josecar 0 Posted March 30, 2018 Share Posted March 30, 2018 Sorry Maldon but I can't find how to do it, please could you give me some steps to accomplish this? Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted March 30, 2018 Author Administrators Share Posted March 30, 2018 Sorry Maldon but I can't find how to do it, please could you give me some steps to accomplish this? Link to post Share on other sites
josecar 0 Posted March 30, 2018 Share Posted March 30, 2018 Tried twice bit unfortunately not working . Do you have any other idea please? Link to post Share on other sites
aerz 2 Posted April 1, 2018 Share Posted April 1, 2018 Which i5 would you suggest i5 7500 or i5 8400? Â He suggested i5 8400 which works with a Z370. Remind that also you can use the new cheap motherboards with the chipset H370, B360 and H310. Link to post Share on other sites
Mirone 25,714 Posted April 2, 2018 Share Posted April 2, 2018 Tried twice bit unfortunately not working try this:AppleHDA.kext.zip after install repair permissions and rebuild caches. Link to post Share on other sites
aldebaran 0 Posted April 3, 2018 Share Posted April 3, 2018 MaLdOn, I have noticed that part of SMBUS is not working. During post it gives me an error. So I am sending you new Send me Aldebaran_1 file. Hope that you can find the problem. I am running now 10.13.4. Thank you for your help. Regards, Aldebaran Send me Anldebaran_1.zip Link to post Share on other sites
jsl2000 0 Posted April 7, 2018 Share Posted April 7, 2018 Thanks and I need your help to patch my DSDT.aml. Another 2 issues bothered me a lot after installation: 1. AppleALC unable to load due to lack of layout-id in HDEF. ALC1220 failed. Only DP audio from HD 630 & HDMI audio from GTX-980. 2. Unable to boot by newer Clover versions (> r.4268) either hanged at +++++++++++, kernel panic or loss of display from Intel HD 630. Send me iMac.zip Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 7, 2018 Author Administrators Share Posted April 7, 2018 Thanks and I need your help to patch my DSDT.aml. Another 2 issues bothered me a lot after installation: 1. AppleALC unable to load due to lack of layout-id in HDEF. ALC1220 failed. Only DP audio from HD 630 & HDMI audio from GTX-980. 2. Unable to boot by newer Clover versions (> r.4268) either hanged at +++++++++++, kernel panic or loss of display from Intel HD 630. update ur clover why u buy a plextor for hackintosh? buy a samsung 960 NVME 630 is just for hardware acelleration, dont plug nothing there, have a specific config for it CLOVER.zip Link to post Share on other sites
jsl2000 0 Posted April 8, 2018 Share Posted April 8, 2018 (edited) Thanks for your prompt reply and help, but booted by this new Clover got CPU panic immediately as shown in the following photo: Edited April 8, 2018 by Guest Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 8, 2018 Author Administrators Share Posted April 8, 2018 press bar space and block kexts AppleAlc and Lilu Link to post Share on other sites
jsl2000 0 Posted April 8, 2018 Share Posted April 8, 2018 After block AppleALC & Lilu still got freezing of screen during booting as shown here: Link to post Share on other sites
ford2201 1 Posted April 15, 2018 Share Posted April 15, 2018 -FIX ERRORS AND WARNINGS -HPET -SATA -DMAC -SLPB -DARWIN -XHCI -PLUGIN TYPE -HDAS to HDEF -HDEF -RTC -IRQs -SBUS -MIKEY -BUS1 -MCHC -ALS0 -SHUTDOWN -LAN -USBX -PMCR -IMEI -EC -PNLF -GFX0 -HDAU -NVME -ASMEDIA USB 1 -ASMEDIA USB 2 -ARPT -INTELHDGRAPHICS Where add patches help me sned me files all asus prime B250M-a, i7-7700K, INtel HD Graphics 630+ Nvdia Geforce GTX 1060 6GB, 1360x768,Realtek ALC887, INtel Kaby lake HDMI+NVDIA HDMI/DP,RTL88111 Link to post Share on other sites
