PlexiPuter 1 Posted April 22, 2018 Share Posted April 22, 2018 I did try it but did have trouble booting so I don't think it was the same bios version. Here's my "Run Me" taken before I tried that other DSDT. Cheers PlexiPuter Send me PlexiPutersiMac.zip Link to post Share on other sites
aldebaran 0 Posted April 24, 2018 Share Posted April 24, 2018 Hi MaLdOn, Here are my Send me lira.zip fall. Could you please send me edited DSDT file, config.plist and your suggestion for clover directory? Thank you, Regards, Dragan Send me lira.zip Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 25, 2018 Author Administrators Share Posted April 25, 2018 I did try it but did have trouble booting so I don't think it was the same bios version. Here's my "Run Me" taken before I tried that other DSDT. Cheers PlexiPuter CLOVER.zip Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 25, 2018 Author Administrators Share Posted April 25, 2018 Hi MaLdOn, Here are my Send me lira.zip fall. Could you please send me edited DSDT file, config.plist and your suggestion for clover directory? Thank you, Regards, Dragan Attachments CLOVER.zip Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 25, 2018 Author Administrators Share Posted April 25, 2018 UPDATE FIRST POST -Clover Folder -Kexts -Patches Link to post Share on other sites
magnifico 0 Posted April 25, 2018 Share Posted April 25, 2018 Aspetta, vendi ur skylake? si si Link to post Share on other sites
aldebaran 0 Posted April 26, 2018 Share Posted April 26, 2018 Hi MaLdOn Here is my Send me Andromeda file. The system is: Gigabyte Z370-Gaming3 i5-8400 Radeon RX560 Bios F6 Can you, please, send me clover folder for my system. Regards, Aldebaran Send me Andromeda.zip Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 26, 2018 Author Administrators Share Posted April 26, 2018 Gigabyte Z370-Gaming3 CLOVER.zip Link to post Share on other sites
aldebaran 0 Posted April 27, 2018 Share Posted April 27, 2018 Hi MaLdOn, Thank you for clover folder for Andromeda. All is working. Only one can see some errors during boot. These errors are: ACPI error \.SB.PCIO.RP04.PXSX - AE_NOT_FOUND ACPI error \.SB.PCIO.RP05.PXSX - AE_NOT_FOUND ACPI error \.SB.PCIO.RP08.PXSX - AE_NOT_FOUND ACPI error \.SB.PCIO.RP09.PXSX - AE_NOT_FOUND Also when compiling one gets error at line 315 name already exists in scope (BNUM). Can you, please, fix those errors. Regards, Aldebaran Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 27, 2018 Author Administrators Share Posted April 27, 2018 ACPI error \.SB.PCIO.RP04.PXSX - AE_NOT_FOUND ACPI error \.SB.PCIO.RP05.PXSX - AE_NOT_FOUND ACPI error \.SB.PCIO.RP08.PXSX - AE_NOT_FOUND ACPI error \.SB.PCIO.RP09.PXSX - AE_NOT_FOUND DSDT.aml.zip Link to post Share on other sites
PlexiPuter 1 Posted April 28, 2018 Share Posted April 28, 2018 Thanks MaLd0n! Also got the error at line 294 name already exists in scope (BNUM) so I deleted that line and it now shows no errors. Machine is running great on 10.12.6 wih everything working apart from HDMI Audio. Been trying to get HDMI audio to work using the usual framebuffer kext injection and Fake PCIID but still no joy there. Not expecting sleep to work on Intel HD 630 graphics as this seems to be a known issue. Another weird thing is that I also have 10.12.6 running great on: P55M-UD2 P55M-UD4 P55-UD5 But P55A-UD3 and P55A-UD6 won't even get to the clover menu. They stop at "Loading Operating System 6_" These two boards run fine on 10.8.5 using Chimera.: Any ideas? Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 28, 2018 Author Administrators Share Posted April 28, 2018 Another weird thing is that I also have 10.12.6 running great on: P55M-UD2 P55M-UD4 P55-UD5 But P55A-UD3 and P55A-UD6 won't even get to the clover menu. They stop at "Loading Operating System 6_" These two boards run fine on 10.8.5 using Chimera.: Any ideas? Â use boot0ss in ESP Link to post Share on other sites
