aldebaran 0 Posted July 5, 2018 Share Posted July 5, 2018 Hi MaLdOn, When I start using full patch (vanilla) DSDT should I use iMacPro 1,1 or iMac 18,3 SMBIOS? I have i5 8600K processor and RX560 card. Regards, Dragan Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted July 5, 2018 Author Administrators Share Posted July 5, 2018 both work Link to post Share on other sites
aldebaran 0 Posted July 5, 2018 Share Posted July 5, 2018 Thank you for quick answer. Regards Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted July 6, 2018 Author Administrators Share Posted July 6, 2018 Enjoy! Link to post Share on other sites
PlexiPuter 1 Posted July 6, 2018 Share Posted July 6, 2018 What's the situation with the USB by PM Heart patch? Does it replace USBInjectAll kext? Can it be used in conjunction raise port limit patch? Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted July 6, 2018 Author Administrators Share Posted July 6, 2018 PMHeart patch disable limit, is better than raise patch u can use PMHeart patch + usbinjectall without any problem Link to post Share on other sites
aldebaran 0 Posted July 6, 2018 Share Posted July 6, 2018 Hi MaLdOn, Any progress in vanilla DSDT for Z370 Gaming3? I would really like to try it and get rid of all unnecessary kexts. Regards, Dragan Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted July 6, 2018 Author Administrators Share Posted July 6, 2018 Hi MaLdOn, Any progress in vanilla DSDT for Z370 Gaming3? I would really like to try it and get rid of all unnecessary kexts. Regards, Dragan I don't have time for it now, some work here Link to post Share on other sites
aldebaran 0 Posted July 6, 2018 Share Posted July 6, 2018 OK MaLdOn, I will wait. Take your time. Regards, Dragan Link to post Share on other sites
jeff* 0 Posted July 7, 2018 Share Posted July 7, 2018 Hi MaLdOn, When you have the time, here are the requested files for a full patch for my new Asus Prime z270-A build! Really appreciate what you are doing, and hope to learn a lot from your what you are going to do! Regards Send me Johns-iMac.zip Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted July 7, 2018 Author Administrators Share Posted July 7, 2018 Hi MaLdOn, When you have the time, here are the requested files for a full patch for my new Asus Prime z270-A build! Really appreciate what you are doing, and hope to learn a lot from your what you are going to do! Regards replace full clover, reboot and send me new SEND_ME CLOVER.zip RunMe.app Link to post Share on other sites
jeff* 0 Posted July 7, 2018 Share Posted July 7, 2018 replace full clover, reboot and send me new SEND_ME CLOVER.zip (1.54 MiB) Downloaded 1 time RunMe.app  Hi MaLd0n, Here is the new send_me, many thanks in advance! Send me Johns-iMac.zip Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted July 7, 2018 Author Administrators Share Posted July 7, 2018 Hi MaLd0n, Here is the new send_me, many thanks in advance! Attachments looks good Link to post Share on other sites
jeff* 0 Posted July 7, 2018 Share Posted July 7, 2018 looks good I love how everything feels now! You are a king! Many many thanks, will donate and learn Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted July 7, 2018 Author Administrators Share Posted July 7, 2018 welcome and enjoy Link to post Share on other sites
PlexiPuter 1 Posted July 11, 2018 Share Posted July 11, 2018 10.13.6 update has gone shocking pink when my Radeon kicks in. Had to revert to clone of 10.13.5 to get back to normal again. I'm pretty sure it's not DSDT related as it's running perfect on 10.13.5. Any idea how to get around around it? Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted July 11, 2018 Author Administrators Share Posted July 11, 2018 10.13.6 update has gone shocking pink when my Radeon kicks in. Had to revert to clone of 10.13.5 to get back to normal again. I'm pretty sure it's not DSDT related as it's running perfect on 10.13.5. Any idea how to get around around it? i'm using DVI to avoid it, in HDMI appears it, need check if Whateveergreen solve it, but i don't like, appears other problems Link to post Share on other sites
PlexiPuter 1 Posted July 11, 2018 Share Posted July 11, 2018 My super native Z370 flew through the update with no issues, still on UHD GFX and only five kexts (combo update) Already on DVI on the H270 with the Radeon. Is Mojave any better? Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted July 11, 2018 Author Administrators Share Posted July 11, 2018 My super native Z370 flew through the update with no issues, still on UHD GFX and only five kexts (combo update) Already on DVI on the H270 with the Radeon. Is Mojave any better? Try with compiled version Arquivo Comprimido.zip Link to post Share on other sites
PlexiPuter 1 Posted July 11, 2018 Share Posted July 11, 2018 Thanks Mald0n! I did only try it with a version that was a few months old so this might do the trick. Link to post Share on other sites
PlexiPuter 1 Posted July 11, 2018 Share Posted July 11, 2018 I swapped the clover folder and booted from the Z370 drive on the H270. Still shocking pink. Tried adding the two kexts. No change but thanks anyway. RX560 only seems to go as far as 10.13.5. Bye Bye RX560 Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted July 11, 2018 Author Administrators Share Posted July 11, 2018 I swapped the clover folder and booted from the Z370 drive on the H270. Still shocking pink. Tried adding the two kexts. No change but thanks anyway. RX560 only seems to go as far as 10.13.5. Bye Bye RX560 i think no, ppl discovery one fix in next day xD Link to post Share on other sites
Dean91 4 Posted July 12, 2018 Share Posted July 12, 2018 MaLd0n ,Thanks! Send me iMac-de-Ygor.zip Link to post Share on other sites
Administrators MaLd0n 1,001,055 Posted July 12, 2018 Author Administrators Share Posted July 12, 2018 MaLd0n ,Thanks! send me complete files use updated app RunMe.app Link to post Share on other sites
Dean91 4 Posted July 12, 2018 Share Posted July 12, 2018 y MaLd0n » 11 Jul 2018, 21:52 Dean91 wrote: ↑ MaLd0n ,Thanks! send me complete files use updated app RunMe.app  Done, Thanks! added my clover folder Send me iMac-de-Ygor.zip clover.zip Link to post Share on other sites