Karouteur 0 Posted April 17, 2018 Share Posted April 17, 2018 Hello Maldon, Thanks a lot for your great job. I follow your guide to succefully install osx on my two systems. Could you please help me now to fine tune the DSDT of the first one ? Here are the runme file Send me iMac-de-Ludovic.zip thanks for your help. Regards, Karouteur Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 17, 2018 Author Administrators Share Posted April 17, 2018 Hello Maldon, Thanks a lot for your great job. I follow your guide to succefully install osx on my two systems. Could you please help me now to fine tune the DSDT of the first one ? Here are the runme file Send me iMac-de-Ludovic.zip (2.96 MiB) Not downloaded yet thanks for your help. Regards, Karouteur CLOVER.zip Replace full clover folder, reboot, test all usb ports with devices USB3 Link to post Share on other sites
Karouteur 0 Posted April 17, 2018 Share Posted April 17, 2018 Replace full clover folder, reboot, test all usb ports with devices USB3 Thanks a lot ! I'll try this asap Link to post Share on other sites
Karouteur 0 Posted April 17, 2018 Share Posted April 17, 2018 Thanks a lot ! I'll try this asap It's Ok !!! well done. Could you please now do the same for my second system ? Send me iMac-de-CosPi.zip  Best regards Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 17, 2018 Author Administrators Share Posted April 17, 2018 It's Ok !!! well done. Could you please now do the same for my second system ? Send me iMac-de-CosPi.zip (3.73 MiB) Not downloaded yet Best regards CLOVER.zip Link to post Share on other sites
Karouteur 0 Posted April 18, 2018 Share Posted April 18, 2018 Thanks a lot MaLd0n. Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 18, 2018 Author Administrators Share Posted April 18, 2018 Thanks a lot MaLd0n. Welcome! Enjoy! Link to post Share on other sites
magnifico 0 Posted April 18, 2018 Share Posted April 18, 2018 Oi bro , about 9700K ?? Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 18, 2018 Author Administrators Share Posted April 18, 2018 Oi bro , about 9700K ?? just wait, u sell ur skylake? Link to post Share on other sites
H4K0N3 0 Posted April 19, 2018 Share Posted April 19, 2018 -FIX ERRORS AND WARNINGS-HPET -SATA -DMAC -SLPB -DARWIN -EHCI -XHCI -PLUGIN TYPE -XXXX to HDEF -HDEF -RTC -IRQs -SBUS -MIKEY -BUS1 -MCHC -ALS0 -SHUTDOWN -LAN -USBX -IMEI -EC -PNLF -GFX0 -HDAU -NVME -ARPT -INTELHDGRAPHICS Â Hi MaLdon, how are you? Please where can find this patches? I looking for in section of DSDT of this page but not at all. Thanks so much. Regards. Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 20, 2018 Author Administrators Share Posted April 20, 2018 Hi MaLdon, how are you? Please where can find this patches? I looking for in section of DSDT of this page but not at all. Thanks so much. Regards. post ur files, i'll check Link to post Share on other sites
PlexiPuter 1 Posted April 22, 2018 Share Posted April 22, 2018 Hi MaLd0n I also have a Gigabyte H270-HD3 with an i7 7700k using internal Intel 630 graphics for the time being. My question is, can I use the DSDT you did for aldebaran or would it be edited differently for my processor? Cheers PlexiPuter Link to post Share on other sites
Administrators MaLd0n 1,001,050 Posted April 22, 2018 Author Administrators Share Posted April 22, 2018 Hi MaLd0n I also have a Gigabyte H270-HD3 with an i7 7700k using internal Intel 630 graphics for the time being. My question is, can I use the DSDT you did for aldebaran or would it be edited differently for my processor? Cheers PlexiPuter u can use same DSDT from same mobo and same bios version, best to avoid problem Link to post Share on other sites
