC sensor kexts?
Do I need to change the serial number etc. in Config.plist file?
Is there anything I can do for Nightshift?
I hope the same restart and slowdown problems do not appear. In this matter, I will definitely make a positive and negative return in a week.
And I wanted to buy you a beer, but PayPal does not work in Turkey. But I will find a way. :)
See you...
Link to post
You're great,
You've made me very happy. I do not want to tired you anymore, I want to ask you my last questions, if you can.
See you...
i don't like fakesmc sensors, but u can use, if have freeze in boot or other problem, remove, i prefer intel power gadget
https://software.intel.com/file/641033/download
Nightshift don't work?
Link to post
Nightshift not work and after the second DSDT file I do not see x86platform or ADGP in IOreg. But the processor frequencies are working more correctly.
u need use ur SSDT + DSDT, i remove plugin type in DSDT, if u dont use it in config.plist or SSDT, PM don't work
put in clover/acpi/patched, reboot
SSDT.aml.zip
Link to post
:cap-Please Disable Your ADBlocker and Support Our Forum-:cap
