Hackintosh Guide - Sierra / High Sierra / Mojave / Catalina on Serie 100/200/300/400 with Clover Bootloader
hanks you! You can help me patch it or how to patch it with some patchs you post. Sr, my english is bad . Thanks you in advanced.
Send me Nguyens-MBP.net.fpt.zi
put ur gpu in first slot, work at 4x only, bad
CLOVER.zip
Link to post
Share on other sites
  • Replies 1.5k
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
https://www.olarila.com/topic/9351-video-guide-opencore-vanilla-guide-step-by-step-full-dsdt-patched-or-ssdt/
Posted Images
Hi MaLdOn,
There is a new BIOS release for my board (Gigabyte Z370 Gaming3) with a lot of changes. I am sending you Send me Andro.zip file. Can you please send me patched DSDT file and suggestion for config.plist. I will have iMac18,3 (or iMac Pro 1,1 if you think that it is a better solution).
Thank you once again.
Regards,
Aldebaran
Send me Andro.zip
Link to post
Hi MaLdOn,
Regards,
Aldebaran
CLOVER.zip
send me new SEND_ME after reboot
Link to post
I have somes problems with pci and shutdown/reboot my hackintosh. shutdown/reboot is very slow , my pci not show like you. How to fix it pls?. Thanks in advance!
enable ERP in bios
the mobos B360 have a problems, the bios is a very diff, i don't have any b360 for debug and check what cause it, is just a cosmetic
Link to post
What's the deal with trim on 10.14 beta 4? (running APFS)
Got everything working on H270 apart from trim on 10.14 beta 4.
Ruby script works the same as on 10.13.6. (both HDMI and DVI look great)
I put audio back on 1 in DSDT. (I previously had it on 3).
Had to update AppleALC kext to 1.3.0.
had to update Lilu to 1.2.5.
Audio and HDMI audio working using RX560.
Link to post
I hear ya!
Not keen on apfs myself.
What's the best way to get Mojave over to HFS?
Is there a trim patch that works on Mojave in HFS?
hfs is perfect, apfs is for apple firmware, common ssd don't have it
Link to post
u can use in clover config.plist, easy and clean way
com.apple.iokit.IOAHCIBlockStorage
00415050 4C452053 534400
00000000 00000000 000000
Enable TRIM for SSD
10.14.x
Link to post
Hi MaLdOn,
I tried your CLOVER and everything is working.
I am sending you new Send me Andro_1.zip file so you can check if anything else should be done.
Also couple questions.
1 What FAKESMC are you using?
2. Can I get plugin for it for monitoring processor temperature?
3. Do I need EFICheckDisabler.kext since my board is Z370?
4. Why do you use NoDynamicExtract (YES) and NoOemTabled (YES). What would change if they are NO.
5. What shikigva=60 means and is that just temporary?
Regards, Aldebaran
Link to post
Hi MaLdOn,
Regards, Aldebaran
FAKESMC.zip
https://www.insanelymac.com/forum/topic/306156-clover-problems-and-solutions/?do=findComment&comment=2524096
EFICheckDisabler.kext, U can use without any problem
shikigva is for hardware acelleration
Link to post
:cap-Please Disable Your ADBlocker and Support Our Forum-:cap