PlexiPuter 1 Posted April 29, 2018 Share Posted April 29, 2018 Unfortunately, boot0ss in the ESP didn't work on either of the two P55A's. Oh well.....3 out of 5 is still WAY more than I expected I can't believe how well the other three P55's are running 10.12.6 using DSDT's with your original patches with USB updated from EHC1/EHC2 to EH01/EH02. Everything works fine on those! Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 29, 2018 Author Administrators Share Posted April 29, 2018 Link to post Share on other sites
PlexiPuter 1 Posted April 30, 2018 Share Posted April 30, 2018 Tried exactly that, with the same (latest) version of Clover and still cannot boot into clover on either of my two P55A's. Thanks anyway Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 30, 2018 Author Administrators Share Posted April 30, 2018 Tried exactly that, with the same (latest) version of Clover and still cannot boot into clover on either of my two P55A's. Thanks anyway use a fresh install, i think work Link to post Share on other sites
aldebaran 0 Posted May 1, 2018 Share Posted May 1, 2018 Hi MaLdOn, Thank you for the new DSDT. Now all is working and there is no errors during booting. Only the error at line 315 name already exists in scope (BNUM) when compiling. Thank you once again. Regards, Aldebaran Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted May 1, 2018 Author Administrators Share Posted May 1, 2018 Hi MaLdOn, Thank you for the new DSDT. Now all is working and there is no errors during booting. Only the error at line 315 name already exists in scope (BNUM) when compiling. Thank you once again. Regards, Aldebaran Link to post Share on other sites
PlexiPuter 1 Posted May 2, 2018 Share Posted May 2, 2018 Same deal with booting into Clover on a freshly prepared USB installer with boot0ss. Both P55A's only get to "Loading Operating System 6_" Same installer boots on all four other machines. Both P55A's still boot into my old 10.8.5 and 10.6.8 drives fine. Very strange indeed! Thanks for the suggestions anyway Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted May 2, 2018 Author Administrators Share Posted May 2, 2018 Same deal with booting into Clover on a freshly prepared USB installer with boot0ss. Both P55A's only get to "Loading Operating System 6_" Same installer boots on all four other machines. Both P55A's still boot into my old 10.8.5 and 10.6.8 drives fine. Very strange indeed! Thanks for the suggestions anyway i see this problems in some old Intel mobos, gigabyte no Link to post Share on other sites
opoeta 0 Posted May 3, 2018 Share Posted May 3, 2018 Great Work Send me iMac.zip Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted May 3, 2018 Author Administrators Share Posted May 3, 2018 Great Work CLOVER.zip Link to post Share on other sites
aldebaran 0 Posted May 4, 2018 Share Posted May 4, 2018 Hi MaLdOn, Can you, please, fix the errors I have during boot. I am sending you Send me lira-1.zip. Thank you for your time and kindness. Regards, Aldebaran Send me lira-1.zip Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted May 4, 2018 Author Administrators Share Posted May 4, 2018 Hi MaLdOn, Can you, please, fix the errors I have during boot. I am sending you Send me lira-1.zip. Thank you for your time and kindness. Regards, Aldebaran Serie 10/100 u can ignore it, just a HDEF Link to post Share on other sites
kevinagnes 0 Posted May 4, 2018 Share Posted May 4, 2018 Hi MaL0n, can you please help me with the DSDT? It's my second hackintosh. But this one have many things not working. I'm still in Sierra because of the FCP7 support. Cheers, Kevin Send me Kevins-iMac.zip Link to post Share on other sites
